help with vag engine codes pleeaase!!!
well, I ran my car for a while with the ams chip and stock exhaust, 2-3 days about. then i got the exhaust and now all of a sudden its throwing codes. heres the codes
I appreciate any help in advance.
VAG-COM Version: Release 504.1-UD
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 17 25 35 45 55 56
Address 01: Engine
Controller: 8D0 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06711
Shop #: WSC 06435
7 Faults Found:
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17947 - Clutch Pedal Switch (F36): Implausible Signal
P1539 - 35-00 - -
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
16891 - Idle Control System RPM: Higher than Expected.
P0507 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Controller: 8D0 820 043 Q
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 920 981 BX
Component: B5-KOMBIINSTR. VDO D17
Coding: 02264
Shop #: WSC 08216
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 35: Centr. Locks
Controller: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16140
Shop #: WSC 63351
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 63351
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
Address 56: Radio
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00200
Shop #: WSC 63351
End --------------------------------------------------------------------------------------------------
Address 01: Engine
Coding: 06711
Shop #: WSC 06435
7 Faults Found:
P1539 - 35-00 - -
Coding: 04395
Shop #: WSC 06435
Coding: 00160
Shop #: WSC 63351
Coding: 02264
Shop #: WSC 08216
1 Fault Found:
Coding: 16140
Shop #: WSC 63351
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00102
Shop #: WSC 63351
Coding: 00012
Shop #: WSC 63351
Address 56: Radio
Coding: 00200
Shop #: WSC 63351
First of all, a gentle STFA is in order. There is information there about DTCs.
Second clear all codes and see if they reapper. Have you or anyone else used lemiwinks or anything...one of those codes looks like throttle cut or you might have a bad boost sensor. Might want to check your TBB for tears too...just my thoughts.
Hope that helps.
Hope that helps.
BeeRock::Riding Red
VAG-COM Discussion
01-22-2006 10:00 PM
JJCNSX
02-03-2005 06:30 AM
