Changing the fuel filter
I plan on changing out my fuel filter this weekend, along w/ a few other things (air filter, cabin filter, coolant flush and oil change). I found these write ups but they are both for a B5 A4. Is everything the same? Also, if anyone has any tips or tricks to make it easier I'd appreciate it!!
TIA!
<a href="https://www.audiworld.com/tech/eng49.shtml">Write Up 1</a>
<a href="https://forums.audiworld.com/a4/msgs/2545196.phtml">Write Up 2</a>
TIA!
Do it yourself unless you can have it done for $20, it is not that bad if .....
<center><img src="http://pictureposter.audiworld.com/134540/s4_fuel_filter_tool.jpg"></center><p>you use a tool like this one. Put the correct size bit in it to loosen the filter clamp/holder thing. Run your car down to empty or drain the tank before removing the tank bolts. I just removed the forward bolts on the gas tank. For me the hardest part was getting gas tank bolted back on. Yes I had 1/2 a tank of gas in there.<ul><li><a href="http://pictureposter.audiworld.com/134540/100_2146e.jpg">Bigger Picture</a></li></ul>
KOpork
03-22-2004 09:54 AM
