Retro fitting Heated seats trouble & coding HVAC
Old 04-21-2019, 06:38 AM
Allwiredup's Avatar
Default Retro fitting Heated seats trouble & coding HVAC
Hey everyone, Just wondering if there's anyone out there that can help me out. I picked up a C6 A6 for parts so I thought I'd take the heated seats out of the parts car and install them into mine. I removed the wiring and installed the harness into mine with no trouble, had to remove all the seat leathers and install them over the heated cushions which were a (PITA). As for my HVAC controller, I removed the blanking plates that are in place of the heated seat buttons and swapped the buttons from the parts car, that way I wouldn't worry about the component protection on the controller. after putting everything back together and pushing the heated seat button, I did get the picture of the seat in the MMI screen. But when I went to adjust the temperature it stays on 0, I cannot find anything in VDCS that says anything about heated seats, When I go into Output test and select heated seat left or right it says an error 4 from the controller, I plugged in the parts car HVAC controller and of course, it says off of both displays and the buttons don't work but when I go into output test for the heated seats they both work. So I found the EEPROM that stores the coding for CP in HVAC and swapped it over to the parts car one. Now It does light up and seems to work but now I'm back to where I started, it shows up on the MMI but stays on 0, and the rear defroster will only light up when the button is pushed and won't stay on lol. I did read about going into adaptation channel 81 and change the values to reset the controller, but it says security access needed, and of course, I have no idea what the security code is, I know it's not 01122 lol. Any help on coding different controllers that I'm missing or a direction I can try would be a big help, sorry for the long read....
Old 04-21-2019, 07:01 AM
A6Gary's Avatar
I don't know if this security code will work, but here is the security code I used in VCDS to access the air suspension module when I changed the rear air shocks on my A6 Avant:
[Security]
[Do it!]
[08367]
This is the code I obtained from Ross-Tech.
Old 04-21-2019, 07:32 AM
Allwiredup's Avatar
Thanks A6Gary, but no joy
Old 04-21-2019, 10:52 AM
hrc4u's Avatar
what coding you have on the climate?
or..post full vcds log..can compare with mine..
/H
Old 04-21-2019, 01:47 PM
Allwiredup's Avatar
This is the scan with my HVAC that shows the seat on the MMI when the heated button is pushed, but cant adjust the temp. and if I go into the output testing it says not supported error 4, I did plug in the other HVAC that is locked but will test when done though the output test-03, and coped all the adaptation values in all channels that would allow me to enter a new value, and placed them in the other HVAC controller with no luck. So if you can see something that I'm missing please let me know lol
File Type: txt
Old 04-22-2019, 11:05 AM
hrc4u's Avatar
the log shows 2 component protection ? ...get rid of atleast first the HVAC-02084 - Component Protection
...clear codes and rescan.CP locks out lot of functions.
/H
Old 04-22-2019, 11:55 AM
Allwiredup's Avatar
The only way to remove the CP is through Audi right?
Old 04-24-2019, 02:34 AM
hrc4u's Avatar
Mm.... The "short" answer and The easiest way is yes.
Or shop or someone with gecko online access to v.a.g
(or someone with abrites software.. Or equivalent 😁.. )
/H
Edit : I think CP is not only stored in the chip you mentioned.. You also need to have the gateway from the donor car.. If I remember correctly.. 🤔 If you going to try get rid of it.. But then comes other components to be unhappy..
A1EK
01-14-2017 12:26 PM
nickelmedia
09-26-2006 04:49 PM
faiz_twinzdaddy
02-18-2006 09:10 PM
Quick Reply: Retro fitting Heated seats trouble & coding HVAC
