Question for SmokinS4 or others
Regarding the euro Dash Panel -- Driver's Side Footwell. I noticed in one of your tech articles you have euro version with the extra pokets and headlight leveling switch. I also havethis part but have not installed it. What did you do about the OBDII port? And have you hooked up the leveling switch? Do you have info on the wireing for this? I do have xenons with leveling motors but my S4 does not have the auto leveling sensors so having manual control would be great.
TIA for any help.
TIA for any help.
OBDII port is relocated to the ashtray just like early A4s. Headlight switch doesn't work yet.
Toyguy wrote up some stuff on getting it to work - try digging through the archives or emailing him.
Re: OBDII port is relocated to the ashtray just like early A4s. Headlight switch doesn't work yet.
So you relocated it to the rear of the center consol? The rear cernter ashtray....did you just splice/cut the wires and extend? Or is there a simple male....wire...female connector?
Will check archives for Toyguy stuff thanks.
Here's Toy Guy's post and some info from Matt.
<ul><li><a href="https://forums.audiworld.com/s4/msgs/2588533.phtml">https://forums.audiworld.com/s4/msgs/2588533.phtml</a</li></ul>
audikillsbmw
15
05-21-2007 05:38 PM
