View Full Version : Q7 MK 1 Discussion
- High pressure sensor(G65) lower limit exceeded
- Water pump replaced with other coolant issues
- Help, can't figure out where this connector goes.
- 4.2 FSI oil consumption?
- Transmission recall
- AU: Cracking Amps-battery-long cranks in warm start
- Lamin-x headlight / taillight film
- Feedback Desired: Kansas Audi Dealers
- To TDI or not TDI?
- Door sag?
- TPMS monitoring on instrument cluster?
- Annoying Buzz/Rattle/Vibration noise on drivers side.
- Is there a trunk cover when 3rd row is in use
- "Auto Hold" vs engaging the parking brake every time
- 2012 Q7 Transmission Jumps Between Gears
- My Q7 trouble codes
- Front Wipers Motor issues
- Maintenance
- 2015 Audi Q7 Tdi P0C2E
- Replacement Rear View Mirror
- 07 q7 Electric towbar won't go back in.
- P100D 04109 error
- UK: Passenger side door foam mould issue
- 3.6L Exhaust Tips
- Air suspension - worth the wait?
- TDI Ext. Warranty expired - do I keep it?
- 07 Q7 Sirius Radio Greyed Out
- Can't open door from inside or outside.
- Switching to black from chrome.
- KKL VAG-COM for 409.1VCDS-Lite Issue
- 13 premium plus 3.0
- Q7 air suspension adaptation issues
- 21" Tire size?
- Injectors, Seals and Bolts
- Battery re-code clarification?
- Q7 Heatet Seats
- q7, random shut downs
- Flippin' MMI
- Air Suspension Compressor Temperature Range
- Q7 TDi Long crank and white smoke after being stationary overnight
- Control Arms
- Malone Tuning 07' 3.6L / Worth it?
- How reliable is the 2013 q7 premium?
- Look for a dpf
- Air suspension issues
- Invoice Review for TDI Warranty Coverage
- Lost satellite radio
- Every Error Message Known
- Air compressor
- Engine Replacement (2015 - Q7 )
- 2007 Q7 code PO336
- Factory air tank location
- O2 sensor q7 2007
- Side mirror light bulb replacement?
- Looking at a 2014 Q7 Prestige 3.0TFSI
- An Bluetooth experts?
- AUDI Q7 2019 3.0 vibration at 900 rpm
- How much to add factory hitch?
- Value of Q7 after rebuild
- Air suspension VCDS lowering ?
- Audi Q7 4L 12v Switched/Ignition options
- VW Indicator Fluid same as Audi?
- Starting problem
- Eventual replacement of 2011 S Line Q7 should I buy another MKI or upgrade to MKII?
- UK: Audi Q7 S-line 63 plate.
- Intake manifold leak on 2007 Q7 3.6L
- Halogen to bixenon
- Audi q7 2007 4.2tdi coolant leak
- 2013 q7 tdi engine coolant temp sensor 3 located ?
- Need help to replace AC line with many pinhole leaks
- Red Coolant light
- Winter wheels/tires question
- Looking for a Q7 TDI Diesel gas cap
- 2012 Q7 TDI Maintenance
- Rear rotor extra recessed bolt needed?
- 2013 Q7 S-line drone/
- Labels for Q7 HVAC measuring blocks
- 2015 Q7 reprogram spare key
- Getting ahead of the timing chain noise
- Q7 rear drive shaft removal
- Mobile app
- Front seat compatablility
- Wet floor mats
- Audi Specialist in Chicago?
- Front camera replacement
- Tire size?
- Audi Q7 2013 MMI problem
- Wanted new.SQ7
- Help! Both passenger and driver front seats will not move:(
- Help!: Camshaft position sensor locations/replacement (2012 Q7 3.0L V6)
- ZA: BUG cranking no start
- Steering lock problem HELP!!
- 2014 Q7 TDI - Rear tail light, turn directional, brake light alert but it's working?
- 2012 TDI delete
- I need to find or where can I get Audi Q7 sport edition left doors lower molding
- starter motor connector removal help
- Transmission Re-Learn?
- 2022 Q7 lane assist, cruise control not working and not under warranty?
- Need some parts
- CheaP Air suspension pump will it work?
- my take on timing chain rattle
- Tire rotation pattern?
- need location of heater core inlet/outlet hoses to backflush my heater core!! please
- HELP Car wont crank
- 2021 Audi SQ7 Consumption green battery regenerating battery
- MMI problems since re-installing Sirius receiver
- battery registration
- Fumoto oil drain install question
- How difficult is it to tap into the reverse lights?
- TDI Fans – I got $76,098.73 for my 2015 A6 TDI with 146,179 miles
- New Guy Post: 2015 S-Line SP Exclusive Velvet Purple we call GrpeApe
- drivers window
- Mystery vibration is driving me crazy trying to diagnose
- No more oil burn 15 Q7 Sport S Line
- Replace halogen turn signal bar under headlights with LEDs?
- 2014 Q7 3.0 S/C Oil Change question
- Wiring nightmare. Expert advice needed
- Q7 4.2 TDI Engine ticking noise
- 13 q7 TDI "unprogrammed key" stuck in ignition. is it immobilizer?
- Damn?
- new key stuck in ignition? 2013 q7
- Air suspension
- Steering wheel noise
- check engine light one
- Diesel fuel additive
- AC stopped, VCDS logs
- New owner Q7 TDI questions
- Q7 vs. MDX Type S
- 2006 AUDI Q7 - Car hard to start and now blowing white smoke when accelerating
- High mileage purchase on 2017 Q7 Prestige
- Quattro is a God given gift to man
- Q7 Back of Front Seats Coming off?
- Mmi replacement???
- New Audi owner - Confused on diesel emmssions fix warranty
- How common is a failed oil cooler on the 3.0T Q7?
- 2017 Q7 part shortages
- 2013 q7 tdi coolant alternatives EGR cooler
- KR: First post, help me, what's happening with my diesel engine right now?
- Front suspension bottomed out!!
- Passenger AC not cold
- A/C Compressor
- Fuse sizes
- 2014 Q7 P0068 error message
- ROSS-TECH UPGRADES/DISCOUNTS AVAILABLE
- Service lift recommendations
- Anyone replace / fix door handle?
- 2013 Q7 TDI Leaking oil near turbo?
- Does Q7 have any Trailer Sway Control Software included in Tow package?
- Disable Stop Start Audi Q7 2011 model?
- Abnormal starting behavior
- UK: 2006 3.0 diesel Q7 acceleration issues
- 2012 Q7 TDI: 38161 - Reductant Metering Module P20FE 00 [101] - Malfunction
- UK: What to clean after turbo failure?
- Aftermarket eXtended warranty coverage
- Anyone here running a JHM ECU/TCU tune?
- Recommendations for code reader or diagnostic tool
- 2011 3.0 TDIB throttle response
- Removing chrome door inserts
- Does my vehicle have slow close/ closing aid on the doors?
- ⚠️ Tire / Tyre Extinguishers ⚠️
- UK: Jerry cans?
- Weird light staying on
- Belt tensioner failure
- Trailer Control Electrical Issues
- Dr. ColorChip - not matching Daytona Gray Pearl
- Cerakote Ceramic Headlight Restorer
- AU: reverse camera?
- New Battery Coding
- LED light intermitently stays on
- Q7 ABS Sensor
- Tires? which ones?
- New Engine or I'm not?
- UK: Grossdach Rollo fuse keeps blowing
- 2022 Q7 Phone Box Alternative
- Suspension spring conversion
- Modified Hitch
- Adblue cap?
- Chrome window trim removal
- Oem vs. Aftermarket Windshield
- q7 4L OEM bluetooth and NAV retrofit
- Error code?? Diagnostic Trouble Code
- 2011 vs 2013 TDI engine
- 2017 lane assit calibration
- Strong DEF (ammonia) smell at start in morning
- Chip tuning to improve fuel economy for 2007 Q7 4.2 Premium?
- 2011 music streaming?
- 2011 Q7 passenger wiper not touching
- 2015 Q7 squealing from presumed to be rear of car/ not engine
- 2011 Q7 radio/MMI stay on when car off
- 2011 Q7 TDI - Fluid Specs
- CA: Low Tire Warning, 2014 Q7
- Q7 lease buy out option
- Insert Key, sometimes no unlock sound heard
- Adblue mileage?
- Need more light!
- 2017 Q7 3.0 Check Engine Light
- 2011 Q7 P+ auto fold mirrors?
- hitched installed
- oil sensor?
- Brake Controller installation
- 2010 Q7 Door problem
- Adaptive (or active?) Cruise Control - wrong coding
- Rear hatch sun shade
- Rear hatch?
- OBD2 VCDS/VAG APP
- CL: Drum noise when turning left audi Q7 2021
- Trunk liner
- Some asking for 2013 Q7, thanks.
- New Battery And Engine Light
- ABS TPMS Question
- Help with am/fm static noise
- Extended Warranty for a 2018 Q7
- AU: Oil leak repair cost is a Joke,on you AUDI!
- Help with fault codes
- Generic red 'Long Life' coolant was used in my 3.0T, should I flush it?
- Used car valuation?
- Hello!
- How often do you change your drivetrain fluids?
- AU: Where's this bloody oil coming from
- DK: Q7 (4L) / 2007 - 22 inch tire - Doubt, what should the pressure be?
- One wiper stopped working, linkage issue?
- 2009 Q7 vacuum hose part no.
- R j ?
- 2013 Q7 S-Line - Blinking Headlights
- 2012 No power to MMI at all
- 2012 3.0 TSFI Q7 Cracked cylinder head
- Bosch Ignition Coil Rubber Sleeve Broke
- hpfp location
- Q7 2008 with xenon headlights- doesn't work
- Cargo cover 2014 Q7
- Ceramic coating cost?
- Installed new side mirror switch, mirrors still won't adjust
- Shift knob install - how to properly tighten replacement clamp?
- CN: Audi Q7 diesel gearbox replacement
- Tire swap to buy a few months
- Anyone from Central Ohio? - Recommend a repair shop
- UK: Q7 no breaks after multiple repairs to brakes
- Ambient Lighting
- GAS IN MY DIESEL/ GAS STATION IN THE WRONG
- CB Radio mounting and armrest/console disassembly?
- Hood stuck won’t open!
- 2014 Q7 TDI - diesel fuel odor in garage
- 2007 immobilizer location?
- Dash separation fix?
- AU: Low fuel rail pressure
- Audi Q7 ambient lighting
- AT&T wi-fi expired?
- 07' 3.6L 0AT Pan off transmission fluid/filter change
