RS4 fuel pump. Pics of replacing unused branch hose
Here's the RS4 pump showing the infamous Y-fitting and extra unused plastic hose. I had a bolt installed to plug the un-used hose. Please forgive the messy bench..
<img src="http://dave-new.com/S4/modify_rs4_pump/Mvc-451x.jpg">
It's tough to see, but I used the longer un-used plastic branch hose to replace the Y fitting and shorter hose.
<img src="http://dave-new.com/S4/modify_rs4_pump/Mvc-452x.jpg">
Longer hose attached to the right side of the check valve.
<img src="http://dave-new.com/S4/modify_rs4_pump/Mvc-453x.jpg">
Longer plastic hose attached to pump, where black hose (shown to left in background) was connected.
<img src="http://dave-new.com/S4/modify_rs4_pump/Mvc-455x.jpg">
Uh, removed rubber hose..
<img src="http://dave-new.com/S4/modify_rs4_pump/Mvc-456x.jpg">
oem clamp that has "15.7" stamped on it.
<img src="http://dave-new.com/S4/modify_rs4_pump/Mvc-457x.jpg">
your post is why I jumped on it today. thanks
I'm having some problems that sound similar to what you had. I'm not sure this is my problem but it really needed to be fixed regardless.
thanks
thanks
Cheers, and ygm.
Give me a call if you want to talk more. I don't claim to be a pro at this, but I DID learn a LOT getting my car fixed.
I'm totally slammed between work and the airbox project, but want to hear what your problems are and what you've checked so far.
CvTech
12-24-2007 02:39 PM
tragopan86
06-03-2003 01:21 PM
