Neuspeed 19mm Sway BT: I got a creek - normal?
Put a 19mm sway on the avant this weekend. Its on what I believe is the Med setting (tube strut all the way up, ends of sway in outer position attached to susp). I am getting a slight creek out of the passenger side. Wondering if this is normal or not. I am contemplating taking off and re-installing.
I will say that the ride is subly improved. More over-steer as expected. It is a plesant offset to all that high glass on the avant that tends to make the rear roll a bit more than the sedan.
Mine squeaks. Still lubed decently. Only happens when I go over speed bumps...
or other things that cause one side of the car to be much higher/lower than the other.
audikidS4
01-30-2017 02:23 PM
GOTPSI
14
03-12-2002 01:03 PM
T-28-Quattro de VT
06-08-2001 08:27 AM
realdeal
10-15-2000 04:12 PM
