I am going to be buying a stage 4 CM clutch very soon. One question.
I see there is a 4 puck and a 6 puck. I know the 4 puck is more aggressive. Whats the difference/ best for stage 3 A6 1/4mile tracked about 10x a year?
6 puck is probably what you want. You know neither of those will work with a stock flywheel right?
You have to get the CM lwfw (or I think vast offers a lwfw with countersunk holes that *should* work as well) otherwise there is a clearance issue with the crank/flywheel bolts.
I actually found someone that will sell me a lwfw. I was going to...
Get mine resurfaced but it scares me a little. I am going to buy the used FW which I was already told it should work.
I also just ordered an new replacement surface to throw on it.
Careful though. Any fw will work with the stage 3/4 (also called a segmented stage 4)
But the 4/6 puck stage 4 is different. I'd hate to see you have everything installed only to find out it doesn't work, necessitating another trans pull...
SoSlow
01-17-2008 03:03 PM
AudiSport44
06-14-2006 11:03 AM
zszabo
12-05-2004 07:32 PM
~DonQPremiumTequila~
05-24-2004 05:29 PM
mdwsta4â„¢uroslut
06-03-2003 10:09 AM
