Does this engine (2.7T) just misfire a lot?
AudiWorld Expert
Yesterday, after a spirited drive, I shut off the car and then went an had dinner. Three hours later, I went back out a started the car and had a CE light. Hooked up the VAG and had 4 DTC's,
1) Random Misfire
2) Misfire Cylinder 2
3) Misfire Cylinder 3
4) Misfire Cylinder 5
I checked blocks 015, 016 and 014 and they showed my car to be misfiring quite a bit. The misfire counters would get up to about 7 or 8 and then reset. Now, because of my AudiWorld induced paranoia, I've checked these blocks a few more times. I thought it might be bad gas so I filled up with Chevron 93 from a familar station and still was logging misfires. No DTC's or CE light, just a bunch of misfires. At one point, the total misfire count on block 014 totaled 27 and then reset itself. Should I be concerned?
I'm not really sure what counts as a misfire to the ECU, but it seems like it would be bad to me. I asked an Audi Tech when it first happened and he told me not to worry about it, but I haven't spoken to him regarding the contiuned misfires. I never checked these blocks before the CE light, so I don't know if this is normal. What's the general opinion?
Thanks guys.
1) Random Misfire
Thanks guys.
My 2002 recorded misfires in the same cylinders. SkydiveS4 cleared the codes for me
so I have no idea what the count is in total. Hasn't happened in a few weeks though. Oh and I have about 7700 miles on the car now.
The CE light, should not of cleared them unless chipped. Would of brought into dealer.
But the cars are known for misfires @ idle. The shop foreman @ my dealership said the S4's run hella lean @ idle and your getting Lean misfires. Who knows if true or not...
If my car ever thru a CE for misfire, I would jump up and down and bring it to dealer for them to do something. As it is now, car misfires away, no CE = Nothing looked at.
Mine had noticible mis-fires at moderate acceleration once...
...and the cel came on. I took it in and they said Intermittent Misfire, cleared the codes and told me to come back if it did it again. Well, it did, so I took it back and they're ordering a "Engine Temperature Sensor"??? I'll ask them more when I got in to have it installed this week.
PILL PUSHER
05-27-2008 03:12 PM
Achen
11-08-2002 07:43 AM
