HELP ALADDIN 2000 Questions
1. Does anyone know how to set turbo timer, and how it works.... I dont get the manual.
2. How come my auto engine start only works 4-5 minutes after i Arm car.. any longer.. and when i press "E" car just blink's and beeps 2x..?
Suggestoin and Explanations appreciated... thanks
Re: HELP ALADDIN 2000 Questions
I checked my manual to refresh my memory about the TT. Before you shut down the car press the "E" button then follow normal exiting procedure. You car will stay running for 3,10,or 15 mins depending on how you've set it up. When re-entering the car, put your key into ignition and turn to on(it takes a while to remember to not turn the key to full start.A couple of bone shattering screeches fromn the starter will break that habit pretty quickly)
If it's the run time of the TT you're refering to, Try having the system disarmed while doing what it says on page 25 of the manual. I just tried it and it works for me.
As far as the remote start thing,If you are folowwing the exiting procedure correctly, which you must be otherwise you couldn't remote start at all, you might want to call the Tech support line at 714-871-0887. They may take your name and # and call you back but they have been very helpful.
Hope this helps you. BTW where are you located?
