20" RS4 Wheels for my S6 - Need help with offsets
I think I like the look of the RS4 wheel for my S6.
They are manufactured by Hartmann and VMR, but they each make them in different offsets. I need help, what do you guys think would look best? I want them to be as flush as possible with the wheel well without rubbing issues. Do you think they would look nice on an S6?
For starters I'm going to use my exisiting stock P Zeros (255 35 20). Eventually I'm going with Michelin Pilot Sports, but I might as well use up the crappy Pirellis.
HARTMANN:
HRS4-252-GS
20" x 9" ET40
20" x 9" ET25
or
VMR:
V708
20" x 9" ET35
In order, here are the Hartmanns, the VMRs, then a B8 A4 with the wheels.
HARTMANN:
HRS4-252-GS
20" x 9" ET40
20" x 9" ET25
or
VMR:
V708
20" x 9" ET35
According to the wheel offset calculator, the ET+35 9" wheel will push the outer rim to 16mm beyond stock. Is that too much or just right?
ET+40 9" will push the outer rim 11mm beyond stock.
According to tire rack the rim width range for the P Zero 255 35 20 is 8.5" - 10". 10" sound a bit big for that tire, but that's waht they claim.
For reference, click the link below in my sig to see photos of ET25 with 9" rims. This pushes the wheel out 26mm compared to stock. With a 265/35 tire (Michelin PSS), I've rubbed twice over the last 10k miles in the front on the same turn that has this big depression/dip. If I were to do it again I'd go with 20x9 ET32-33 if I could customize the offset.
20x9 ET 35 is just about damn near perfect for the S6 and will nicely fit a 265/35 tire. 255's will also be fine. My previous RS4 had 255's on 9" wheels as the stock set-up and it looked great.
cheewy
9
07-08-2016 05:35 PM
Chigger
S4 (B8 Platform) Discussion
02-10-2016 11:33 AM
Chin Choe
Wheels & Tires Discussion
09-25-2015 10:39 AM
