View Full Version : 30v V6 Discussion
- anyone here run one of VAP's s3 hose kits?
- Coolant Issue - '98 A4 with 30V 2.8
- questions regarding pes supercharger G2
- ABS Lights
- Blocked pressure hose
- Is there a 30v crash course thread?
- oh woe is me.....
- Can anybody make sense of this? Trim info..
- Valve cover gaskets leaking after replacing
- need help, working on timing belt A6 2000
- Mixing Engine additives
- Howdy howdy howdy
- A fix for the Leaky Oil Cap
- rattle during high revs
- mount diagnostics
- Crosspost: Timing belt service: 12V vs 30V...compare and contrast
- Fuel filter question.
- 1998.5 A4 Avant running a little hot...
- as far as what it out there right now what is the min/max weight for summer oil?
- ====>> Need Help urgent~~~~!!!! Empty fuel tank=> engine damaged <====
- "Warm up catalyst below thershold..." errors.
- Coolant Temp Sensor Location
- Are the EGR valves servicable on 2.8 V6?
- misfiring and engine light
- 1998 A4 avant
- Did the timing belt + more and now I have big trouble - please help
- Timing Belt Time
- Need help from those who have done a tranny service....
- spark plugs
- service engine oil warning light flashing at start up.
- cel codes..
- what is normal engine oil pressure for the 30V (AHA/ATQ engines if that matters)?
- O2 sensor replacement DIY?
- catalytic converters 2.8 V6
- Cam adjuster wear? When/how do they typically fail?
- Sorry forgot there was a 30V forum. posted pic of my valve cover leak...
- please help fix my oil/coolant leak....
- GIAC chip?
- timimg belt replacement
- Still have oil leak twards front in middle even after replacing
- 30V AHA engine fuel requirements
- Please Help - I'm almost there - Head Gasket?
- Timing Belt Question???
- clarification for valve/cam gasket replacement
- Engine shake while idling
- CO reading far too high
- Part # please
- Posted this in regional forum, but no luck.Looking for a little help.
- Calling audix...help coolant leak!
- Call me crazy
- Warm-up catalyst below threshold-bank 2
- Spark plug BT: NGK BKR6EKUB plugs -- gapping these not applicable?
- Engine Failure
- cracked/broken breather hose...
- Any words of wisdom on replacing the engine mounts?
- Help with codes "16730" P0346-35-00
- Check out the haul I scored of Craigslist. 30V cam timing tool/lock...plus
- Air box issue, help needed
- Misfire in multiply cylinders???
- A6Q 3.0L (AVK) CATs
- Audi A4 3.0 stalls, throttle body suspected. Need part# and/or advice if there..
- Q re Throttle Body Adaptation....video of my results. Is this normal?
- My cats are out on my A4! $3999 each at dealer, what can I do? Test pipe? HELP!
- oil pressure
- Rpm problems .
- Electric Fan?
- evo mr turbo
- Replacing O2 Sensors.
- Engine Code Location ( I searched)
- Brake & Abs Warning Lights
- My A4 is Oil Thirsty.
- A different oil question
- Oil Temp
- Rpm Gauge problem
- RS4 ecu for a na 2.7
- is it safe to use g-05 light yellow coolant ? instead of g12+ ?
- COMPUTER?
- AIR
- Gear box and oil pressure light
- Whine from front of engine?
- Haldex Clutch???
- Deciding on a Clutch..
- engine code ACK U.S equivalent is it AHA ?
- Tapping sound appears after the engine fully warn up?
- Monster
- can any1 help a newbie servicing a4 2.8 v6 30v quattro pls ?
- Tapping
- Evap System Code?
- Where to get a PCV valve on a 98 2.8 A6
- PES G3 on a TIP 3.0quattro a4?
- Q re adaptation required after tranmission replacement.
- Rough Idle/Poor Performance...
- Are 2.8 30v heads a direct bolt on to my S4 2.7T?
- URGENT HELP PLEASE TRANSMISSION FLUID
- replacing front primary/warmup cats in 30v 2.8 a4
- car sort of missing
- Need a 2.8l AHA 30v engine?
- TPS Bad circuit code
- can a 30v be swapped into a b4 chassis (1995 90Q)
- Has anyone change a timing belt in a 3.0L 2002 A4?
- Deciding What Oil to Run..
- 2.8L30v- Is PES SC emission free? especially CA.
- Did A Compression Test This Morning..
- Multiple running faults on ACK engine
- Help! O2 sensor
- Timing belt replaced now it wont start 2.8 30V
- is 2000 A6 outer CV circlip splined?
- 2.8 exhaust flex joints
- fault codes
- Question regarding heads + cams.
- s-belt length to bypass a/c compressor
- have a no spark,no fuel situation in my daughter's 98 A4
- play in a/c compressor clutch?
- Borrow cam adjuster tool??
- AWE exhaust
- Where to get a new engine in SoCAL?
- Need RECOMMENDATIONS on Brake Fluid
- Coolant temp sensor
- Dealership Costs
- Oxygen Sensor replacement (pre-cat) on 2001 A4 2.8
- 03 a4 A/C compressor issues
- x-post from last week ,TDC marks for 30v
- Misfires
- Has anyone removed cats and put straight pipes?
- Coolant leak.
- Are there any light/ lighter flywheel or performance clutch options for a 30v V6?
- Hey Guys I'm a former 12v and have been considering the 30v. Things I should look for? component Qs
- Where the H*ll is the oil leak coming from!? I'm an angry Audi Owner.
- Head Gasket, now WARPED HEADS????
- Engine wiring harness for 2.8 v6 30v 1998.5 >
- Horrible fuel economy in 2001 A4, 2.8Q
- 30V with code 1545 and CEL
- Question about Secondary Air Injection.
- Coolant system bleed in a 2.8 A6??
- trouble code po432 1998 av 2.8 105.000 miles
- Tell me how the cam chain tensioner works....2.8L 30v
- engine rebuild
- help quick please! car in for repair, need advice on transmission quote $$$
- need for speed
- Valeo or Bosch?
- Cam Tensioner Seals / Valve Cover Gaskets. Please Help!
- Burning Smell
- Violent sputter upon start-up and codes
- Engine surging / cutout
- rear engine cam plug seals
- Fan Belt (ribbed belt) tensioner bolt sheared!
- oil pan cracked
- Cooland Reservoir Overflow Drain
- A6 3ltr Time belt???
- Intake and ECU
- Clutch Slip (after replacing heater core) Coincidence?
- Warm up the engine?
- What kind of coolant?
- Replacing the electric radiator fan
- recommended level of power steering fluid
- leak from oil pan
- timing problem or what???
- Vibration/noise help
- '03 A6 vacuum actuator
- '02 A6 oil pressure??
- Error Code
- Poss TB problem..
- s4 exhaust
- where I can find one conrod?
- help track down oil leak in 30v 2.8 (pics)
- changed my oil yesterday and...
- Engine oil quantity
- level of power steering fluid
- 4 bolt mains
- how to remove intake air duct
- Knock when startup
- FYI: If you clean your MAF, do the IAT sensor as well. Just solved a rough idle by doing just this
- Dealer "fixed" exhaust leak, now there's a huge vibration + loss of power
- no heat / defrost / wipers / blinkers in cold weather...
- Thermostat and Temp sender
- Another coil pack failure
- Where to buy Philips xenon ballasts
- Battery light is on.. couple questions
- APR and Jim Ellis Audi present Petit LeMans Customer Appreciation Weekend
- When should timing belt be replaced?
- Will a 6-speed bolt up to this motor?
- exhaust question
- HELP with A4 3.0Q 6sp
- O2 Sensors
- RS4 Cams more aggressive than stock AHA 30v cams?
- is this possible?
- Where are the O2 sensors on the US-spec pre<99.5 2.8L 30V/Quattro
- 98' 2.8 30v Headgaskets (rumor has it they dont fail)
- Crosspost form A6 (C5) Need help - Problem with secondary air ports
- Doing an everything service and have a few questions..
- Picture of TB Tensioner after mounting bolt sheared off.
- 2001 A4 2.8 on auction
- ECU Number Query
- Camshaft Position Sensor
- p0421 and p0431 codes
- Rattling noise in first gear
- How to tell if a water pump is bad?? (long winded)
- Cat Converter Honeycomb Crack Leak
- Does anyone know a repair guy who really understand,and fixing the audi in Brooklyn..????
- Cat Converter modification - will it help?
- where is heater core hose?.. coolant capacity?
- Cheap Horsepower Options
- Front seats adjustement
- What is the Correct Temperature Thermostat 2.8 V6 99 A4
- Cracked My Oil Pan
- Looking for used cat back exhaust in tri state>
- idle is not stable
- Oil Leak Please Help
- 3391 and 3242 Dimensions
- 1998 30V Valve cover gaskets
- A4 quattro 2.8 Turbo
- CEL and those codes. Cleared and worked fine since, what could that be?
- ? Code .. P0118 : engine coolant temp circ High input and general Temperature gauge info
- Coil pack went bad
- Audi cat converter problems, was stuck a couple times
- 2004 A4 3.0 v6
- 2.8 Cat Replacement
- Tool rentals.
- 30v upper oil pan
- 1 touch window not working
- Replacing my throttle body in a 99 a4, need a guide or at least a list of tools
- Crankshaft locking.
- For the archives: pn 433862117 check valve
- Cooling fan thermostat location...
- Very strange. Im stumped
- Anyone here have experience with these aftermarket exhaust part manufacturers?:
- Starter location?
- oil pressure warning light
- Torque specs needed for head replacement..........
- Oil
- Good plugs that I can recommend: BOSCH Super Plus YTTRIUM
- Anyone know what the wrist pin diameter is for the 30v engine? ive seen 20 and 21mm... which is it?
- Are new light weight pulleys worth the money??? Thanks
- water in secondary air pump?
- Strange Thing happened to me today
- power maxx vortex
- 98 a4 V6Q With a horrible rattling noise almost like an engine knock
- 99 A4 30V codes P1250, P1137, P1139. Runs normal
- NOOB exhuast Q???
- Best spark plugs???
- Not mine, but I know people here will be interested...PES G2 on evil bay...3600 Buy-it-now
- Misfiring Issues.......
- s4 swap
- what is there behind the ac compressor that could possibly leak oil?
- dipstick reading (very) high. what the deuce?
- 2001 2.8 30v Misfires
- Has anyone re-mapped their 3.0l 218 bhp ecu?
- CEL - Code P0432
- X-post from B5 A4 forum: Exhaust question -- drawbacks to a bigger cat-back on a 30v 2.8?
- Bucking
