Immobilizer bad actuator bad r-tronic pump
Hello everyone,
Long story short, the car will not start or turn over but I have full lights and radio and etc... I replaced the battery.
There is a gear light and malfunction on the actuator and possibly the r-tronic pump. I do not hear is priming anymore when i open the door.
Why can't I start the car and why do I have an immobilizer code?
SEE BELOW:
Address 02: Auto Trans Labels: 420-910-156-V2.clb
Part No SW: 420 910 156 H HW: 420 927 156
Component: SL600 5.2L FSI HDZ 0020
Revision: SBH02001 Serial number: 7MHN1523J
Coding: 0000001
Shop #: WSC 06759 128 40452
VCID: 14644498378075EF25-8040
Subsystem 1 - Part No: 420 713 041 C
Component: A11 C02 11.11.08 0A11
2 Faults Found:
005934 - Shifting Actuator
P172E - 000 - Mechanical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 110043 km
Time Indication: 0
Date: 2019.05.23
Time: 20:27:23
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
Torque: 0.0 Nm
Temperature: 21.0∞C
0.00 %
006079 - Hydraulic Pump
P17BF - 000 - Play Protection - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Mileage: 110043 km
Time Indication: 0
Date: 2019.05.23
Time: 20:28:23
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
Torque: 0.0 Nm
Temperature: 21.0∞C
0.00 %
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No SW: 420 920 980 J HW: 420 920 980 J
Component: KOMBIINSTR. VDO H02 0360
Revision: D0H02001 Serial number: AUX7Z0I2FNO0DX
Shop #: WSC 00000 000 00000
VCID: 1C742CB8DF503DAF6D-8048
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
SEE BELOW:
Coding: 0000001
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 110043 km
Time Indication: 0
Date: 2019.05.23
Time: 20:27:23
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
Torque: 0.0 Nm
Temperature: 21.0∞C
0.00 %
Freeze Frame:
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Mileage: 110043 km
Time Indication: 0
Date: 2019.05.23
Time: 20:28:23
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
Torque: 0.0 Nm
Temperature: 21.0∞C
0.00 %
1 Fault Found:
014 - Defective
Whoever replaced your battery jacked things up. Sorry.
Still sounds electrical. That immobilizer module ROM error is an electric knife in it’s heart that would only be fixed by a dealer.
TT4XNYR
TT (Mk1) Discussion
10-04-2007 12:13 PM
bantu
05-01-2006 04:35 AM
