View Full Version : Q7 MK 1 Discussion
- navigation issue on my screen.
- Coolant temp sensor to gauge
- Looking for an Audi engineer to help me replace some parts
- 2010 Q7 TDI Coolant Pump 2
- Help!! Missing power amp issues
- Fault Codes 00814 and 01316
- Rear 12 Volt flap will not close
- suspension problems
- Prevent or Fix the Steering Wheel Column Lock Actuator on Q7/A6 C6
- 2015 Q7 driver's side door won't open from inside
- MMI 3G+ issues
- P102A00 - Torque Limitation due to Coolant Temperature
- 2011 Q7 TDI CP4 DISASTER PREVENTION
- Audi q7 2023
- Help: 2015 TDI P0402, EGR, DPF, Boost prob
- 2015 Q7 Oil Leak 3.0L
- Audi Q7 4.2 Gas 2008
- 2015 Q7 TDI, no heat/coolant flow from engine
- Live Traffic Not Working
- Audi Q7 install memory seats
- Q7 In Limp Mode Help
- 2010 Q7 TDI coolant leak found
- Feasible exhaust repair?
- A problem with my wipers
- 2010 TDI Oil Cooler leak
- HELP identifying coolant hose
- air suspension issue
- MMI adapter for USB C
- How to program new Batt w/ VCDS
- 2010 Q7 TDI, HVAC seems to have a mind of its own...
- Banned????
- 2014 Q7 3.0 TFSI (CTWA) Fuel Pemp Relay Location????
- Wheel hub diameter???
- 3.0 TFSI
- ZA: 2009 Q7, headlights
- Full battery with radio but no ignition
- Random Headlight issues - Q7 need help
- DEF fluid not transferring
- UK: Diesel Oil?
- UK: MMI buttons?
- Banks iDash SuperGauge
- MMI issue 2014 Q7 s Line
- 2015 Audi Q7 No AC
- Tow setting w/out the MMI Option
- DPF took a crap after 43,000 KM's
- Monronie Copy Request
- 2015 Q7 3.0 Premium Plus EPC and 20 psi in cylinder 5
- Trans mount replacement
- Tunezilla Black November Event - 15% off
- 2011 Q7 completely dead MMI
- UK: Oil pressure Sensor for V6 diesel?
- Steering wheel module 16 security access code
- 2009 q7 3.6 part out - let me know what you need.
- Heated Steering Wheel Retrofit
- What is this???
- Final boss steering wheel vibration
- program heating remote
- RO: Oil dipstick strange readings
- Flashzilla pro vs tunezilla dealer
- 3.6 Exhaust Measurements
- USA: Questions about Emissions Delete on 14 Q7 TDI
- 2011 Q7 Front RIGHT seat removal
- 2014 trouble codes Mmi not functioning
- 2014 q7 s line
- Wires exposed under front seats Q7 2022 Premium plus
- Replacement Climate Control Knob
- Anyone know this part and where to find?
- S line issues
- Oil pressure regulator valve
- 2010 Q7 TDI Part (Coolant hose) Lookup Help Request
- Need Help (Sensor)
- 2013 Q7 3.0T issues. - Long-winded
- 3.0t no oil
- Access/Start Authorization Antenna; Passenger Side (R135) location
- Front Bumper Questions (In Search of Parts)
- Diesel: How much to delete? And who offers it?
- TPMS and ECS lights with vibration
- All weather tires
- Please help!!!
- 2020 Q7: How to remove rear trim from center console
- New to me: 2015 TDI Prestige -- recommendations?
- 2010 3.6 fuel system operation direction of gas flow
- 2010 q7 gas filter driver side
- need help -- 2013 Q7 diesel battery drain
- 2010 Q7 Front Turn Signals
- Air is blowing, just not from any vents. Blend Door????
- Q7 3.0 tdi DPF EGTs fault
- MMI screen is not coming on
- motor mount replacement
- Q7 Rear propshaft dust seal
- Vcds coding
- Q7 FM radio antenna
- Switching to 18" wheels Q7 Prestige
- will supercharger oil leak out if upside down?
- Audi 3.0 TFSI Engine Head Bolts and Engine Codes
- Q7 air suspension issues
- Q7 3L Battery
- ABS brake line diagram
- NVH when in Park or Reverse
- Q7 TDI NOx sensor - how difficult to replace?
- Anyone have experience with persistent condensation in headlights?
- q7 Navigation not available
- 3.6FSI Fuel system.
- Q7 4.2 engine issue, seems like air escaping.
- Side mirror advice
- Starting Issues of 2009Q7
- Audi Service Coupons? Tried and true?
- Check engine light flashing , Q7
- Aux cord issues
- Suspension goes back to Auto mode and all other modes disabled
- Exhaust PITA
- EGR Cooler or Head Gasket
- 11 Q7 Steering
- 3.0 TDI Coolant Change procedure.
- Best wireless Apple car play kit ?
- Q7 ECU COVER
- No Audio from 2010 Audi Q7
- Headlight disassembly - how to get the motor out?
- These worked error free if you want your reverse lights a little brighter.
- Who makes a cold air intake for 2014 Q7
- 2015 prestige s-line cargo cover
- Sline emblem lightin
- Left Dipped Headlight (and no light) - not resolved with new bulb
- Parking Module
- Audi a4 2003 b6 automatic transmission problems
- Audi q7 2011 3.0 TDI parts number request
- 2021 Audi Q7 3.0 6 Cylinder
- Should I worry? Getting close to 120k miles
- Best Bulbs for Q7???
- Air Bag codes - simultaneous - 01738 and 01739
- Is all this water Sunroof Drain Related?
- 2011 Q7
- Nice 2014 Q7 TDI on BAT
- q7 diffuser?
- Self locking ‘15 Q7
- Anyone run 20 x 12 wheels on a Prestige w/flares?
- Coollant expansion tank hose swollen.
- Misfire help!
- Is it normal to not have a brake sensor on the passenger side caliper?
- No Tire pressure reset in MMI
- ABS issue, possible battery issue?
- 2013 MMI 3G+ - slow/unresponsive
- People that have replaced their struts
- 2009 AUDI Q7 3.0 S LINE diesel
- Aftermarket Matrix Style Enclosure
- Audi Q7 Increase DRL Brightness
- Frustrated with crank no start
- 2010 Q7 TDI Oil in Turbo ccoler line
- Misfires on one bank
- DEF Injector Location, 2009 Q7 TDI?
- Which wire/electrical connector is this? 2014 TDI
- 2011 Q7 3.0 TDI Engine Removal
- 2015Audi Q7 Steering Rack Nightmare
- 2012 Q7 CJWB Head Bank 2 Rebuild Inside Car - DIY
- MMI 2G Low - No Nav Button
- tr: Q7 Turbo Problem
- 235/60/18 to 255/60/18.
- Ran AdBlue Out: 2009 Q7 TDI
- Intermittent static through speakers 2010 Q7 3.6
- Warm heat problems
- q7 bluetooth issues
- MMI Issues - Please HELP!
- 2010 Q7 3.6L Valve Cover Leak
- Another PDC issue
- 22x10.5 +21 offset with 285/35R22
- 2010 Q7 TDI HPFP Replaced, Crank, no start
- Help, p0721 car will not go in to gear 2012 q7
- BA: Q7 2007 front end won’t lift
- Rear speakers not working
- Weird HVAC/Blower issue? Help
- Center console fuse box location
- Hose ID?
- EE: Help!!
- Low oil light. First time.
- Is Adaptation Required?
- A new owner's questions
- Q7 87K - Carbon build up killed cylinder #2
- wrong diesel oil?
- 2011 Q7 TDI Parking Brake Issue
- Need help Audi Q7 2007 no start after parking
- Whistling under acceleration
- oil change and DEF fluid
- AWD/Differential Issue?
- Beginner tips on valve cover gasket replacement
- Spare FOB
- Advice on 2015 Q7 Diesel
- 2008 Q7 3.6L FSI FUEL PRESSURE ISSUES
- 2007 Q7 driver side rear heated seat connector
- 2015 Audi Q7 3.0 TDI with P0135 code.
- 2015 Q7 Passenger-Side Headlight, Turn Signal and Fog Light out
- Battery leak?
- Armrest Cover
- Windshield wiper question
- Winshield Wiper Blade not sitting Flush
- New MMI circuit board briefly lights up screen then goes dark
- Part number for the vacuum line goes around driver side supercharger
- Fuel Injector ejected from cylinder head
- Vibration at idle
- Mystery Wire in 2014 Audi Q7 Trunk
- Ipanema Brown Q7 - TDI
- Rear shade handle
- Audi Q7 Adblue Fault Nightmare
- Miles to empty recalulates based on fuel use, DEF does not
- 07 Audi Q7 fuel pump issue
- Weight
- wheel bearing noise
- EPC Light Comes on at RPM 1300 come to a stop Remains High RPM 1300
- 2013 Q7, AC problem. Leak in system
- Service info
- 2011 q7 fuel door won't open
- UK: substantial smoke from oil cap! help! help!
- 13 audi q7 3.pt tsfi want to change crank times
- Mysterious Vibration
- Strange harmonic noise from TDI, pulley bearing?
- Wheels from q7 mk2 do fit?
- Codes P0275, P0272
- high pitch chirping/squeeling at startup and then stalls
- Need front plate bar for 2011 Q7 S-Line
- 2015 Q7 TDI from hell
- Android head unit for Audi Q7 Touch Screen 8 Core Snapdragon 665 CPU 8+128GB RAM
- Heavy steering wheel shake
- Aftermarket Shock Experience
- Looking for Audi Q7 10' drawing schematic
- Looking to swap my front glossy black filler bar for one with plate holder
- Damaged Bumper Side Mounts - Repair With Fiberglass?
- Hose hanging under front left near bumper
- DO: Q7 3.0 tdi start to miss and cuts when warm
- Annoying problems of Audi Q7 FSI 3.0 Engine and models between Q7 2005-2009
- new in group. have problem with AC. basic settings.
- Q7 Died Mid Drive
- Replace oil cooler gaskets, now have a crank no start.
- Tranmission fluid change
- I was today years old when I found this out - Q7 edition
- Audi Q7 2007 4.2TDi coolant leak
- Any CB'ers on here with tips for antenna mounting?
- Q7 with fault code 00456 J518
- Q7 leaking mostly red fluid...
- 2014 Q7 - TDI: Slight hesitation when accelerating...
- Question on MK1 Q7 Audio Options in Context of Today
- Air Suspension beginning to fail - diagnostics?
- Possible Power steering failure??
- Need help Identifying a part
- Oil spec for deleted q7?
- Q7 4L little problems - Help pls!
- Limitations on the factory SD card reader?
- Brakes
- TPMS for second wheel set?
- Headliner
- Anyone get their Bose Amp repaired by a company?
- AMI Port USB Passthru Replacement
