View Full Version : 30v V6 Discussion
- :: ECS Tuning :: Cam Locking Tool Kit!!
- 1998 30v 2.8l Camshaft Alignment
- Slave Cylinder problem after clutch replacement
- DIY
- Engine rollers (which rolls, which don't)
- radio replacement
- halogen to LED or xenon lights humm?
- Any thoughts?
- wtb 3.0 avk vin T and E
- Bank 2 sensor 1
- 1992 Audi A4 3.0 Quattro oil problem
- Car won't shift into gear? Perhaps this is the culprit...
- Booster leaking?
- idle control
- looping idle
- 1999 A6 2.8 Q fault p1392 Cam Position Sensor
- P00021 Intake Cam Advanced
- How do I get my 2.8 V6 back in time?
- 2.8 shakes when at idle compression is
- Vacuum at idle?
- VW in to Audi???
- Red oil pressure warning
- VALVE COVER GASKETS
- Oil pressure sending unit replacement
- Blowing off oil filter after 30 miles?
- Cylinder Misfire Problem
- Water Pump Replacement
- 2003 3.0 CEL codes
- 1996 a4 12v swap to 1998 30v
- APTuning End of Summer Service Specials - Timing Belts, & Alignments!!!!
- engine surge
- 99 A6 Quattro 2.8 Question.
- anyone with audi tool 3242...need dimensions asap
- Sherwin
- 30V Frankenstein
- 1999 Audi A6 Q 2.8L Overheats after.......
- Stock Spark Plugs Part # Please
- Engine warning light...????
- Replacement Flexpipe Longevity
- ATQ deck height/piston stroke
- timing belt ?
- vibration at around 1500 revs
- JUST DIED
- Big oil leak!
- Timing Belt, Valve Gaskets, Cam Chain Tensioner Job
- is there an official 30V thread? engine removal
- Cam chain tensioner
- "Throaty, Tractor-Like" Sound when Cold Starting
- Intake Cleaning - Recommendations
- Camshaft seal replacement - small scratch
- CHRONIC BELT/PULLEY SQUEAKING ON 3.0 A4
- Audi F6 (C4) pin data. HELP!!!
- WP locked up and the timing jumped
- Fuel sender plug.
- x-post from b5 a4 forums.
- Any idea what this part is?
- Cd Changer
- Fuel sensor issue with 2000/01 A4 Quattro 3.0V6?
- oil problems
- should i put in a surge performence chip
- Fuel Injector EXTERNAL leaking. NOT O-RINGS!
- Q 7 Diesel engine problems
- APTuning New Years Timing Belt Install Special for Virtually all VW/Audi Models!!!!
- 2000 a6 after run pump?
- Flywheel alignment to crankshaft
- 2.8l engine ignition timing at idle
- Serpentine belt tensioner, replace?
- catalytic code
- Quick Timing Belt question..
- Advice on A4 3.0 Engine Situation Please
- cYLINDER HEAD FOR AUDI
- WTB: 1996 A4 2.8 V6 auto trans
- 30V V6 B6 Model Performance Tuning ECU - GIAC
- Engine heater for winter
- O2 sensor codes
- More Hp
- hydrolic tentioner
- Bent Valve Not Timing Belt Related
- 2.8 L valve train noise - need advice.
- Sprint Booster Power Converter
- Reprograming key fob
- Missing, will not run over 2000 rpm plugged cats?
- Sudden misfire
- Apparent Phantom Misfire on cyliners 3 and 5
- Codes. Help me out!
- Very strage problem
- 99 Audi Throttle Body
- EATON SUPERCHARGER on older models?
- weird noise
- WANTED: vag-com SYRACUSE
- weak points
- original equipment
- 2.8l RPM fluctuates when cold
- audi a4 3.0L engine help
- Can thermostat be repalced without removing timing belt?
- timing belt
- Trany code help
- Noctious Exhaust smoke
- Coolant temp sensor
- Leaking Crankshaft Seal
- audi exhaust
- engine sputtering at low rpms
- Bad rattle form a V6 engine bay.
- Cooleant temp high light on
- Clicking noise on valve/camshaft after Timing change
- Misfire on 4,5 and 6 ...
- Minimum Oil Indicator
- Question
- No Power and Misfires
- Need help, A6 wont start
- Engine Coolant Sensor - location???
- First check engine light --> need help
- After cleaning throttle body no acceleration
- Oil Leak after Timing Belt Change 3.0 L
- Suction Pump - wrong version being delivered
- Do the engine covers do anything useful
- Oxygen sensors
- Where to buy timing belt kit?
- coolant sensor location???
- Anyone Try the new LLTek "Sprint Booster" acceleration modification?
- vehicle cylinders misfiring
- Power Steering Lost- Serp Belt Off
- Need Repairs-- Auxiliary Fan, Valve Cover Gask, Cam Tensioner, etc.
- P0411 - SAI Pump Running When Car is Off - SOLUTION
- Oil Pressure LIGHT!
- Timing Belt - AAAAAAH!
- 2002 A6 3.0 valve cover oil leak during winter conditions
- 1998 a6 2.8L Question about parts
- 2002 A4 3.0 Crank Case
- Timing Belt Tensioner Roller Torque
- Engine out for TC, what maintenance to do (O2 sensor, cats??)
- how should I reset the timing on my car...
- Random misfire, cyl 1 upper limit misfire on 3.0
- Just Got My Car Back, Now This
- aftermarket cams?
- mechanical fan pully
- Will 17" rims with 45 offset fit on 2000 A6?
- anyone need a 30v engine?
- Need some advice on A6(new to forum)
- Egine rattling
- oil cooler part
- 30v compicated?
- Sea foam
- Had tracking done car is still pulling left ALOT..
- burning oil,white smoke, i knw its valve cover gasket but...
- Audi A4 3.0 Timing Belt Change Question?
- TB/valve cover gasket/cam tensioner what else should i do? preventative 86k
- Variable Intake Valve
- Emission DTC P1411 and P1423
- Windshiel washer not working. I thing it is the pump, but need the part#...
- Engine rattling
- I want to supercharge but i have a few questions
- Rebuilt 30V 2.8 engine price question.
- Rattling in left engine bank
- loud clicking, ticking noise under acceleration
- Need definitive answers on o2 sensors
- 2005/A6/3.2 vs 2001/A4/2,8
- Oil question (-: boys with over 150K what do you use summer and winter for oil?
- Timing Belt change or not
- Multitude of problems
- Got a few codes
- Burning oil smell, some smoke, and then this...
- Can we talk about oil viscosity and misfires for a minute?
- brand new 3.0TFSI fuel engine
- Need help on taking off Center Timing belt cover for 2002 A6 Quattro 3.0L
- coil packs
- Replacing breather hose did not solve misfire problem, I think I still have oil in my plug wells.
- 30 valve compression check
- Cause of silly O2 trims and thirsty engine?
- Knocking/Rattling from upper engine in '99 A4 2.8
- Water pump, 2.8 30V
- Some folks might find this handy, PDF of the 30v 2.8l engine schematics
- Could a totally broken/disconnected breather hose put oil on my plugs?
- Scanned car with OBD2 and found four codes...any advice?
- potential "new" purchase
- Looks like PS pump is about to die.
- leaking from carnkshaft and camshafts
- Please help - Misfiring on one bank of AHA engine
- Bad cat.. tried everything!
- CAM Tensioner aka sew machine
- Pulley Bolts Damaged or Loose After Audi changed my timing belt
- Anyone want my used stock cats
- Help! My oil, abs, and brake warning lights go on, and no tach...
- A/C making a Squeeking/Squealing noise on cold Startup
- 30v v6 turbo kit
- Timing Belt Slip??
- Timing Belt Q's...
- here's a good deal on timing belt tools if anyone is looking. (not mine)
- Evap 16825, yadda yadda yadda
- Foaming PS Fluid and Pump Noise
- Clutch replacement
- is there any way to recalibrate a TB from an auto to work in a 5spd?
- Cam Tensioner Issue - Screwed?
- Bank1 Bank2! Where is it?
- Cat or O2 sensor
- A4 3.0 V6 Head Gasket Change - Cam Locking Tools
- Question regarding brake booster.
- hard starts and 2 engine codes
- Crank/Engine speed sensor location for 2.8 engine
- Inaccurate fuel consumption indications.
- MAF readings for 2.8 V6
- Why is my Audi A6 keep loosing the tension on my new timing belt??
- S4 Exhaust??
- Anyone ever moved the timing chain one tooth without full teardown?
- Camshaft cover bolt.
- 2.8L 30v Misfiring.. Help
- WTB stock exhaust 98 2.8q (CT/NY)
- Drivers side bank not firing
- p1113 code 17521
- Just to be sure.
- A6 , pcv, oil catch can 6v ?
- Nothing to do here. Mileage pool: 148.576K 2.8 30v 1998.5 runs like a charm!
- Fuel regulator on 97 2.8 30v
- Timing Belt Service in Denver, who is the best?
- how much should a new clutch cost 98 A4??
- What is this part?
- Transmission 80,000 service
- Ok, quick question about gasket kits and sealant
- X post from A4 forum: Question on installing SC
- about to try an ACK ecu in my AHA car. Anything I should beware of?
- '04/'05 A4 3.0Q Ultrasport Owners Needed...Please
- Would any of you buy another 3.0 Audi?
- 02 a6 3.0 tip trans problems...HELP!!
- Need new size of Serp Belt for 3.0 eng. after bypassing AC pulley
- Engine flush.
- Need advise in regards to the Water Pump.
- Cam Plug Replacement (BWW)
- FAN PROBLEM????
- Ignition Coils and Readiness Codes
- Does anyone make an aftermarket catalytic converter for the 3.0?
- Muffler needed for B5 2.8 30V. Any suggestions from you guys?
- How does the NGK BKUR6ET run in the AHA engine, anyone try these?
- Cam plug replacement (paging 77'911 again!)
- '02 30V B6 A4, lean codes/rough idle and running conditions
- Effects of Deep Puddle
- Just for viewing pleasure.
- camshaft seal leak for third time
- P0302 Cylinder #2 Misfire
- Ok I hate to do this but I have searched for another 4 hours and am sick of looking
- 2001 A4 2.8 starts with very short misfires every morning
- Getting loud grinding sound from (I think) Power Steering pump.
- What are a pair of 30v 2.8 heads worth
- >>> URGENT HELP: A4 3.0 Quattro - Suddenly Rough Idle / Bad Pulley ???
- 30v Intake and PCV parts - paging 77'911 :)
- tranny leak
- 30v Timing Belt Change - List Please?!!
- engine odor inside cabin
