View Full Version : 30v V6 Discussion
- Anyone w/AHA ever put on headers (sans cats) then put a hi-flow cat at the resonator area?
- 30 valve 2.8 V6 Cam bearing cap numbering?
- Low compression on bank 2, assume head gasket?
- Advice on cleaning throttle body and evap canister valve
- TB dead, need replacement
- I NEED AHA 30v HEADS
- Evap Purge Valve Ticking - Annoying...
- Just replaced cam chain tensioner...need advice!!!!
- cruise control
- 2.8 heads
- Lightened Pulleys
- Throttle body
- Secondary Air Injection fail.
- P1545 Code
- Coolant
- a bit of a miss
- Starter Problem "I CANT GET IT OUT" HEEEEEELPPPPPP PLS
- ticking or tapping
- NGK Iridium IX still perceived as the best choice of plugs for the 2.8 30v?
- SUPERCHARGED A4 on eBAY!!!
- Need more Power
- I'm looking for any information on aftermarket light weight pully systems?
- idle not stable at low rpm when not moving , and engine hestitates when accelerating
- P1423
- 1999 30v V6 quattro engine pics needed PLEASE HELP!!!!
- Engine mounts / Purge valve / 1999 A6 2.8Q
- Clutch job on a B5 2.8 30v? nearly 130 K oem clutch getting tired
- P0141 code: 2002 A6 3.0L
- Forever fun Year/Mileage post, I 'll start: 1998.5 129.000 miles. Stronger than ever.
- A4 2004 3.0
- does the 2000 a6 have an accesory position with the key? key has to be in the on postion for me
- 2000 a6 2.8l flex pipe leaking directly in front of the cat converter is that 8 year 80kmiles HELP!!
- Driver Side B pillar wind noise- Does anyone know how to fix it yourself?
- A4 2.8i (ACK Gen III) Timing
- Audi/VW G-005-000 Manual Tranny Oil "use until" date
- New Suction Pump and Oil Leak
- Noise behind serpentine belt
- upper oil pan leak 98 A4 2.8 30v
- Intermitent engine hesitation (cold/warm) and erratic idle
- idle not stable at low rpm, and engine hestitation when accelerating
- Best place to find a used oil pan?
- Safe Boost Level for 30v with SC
- 2000 A4 looking for right side cylinder head (1,2,3 cylinders) 2.8L ATQ
- urgent help needed.
- Cam Adjuster seals on 2.8 l 30v
- cold air
- Can anyone tell me what sensor is #1 in this picture?
- Oil leak and check engine, are they related?
- PES Supercharger 2001 A4 2.8
- Modefying throttle house from eletrical to manual
- Looking for AHA engine in Vancouver BC area.
- Engine Speed Sensor
- Driving Manual....
- Building the perfect exhaust
- Who needs a PES G2?
- New converters Overthreshold fault Bank 2
- AHA engine
- Cross-post (kinda)....How do I remove stuck hoses?
- Please help: cyl 4-5-6 misfires
- A6 took wife for a ride
- 99.5 2.8 30v stalling at each stop
- So I find myself with an extra intake manifold and injectors...
- Has anyone tried the NGK Iridium IX spark plugs?
- Does the Crankshaft tool only fit correctly if your at TDC?
- SAI delete for the 30V 2.8
- Massive oil leak
- can somone please help me with this dilemma? shouldnt be too hard thanks!
- Hissing sound under vacuum plate
- V6 Tiptronic - sluggish acceleration on quick brake to throttle transition
- Quiet Down Exhaust
- The A4 isn't wanting to start right seems like loss of power???
- okay 2 question regarding timing
- How many litres for oil replacement (2.8L 30V AHA)
- timing problems dont know where to go from here (kinda long)
- anybody in phoenix renting a camshaft lock tool?
- Hard starting B5 A4 2.8 30V
- 2000 A6 2.8 transmission fluid change instructions
- 3000 rpm at 70 mph is that normal?
- Converting Wheel HP
- Does the 99.5 A4 FWD 2.8L come stock with a Oil Cooler?
- Anyone got any advice on good sprak plugs?
- Throttle actuator code? '99 A4 dies at idle
- Some questions.. Oil Leaks=$1,100 in parts and cam adjuster seals Valve cover seal
- Upsolute Chips??
- Improve Throttle Response on MT5?
- 98 a4 quattro 30v triptronic: stock top end speed?
- valve cover leaks
- What do you gain from haveing a " Cold Air Intake" I'm runing a K&N.
- oil on plug wires and in cylinders - due to bad seals/gaskets or dead heads??? Please help!
- Does anyone know where the thermostat is located at on the 99.5 A4 2.6L FWD.
- Hi - Anyone here know what the 3.0l engine dynos at on the driven wheels?
- Power gain with the HyperFlow Induction System for the 2002-on A4 3.0 and the Milltek Catback?
- Remus Muffler for 30v in the Classifieds
- #1: diesel fuel in gas #2:.....
- Does anyone no if a GIAC AHA chip would work for a ATQ engine? 99.5 V6 (6spd)
- I have a 98 A4 2.8 30V and i have some problems
- How could this happen? Improperly torqued screw?
- Need help diagnosing a misfire
- Anyone have any tips for changing the Trans fluid In a 99.5 A4 2.8L V6 (6spd)
- Looking for a GIAC chip for my 1999.5 2.8L V6.
- DAMSEL IN DISTESS engine error code help PLEASE!
- Swapping to the 2.8L 30V ATQ from a AHA - Need some Input Please...
- Timing Belt Nightmare?
- starting
- Rear Muffler colors. Wow!
- Bari- toned Ghrrrr noise when acelling & decelling through 20 MPH
- what brand exhaust system are you guys using? which sounds the best
- does anyone know where left sealing plug is located (2.8 30V ATQ)?
- Where can i buy a new ICV for 98 a4?
- Anybody want to rent me some timing tools?
- Replacing engine in 98 A4 w/ 2.8l
- 2004 30v V6 engine parts on ebay!
- Since I did not
- Goofy coolant temperaute gauge
- OIL
- Switching out a 2.8 for a 2.7T
- AHA and ATQ?
- Is 10,000 Miles between Oil Changes on A6 3.0 OK?
- WHAT'S THE FIX?
- Help! Oil is dripping from these caps? Are these the cam caps?
- heads
- How difficult is it to change the timing belt?
- burning smell after cold start?
- A4 tranny delay shifting
- Replacement Cats
- Best oil and gas grade for stock 2.8l vs. supercharged
- If you know of any performance engine part sources for the 30V 2.8 please post
- Xpst, 3.0 owners: Anyone know what kind of pressure reading I should be getting at the FPR vac line?
- How do you tighten accessory belt? Do u have to remove bumper? Thanks
- check engine light
- Interior dome lights come on automatically after ignition
- Newb!! Hello Gentlemen!! 99 A6 2.8 Quatttro Transmission Question
- A6 2.8 misfires on cold start
- timing belt replacement
- Crossposting. I probably should have started these over here.
- Engine clatter
- WTB: A6 ECU
- questions..
- Exhaust Whistle
- Just got my Blackstone Laboratories report on my engine oil:
- In search of used GIAC chip
- GIAC chip for 30v for sale in the classifieds..
- Engine Time Belt broken (dont know it's real name), Q: Valves affected? AHA V6 30 valves
- Where is the Power Steering fluid located on a 02 3.0 FWD???
- Oil Type/Filter
- repost: from a4 b6 forum...
- What is the best oil for an a6 2.8 30v?
- More Power!!
- Oil Question- my dealer said 5w30 but everyone on here seems to say 0/5/10w40- whats the deal?
- Sparkplugs for 30v 3.0
- sts turbo
- Paging Audi Junkie re: Mobil 1 SUV 5w-40
- changed spark plugs and wires but problems...
- 3.0 Catalytic Converter Replacements?
- First gear noise
- Problems with acceleration!!! A6 2.4 30V
- Exhaust options for my 2001 A4 2.8...
- Maf problems?
- my 99 audi a4 bepps after i shift from first gear
- Clutch replacement on '00 A4 2.8
- Will the dealership combine labor charges on several repairs?
- New oil pan for A6 2.8 30V is different from the old one, and I'm STUCK in Texas!
- When's a good time to switch to synthetic?
- if you have not done a throttle body cleaning do it ! >
- A/C compressor whine/groan around start-up times.
- Audi a4 3.0 quattro specs
- Motor not starting
- Big Oil filter for the 2.8 ? same as the 1.8T ???
- another BMW convert and my first Audi....
- Help w/ knock after PES G2 install. Is this common? Cure? TIA
- Time for timing belt replacement
- Clean lower breather tube with kerosene?
- Stage III MAF??
- Leaky oil cap area.
- Cylinder #5 half-dead
- 2.8, 3.0 Supersprint Headers
- Flickering Lights, PLEASE HELP
- differences in starters?
- oil pressure specs
- miles
- anyone know what kind of internals these engine have
- Please help me with Tiptronic problem
- Battery dies after timing belt + seals + coolant expansion tank job
- xpost from awma: clutch install completed (almost)
- junk in the gas tank?
- Electric fan problems
- Let the teardown begin
- Cross-post re AHA & ATQ thermostats for anyone who has run a cooler t-stat or knows . . .
- Has anyone fitted a BMC CDA induction kit help
- MAF Died again?
- Oil Change Intervals
- OBD II not ready??/
- Transmission temperature sensor error AND torque converter error
- K&N Air FIlter Installation Help
- New Audi Parts10% OFF !!!
- oil leak rear of engine?
- what couold be leaking in the front of the engine down low?
- windshield washer failure
- help...burning oil any ideas?
- Help Needed - P0305 - Cyl 5 misfire
- Camshaft oil seals - anyone have tools to rent near Milwaukee?
- Looking for a used G2. Can anyone help me find one?
- Spark plugs
- Plan to use Auto Rx in my 1998 Audi A4 2.8 30v AHA...
- Has anyone experimented with FPR and or injectors on a NA type 30v?
- Anyone have the weights of both the 3.0l and 3.2l FSI engines?
- Does NE1 know if I can find a 2002 owners manual on-line?
- superchargers
- I'm about to change the timing belt...
- 3.0L performance cats?
- Has anyone thought of turbocharging the 30v V6??
- Help Anyone???
- Looking for DIY Oil Change walk through!?
- vag softcode program..what is it and where can u get it??
- Cut cats out and run straight "test pipe"......horsepower?...yes or no?
- Does anyone know if the audi TT fuel injectors and fuel rails fit on the 30V
- 150k!!!!!
- Auto RX review, findings and what I think of it all
- Engine schematics please Email agony
- What other mods can I do to get more horsepower out of the 2.8L 30V
- Fuel injectors and fuel rail
- Excessive Oil Consumption
- audi a4 quattro induction kit help !
- What is the best chip for the 2.8 30V motor
- Quattro Tiptronic Drivetrain Quirks - HELP PLEASE!
- Cats failing on 2.8 V6. Can't search archives to find if any information
- Best Chip Upgrade
- Audi Expo 2006 - Come be a part of history again!
- Cross post help please
- Valve cover gasket question...
- hard to start after fueling
- Does anyone recognize this chip?
- where to get rear main seal?
- Does this sound stupid?
- Anyone tried out a Stebro exhaust before? Or what exhaust do you recommend? i dont want super loud
- First 1,500 mile phase of Auto-Rx is done; now in 2nd 1,500 mile "rinse" phase.
- Oil Consumption
- 30V Timing - how to tell if its set right? stfa, found nothing....
- tensioner seals DONE.... so far so good...
- Audi Expo 2006 - It's coming!!!!
- transmition problem.. heeelp
- where can I buy the green check valve? i cant find it on ECStuning..
- Audi a6 3.0 exhaust inlet?
- helppppp urgent
- cam tensioner seals...where to get them... DIY job?
- The Constant Coolant Leak?
- LPG Conversion
- Vivrating while driving, please help?!?!
- won't start - 98 A6 2.8 30V
- My A6 Wont Stay Running
