Has anyone worked out how to setup 02 simulators yet?
What would it take to get the voltage/signal correct so we could run test pipes without setting off the CEL? If someone points me in the right direction or knows this info, then I'l make up a prototype set and start testing them ASAP.
Ds O2 voltages start like the front O2 sensors, but once the cats light up....
they go above 450 mv and stay there. The exhaust has no oxygen at this point cause the cats are reburning it all. The number seems to hover around 600 mv and go above and below by 200 mv peak to peak. Whatever circuit you put in can't have a series resistance higher than 500 ohms or the Ecu will think the sensors are **** up. The ecu corrects the mixture somewhat based on the ds o2's. Look through the vagcom measuring blocks in the forties for the correction values. The value is in Milliseconds. You want it to hover around zero correction.
It's a tough one; Can you tell I tried?!
I'm running cats now.
Gave Up and got some 2 1/2" i.d. converters.
I don't notice a difference in speed; it's just nicely quieter.
Post it or e-mail me if you figure it out.
VorsprungTT
02-01-2009 02:26 PM
Audii-Dudii
Performance and Tuning
12-04-2005 06:28 PM
Brdman*
33
02-20-2004 09:34 AM
Agent Orange
22
09-08-2002 06:03 PM
