PDA
View Full Version : 30v V6 Discussion
Pages : [1] 2 3 4 5 6
  1. coolant temp sensor
  2. Audi 80 V6 transmission on Audi 2.7t
  3. 3.0 v6 petrol ASN throttle body issues
  4. Engine rev speed suddenly increased to min 1000rpm
  5. 01 b5 a4 30v 5spd bad ecu?
  6. P2149 Audi A7 3.0
  7. 2017 Q7 3.0 Throttle Response At Intersection
  8. Broken PCM?
  9. Injector fault or just the copper washer
  10. 2.8 ACK C4 Coolent leaking into the oil
  11. 2,8 30v V6 - cam chain rattle ~1 sec on startup
  12. TDI Q5 Leak From Fuel Rail
  13. Told engine needs to be replaced - low compression cal 5
  14. Problem with my A7
  15. Q5 TDI Coolant Leak
  16. Magnaflow 11385 vs 11386
  17. My PCV Valve exploded! What causes that?
  18. Audi A4 B9 Crankshaft broken
  19. 2.4 bdw engine starting issue
  20. Transmission Warning persistent 08031 – Clutch temperature monitoring
  21. Audi Q5 3.0 TDI Under boost P0299
  22. B6 3.0 Qestion
  23. Problem with CCWA after high pressure pump change
  24. Diamond Disk on Oil Pump Gear
  25. 2016 A7 3.0T Stalling?
  26. 2017 Q7 3.0T no start
  27. A6, C6 3.0tdi quattro 2004 fuse problem.
  28. A6 C6 3.0 TDi V6 N75 Location?
  29. 01 Audi A6 Quattro 2.8 issues
  30. Cooling fan won’t turn on
  31. Help I'm stuck.
  32. Audi 80 2.8 V6 helpp
  33. Audi a8 d3 3.0 2005 plate starting issues
  34. Heavy shaking/bucking at 30-50 mph...
  35. 15 Audi S5 coolant leak
  36. Does torque converter come out with engine?
  37. A6 3.0 TDI QUATTRO LOUD KNOCKING NOIZE
  38. 2.8 timing cam problem
  39. Diaphram near rear camshaft sensor 2.8
  40. 3.2 P2539 P2296 P2006
  41. Atf fluid level after radiator disconnect
  42. Timing belt replacement strange noise
  43. 01 A4 stalling when then engine heats up.
  44. No power to coils?
  45. Engine health
  46. Torque value for head bolts 3.0 litre
  47. 04 Audi A4 Quattro v6 3.0 Overheating Issue
  48. Breather Hose crack caused crank case vent. crack?
  49. 2003 Audi A4 3.0 Quattro
  50. 2012 A6 3.0 high oil consumption
  51. 2013 SQ5 TDI
  52. audi a6 2.4 multitronic. transmission problems
  53. Secondary Air Induction Fan / Homelink/Gas cap lock
  54. Recommend me the correct valves and drop a link where i can purchase please
  55. I need some help with a 2.8 valve train...
  56. 2005 a4 3.0 water pipe under manifold
  57. Where to start with these fault codes? Engine starts but stalls immediately. 3.0L V6
  58. 2003 audi a4, 3.0 engine
  59. 2004 Avant Quattro 6MT stalling after running 10-30 seconds
  60. Excessive crankcase pressure?
  61. 3.0 V6 timing job; check those camshaft bolts!
  62. Car won't start
  63. 2015 Audi q5
  64. very poor fuel milage
  65. Rough starting and coolant not circulating
  66. transmission
  67. A7 Rattling/shaking at idle only
  68. engine overheated
  69. 2.8l throttle body won't reprogram?
  70. Picture of leak. Camshaft seal?
  71. Over heating
  72. Vibration and Clunk noise underneath when i launch
  73. 3.2L A6 surging engine various camshaft erross
  74. Surging engine and Various Camshaft errors
  75. 2.8 30v engine removal and replacement
  76. 2.8 oil pan
  77. 2000 a6 avant Quattro 2.8 epc light and other problems
  78. the locking camshafts T40030
  79. Changing oil type...
  80. 2004 3.0 Random misfire cylinders 4,5,and 6
  81. A4 2005 3.0L Went over a speed bump hard
  82. “Minor” Rear-end Collision, Exhaust Damage
  83. need help with this part. 2001 a4 2.8l 30v
  84. Possible 2.7 trans on a 2.8???????
  85. 2003 A6 3.0 V6 slight shaking
  86. OBD P0301 code - hesitation/lagging
  87. 99 a4 wont start
  88. 2002 A4 3.0L
  89. 2.8 ignition misfire
  90. First Audi
  91. Crankshaft compatibility ATQ to AHA
  92. 98 audi a4 rebuild?
  93. audi 3.0 glow light flashing
  94. Rebuilding, scored cylinders
  95. Can't get Temp Sensor out
  96. Cts, thermostat or something else???
  97. Rebuilding a 3.0
  98. 2000 2.8 (A6) Vacuum, vent, and supp air lines??
  99. P1411 P1423, fixes found?
  100. Audi Q7 3.0 tdi oil
  101. Problem with random misses 2000 2.8
  102. 2000 2.8 Spark Plugs
  103. 2016 A7 oil filter
  104. Uh oh? 3.0 avk
  105. General AHA information?
  106. Please help!
  107. 2001 Avant cranks but won't start
  108. URGENT Please Help - Leak?
  109. Bad cam adjuster ????? Help
  110. 97 Audi A6 2.8 V6 how to set engine timing
  111. 2002 audi a4 quattro v6 repair questions
  112. Low Oil Pressure & Moisture in Oil - 2002 A4 B6 3.0L AVK
  113. 2.8 PCV reroute
  114. Help please my last hope of keeping the car
  115. AVK 3.0 motor timing and failure modes..
  116. Few questions about PCV system
  117. please help??????
  118. C5 A6 24Q - Tiptronic trouble (Valve body)
  119. Please help. A6 2.8, terrible drive shaft vibration
  120. 30v 2.8l Possible Rod Knock
  121. 2.4 V6 precat o2 testing
  122. oil change quantity, WTF?
  123. 1998 A6 Quattro Misfire Problem. Think I may have it narrowed down, but need opinions
  124. A4 3.0TDI NO REVERSE!
  125. Audi Guru/Master: Help with Transmission
  126. What engine is this?
  127. Do I need a new MAF?
  128. 3.0 B6 serpentine belt tensioner install
  129. 1,2,3 miss fire 2.8 v6
  130. need help ASAP 2.8 30v motor issue.
  131. Timing question
  132. 2.8 AHA bent valves with correct timing?
  133. Car won't shut off
  134. steam from valve cover
  135. cooling fan
  136. Battery drain fault
  137. Oxygen sensor pigtail wiring?????
  138. Help! Two grooves on timing belt
  139. HELP! Need to lower subframe
  140. A6. 3.0 Diesel 2005 smoke after idle
  141. accelorator problem
  142. Broken crank case breather hose
  143. injector operating sound
  144. Best oils
  145. Timing belt snapped
  146. Coolant smell
  147. head bolt torque spec
  148. Audi miss fire
  149. valve cover/cam/tensioner gasket replacement
  150. 03 a6 3.0 engine noise
  151. 2.8 missing
  152. Transmission oil change
  153. Transmission fluid leaking... now what?
  154. having difficulty removing dipstick tube
  155. Car stalls under load! she was also vandalized :(
  156. TB change
  157. Coolant in wire harness
  158. CEL P0306 Coil Pack misfire
  159. I need a quick heads up on replacing motor and trans mounts on my c5 2.8.
  160. 16398 (P0014) Code GOING INSANE!
  161. :: ECS Tuning :: B5 A4 V6 Transmission Service Kits
  162. Timing belt / valve cover seal replacement
  163. A6 2.8L Quattro -- Misfires, Catalytic Converter etc..
  164. voltage meter sky rockets?
  165. 01 A6 2.8 Quattro oil and temp problems
  166. Intermittent, but serious misfiring
  167. :: ECS Tuning :: Timing Belt Kits for B5 A4 V6 30v
  168. Need some help. 99 audi a6 quattro w/A4 motor.
  169. a4 manual transmission on a6 c5..
  170. RPM Bounces after Timing belt change
  171. Charging system failure
  172. Audi 2.7 V6 30v 2671cc APB boost levels ?
  173. 2001 S4 fuel injectors leak in extreme cold
  174. fuel filter?
  175. 3.0 head needed for my 03
  176. 99 a6 need help please!!!limp mode
  177. NEED Expert Engine Help....PLEASE!!!
  178. Center motor mount location?
  179. HELP WITH LOSS OF POWER AND A POP SOUND
  180. 3.0 Head Failure...NEED ADVICE
  181. Bad coolant leak 02 A4 3.0
  182. In Cleveland area need help w/ ticking & TB replacement
  183. 3.0 CAT failure rate
  184. AVK 3.0 Engine surge
  185. :: ECS Tuning :: Schwaben European Essentials Tool Sets!!
  186. ATQ Engine Serpentine Belt Replacement
  187. Camshaft Seals / Camshaft Sproket question
  188. :: ECS Tuning :: Pentosin - Superior Fluids For Your Audi
  189. A6 3.0L head gasket write-up?
  190. Timing belt kits
  191. Transmission code because of misfire?
  192. C5 3.0 upgrades
  193. 3.0 starts intermittently - any guesses?
  194. 3.0 starts intermittently - any guesses?
  195. Help. Running Rough
  196. Variable Timing
  197. ATQ - suspected timing chain tensioner bad
  198. Running Hot / Overheating
  199. :: ECS Tuning :: B5 A4 V6 30v PCV Kits!!
  200. Any issues with the 2010 3.0T?
  201. :: ECS Tuning :: B6 A4 V6 30v Timing Belt Kits!!
  202. 2.8L 30V Cylinder Heads
  203. 2004 3.0 v6 lean code mystery
  204. High idle 30v v6
  205. A6 C6 grumble under acceleration
  206. Bad Defective Blauparts
  207. Timing belt failure
  208. 2.8 internal upgrades
  209. Guess the oil leak - AVK 3.0
  210. In Chicago, Need Replacement 3.0 Engine & Shop Recommendation
  211. Chipset for 2012 Audi A7?
  212. Need help finding this part for less.
  213. 2009 A6 Avant turbo wagon burns oil
  214. :: ECS Tuning :: D.I.Y - VIN Decoding!
  215. Can Anyone Figure This One Out?!!?
  216. New throttle body?
  217. Help with valve cover leak....
  218. fault code P1519 on 98 A4 30v V6 HELP
  219. Low pitch engine knock 2003 A6 3.0
  220. 1999 Audi 2.8l PROBLEM!! Please Help
  221. Coolant leak from cross pipe. Pull manifold?
  222. 3.0L, engine cranks, timing belt don’t turn, will I have holes in pistons?
  223. Cooling fan running all the time
  224. 2004 a4 3.0 t-belt question
  225. 2003 Audi A6 Avant problems
  226. 2002 A4 Timing Belt install - Timing Question
  227. Vacuum line confusion
  228. Vacuum Lines / Mis-firing & poor idle
  229. 98 30v smoke issues
  230. Can you help me identify?
  231. 2005 Audi A4 3.0 Multiple Cylinder Misfire
  232. A4 2.8 diagnosis help needed
  233. 2.4/30v spark lead order.
  234. P1411 - 17755 - Cam Position Sensor 2
  235. What is the correct engine oil temp?
  236. REPLACING TAILGATE FOGLIGHT TRIM??
  237. Help on part identification
  238. water pump replacement
  239. a4 3.0 pcv issues
  240. 1999 A6 2.8L 30V - not starting after timing and cam seal work
  241. Changing cam seals, tensioner seal
  242. Where to insert crank lock pin? Different pin for 2.8 2V?
  243. Throttle body/DPF light engine management light
  244. How do you get to the slave cylinder bleed valve?
  245. help me plz 99 audi a4 2.8 check engine codes p1626 and p1392
  246. Why is oil still leaking from my 2009 A6 3.0 T?
  247. different AHA versions?
  248. misfire at all rpm
  249. 1998 2.8 30v a4q cat help
  250. Timing belt tools
