PDA
View Full Version : Q7 MK 1 Discussion
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Q7 TDI Filters
  2. Tourist headlight setting
  3. Anyone with a 3.6L and the APR ECU tune? Or other engines as well...
  4. 2011 TDI Prestige 76.8K Miles, thoughts?
  5. Digital Climate Control Retrofit
  6. blower motor stops working
  7. Rack rack and pinion replacement
  8. 2012 Q7 Air Suspension Compressor Not Running....and more!
  9. SQ7 Exhaust too quiet?
  10. 2015 TDI intake manifold removal question.
  11. 2020 Climate control screen black but working
  12. Q7 longer start time
  13. Q7 Start stop disable
  14. Thoughts on buying a formerly repossessed Q7?
  15. Re-flash and S/C pulley
  16. 2017 Q7 Premium Plus 3.0T
  17. 2021 Q7 Wheel Bearing
  18. 4L aftermarket amp/sub installs: couple questions
  19. Adaptive Headlight Defective
  20. Replacing ABS Control Module - the Engine ECU is in the way!!!
  21. Q7 Tailgate issue
  22. Lower Door Cladding Removal
  23. Strange new issue
  24. Slow air leak detection?
  25. Hi, will 265/60/18 fit my 2015 Q7 tdi on stock 18" OEM wheels?
  26. 2011 Audi Q7 TDI Diesel Injector Overspray - Computer Question
  27. Diesel Particulate Filter
  28. $L front carrier service position: anyone have a how-to?
  29. Adblue Fault No Restart
  30. Silly things online vendors make us do...
  31. Tire size
  32. 2010 Q7 3.6 AC Expansion Valve Location
  33. EGR Valve fault...Coincidence, or not...
  34. 2010 Q7 TDI Intermittent stalls and rough idle (and more!)
  35. Seat belt not retracting
  36. 2007 Q7 Nightmare car
  37. 2013 Q7; radio module locations...?
  38. diesel?
  39. Water pump leaking - TDI
  40. 2007 Q7 light wiring
  41. Unknown Noise
  42. Kumho Crugen tires
  43. UK: Desperate, diesel
  44. Turned on for 2 mins. Then turns itself off.
  45. SQ7 rent for payment
  46. erWin for Audi?
  47. Silly question abt heads up display
  48. cylinder # 2 pressure sensor high
  49. Fuel filter on TDI
  50. Please help air suspension calibration
  51. Broke down in NC
  52. Should You Replace the Valve Block Whenever the Suspension Compressor is Replaced?
  53. Hey Audi recognition reset
  54. Need some help
  55. $500 Q7
  56. 2011 TDI Engine codes
  57. Difference in fuel filter PN's
  58. Side assist not working after battery dead.
  59. part #s for ventilated front seat covers?
  60. Rear quarter window seal
  61. Q7 Manual Transmission Swap [3.0TFSI]?
  62. Audi Q7 ABS Light On - Faults Codes 00814, 00283 etc - PLEASE HELP!
  63. 3.0 TDI CATA Emissions Hard Parts Delete List
  64. Purchasing a used 2011 q7 TDI in 2023?
  65. AUDI Q7 TDI 3.0L CNG Conversion
  66. Phantom headlight switch?
  67. Greetings from SuperSprint Italy
  68. Audi Q7 rear windshield wire
  69. 698 miles. 10 hrs 30 minutes incl stops.
  70. Rear Cargo cover and tire well tray
  71. MY13 interior creaks and rattles
  72. Windshield fog?
  73. Need help setting Time on 4.2L BAR
  74. Good grief
  75. P0087 code left me stranded
  76. Stiff # hard steering
  77. Replace Spark Plugs On Q7 3.6L
  78. 2010 TDI Glow plug light and DPF light
  79. VCDS Service intervuls
  80. change cruise intervals using vcds/vag com
  81. Rear Entertainment System
  82. 2010 Audi Q7 3.6 67K miles Suspension groan creaking when hot
  83. cargo net part number
  84. Warning 2010 ECM under window cowl passenger side
  85. 21” Wheels?
  86. Water in footwells
  87. Today's Task: Replace both headlight Lenses on my 4L Q7
  88. 2010 Q7 Windshield cowl passenger side
  89. 2010 Q7 Rear Bumper Tow hitch cover
  90. 2010 Q7 TDI Alarm Siren replacement
  91. 2013 Audi Q7 3.0L V6 gas - trans cooler inlet pipe leak
  92. Question for anyone who has replaced their timing chain tensioners
  93. Electronics going crazy
  94. new brakes and rubber
  95. 2013 Q7 TDI sag with towing
  96. Analog speedometer reading too high
  97. Selling my Q7 diesel, what do I list it for?
  98. <2012 TDI Intake Air Temperature Logs?
  99. Ad blu fault no restart 200 miles
  100. EE: Audi Q7 3.0L TDI 2013 engine knocking/ticking
  101. Push start and touch door sensors not working
  102. 2007 Q7 S-Line 22" Wheels?
  103. 2023 Q7 MPG concerns under 1k miles
  104. 2015 Q7 S-Line 21” Wheel Spec Dimensions
  105. Quick Tip - CarPlay device install - wiring
  106. Need help with xenon bulbs
  107. TDI DEF Reductant Tank Cap Switch
  108. Isolation and removal of units (Lane + Cruise)
  109. Coolant Tank Empty After Repair by Dealership
  110. It rained in my 2007 Audi Q7[left sunroof open]
  111. Audi won’t turn on
  112. 07 Audi Q7 air recharge
  113. Unusual warning light - preheating failure
  114. TDI extended warranty: would something requiring a smoke test likely be covered?
  115. 4L Q7 Prestige - camera & parking sensor issues
  116. Audi Q7 2014 - Someone broken into my Glove box and broke the components
  117. 2017 Q7 PP Transmission problems
  118. MMI Issue - Need help physically finding the radio control module.
  119. Q7 2008 V8 Issues
  120. Q7 headlight issues
  121. Coding Break Lights Off when Blinker is Activated
  122. Q7 wheel hubs - 5x130 vs 5x112... swap?
  123. Liqui Moly
  124. Buying a 2013 Q7, what should i know?
  125. Backup camera new module
  126. 2nd row seat fastener cap/frame fell off
  127. Need Help! CEL, P307A & P0068 codes
  128. What is the TPMS antenna connected to?
  129. Looking for Indy Mechanic VW/Audi West Hollywood
  130. 2015 Q7 driver's seat back panel fell off
  131. TDI 507 spec oil viscosity
  132. Help replacing B-pillar exterior trim
  133. Unimpressed w/ 2019 Q7
  134. 4L 3.0T "Low Oil Pressure" alert
  135. Q7 towbar
  136. UK: Boot not opening properly
  137. UK: Air suspension - VCDS lowering - Question before committing
  138. Malone/Tunezilla TCU tune
  139. Q7 TDi exhaust smell in the cabin
  140. Is it possible to adjust the rear wiper position when not using?
  141. Stiff power steering
  142. Issue with back up camera
  143. 2013 Q7 TDI "Bent connecting rod"
  144. Amplifier Fuse keeps blowing
  145. Q7 TDI in this issue of Quattro Quarterly
  146. 2023 Audi Q7 2nd Row Legroom
  147. 2019 Q7. Body vibration/shaking @High torque mode
  148. Q7 vs Touareg, technical / mechanical differences?
  149. 2014 3.0T Headlight replaced, still not working
  150. Audi tdi egr and Def system
  151. 2010 3.6 Q7 Power Steering Leak
  152. 2010 AUDI 3.6 Q7 Oil leak stops when Hot
  153. TDI Warranty Experience Question
  154. 2010 Audi Q7 3.6 67K miles Suspension groan creaking when hot
  155. Fitting Air struts in place of the coils..
  156. Seat height adjustment not working
  157. Side mirror auto retract - Q7
  158. Trying to do a map update, but end up audio currently unavailable
  159. 09 Q7. S-Line 3.0TDi HPFP replacement
  160. Coolant leak - $1900 quote
  161. Rear Spoiler and or diffusers - Q7 2018
  162. UK: Anyone local to Liverpool, UK and has access to VCDS
  163. 2011 Q7 Air Suspension Light
  164. A 2nd bad PCV?
  165. Is a 2012 door and 2015 door the same?
  166. UK: 3.0L diesel power steering cooler/rad?
  167. Water pump replacement for 2014 audi q7 - additional parts
  168. Clicking noise when closing automatic boot
  169. Particulate filter warning light
  170. cyl no. 2
  171. Reverse camera trailer icon
  172. RocEuro Intake - Gen 2 for 2018 Q7
  173. 2018 Q7 - LED Emblem
  174. Tailghts don't work, but brake lights do.
  175. 2010 Audi Q7 Engine Bay Tubing
  176. EGR Vacuum Solenoid issue
  177. 2009 Q7 - Swapped Bose Amp but now right side and subwoofer not working
  178. Drivers seat controls and memory not working
  179. Audi Q7 won't start - possible J518?
  180. Q7 had blown ECM circuit relay still won't start sometimes
  181. Electrical drain - possible MMI issues?
  182. Q7 Cruise Control not working
  183. Power disconnect on front passenger door female side of harness
  184. Cause and effect?
  185. Headlight Projector Lens Upgrade?
  186. Where's dreadlocks?
  187. Advice, Please: Cracked Transfer Case on 2011 Q7 TDI
  188. Cannot enter modules
  189. Overheating issue
  190. Oldest Q7 tdi on here/mileage?
  191. Q7 3.0 tfsi Cooling issue
  192. The RPM going up and down
  193. Fuel filter/water separator
  194. 2013 Audi Q7 snow tires
  195. 18' Audi A6 wheels on Q7
  196. Been Playing In The Green Menu? Problems Have You?
  197. 2014 Audi Q7 windshield replacement
  198. Custom badges
  199. Water in Spare Tire Well. What amount is acceptable?
  200. Can you improve the hands free bluetooth phone sound quality
  201. Does VCDS identify which tpms sensor has malfunctioned?
  202. Decision - repair or trade in
  203. Interchanging Q7’s Battery Management Module with that of A4
  204. 2014 Q7 S-Line MMI
  205. 275/45/20 to 285/50/20
  206. Crankshaft position sensor location
  207. Brake pad recommendations
  208. FR: Q7 3.0 TFSI ENGINE NOISE?
  209. Audi Q7 2022 Front Grille
  210. Brake Controller on 15' TDI not working, what are these dash warnings for?
  211. UK: 2014 4L Q7 - Headlight Question
  212. q7 alternator
  213. Why I love my first gen Q7
  214. Code 01780
  215. 2013 Q7 MMI not turning on.
  216. Q7 Check engine light & message
  217. It is finished...
  218. 2019 seat heating element broken
  219. What to look for
  220. Mystery Hose
  221. CL: ECU Stolen
  222. Audi Q7 Sline 4.2L Gear Oil Changing
  223. Wet rear passenger side footwell
  224. 2015 3.0T - Coolant Smell With No Leaks?
  225. "Repaired" Bose amp not working? I'm lost...
  226. Bilstein Touring Shocks/Struts + H&R Lowering Springs = Nice
  227. No option to reset service alert for oil change...
  228. Add reversing lights delay
  229. Towing w/o air suspension
  230. 2013 q7 sunroof noise
  231. As if you didn't know already 😁
  232. 2012 Q7 TDI - DEF Countdown - What Should I Do?
  233. Winter tire options 275/65/18
  234. CN: About Audi q7 4.2 tdi s line transmission ratio problem
  235. Does Nox sensor 059907807H supersede 059907807E?
  236. OEM load rating of wheels?
  237. UK: My first ever Audi and its broken within first month. Please advise
  238. Any ideas on how to "waterproof" the Bose Amplifier?
  239. Boost Pressure Sensor or ECM Fault ?
  240. Liqui Moly Engine Flush
  241. Air condition problem
  242. Torching caliper pad carrier bolts to break them free?
  243. Radio receiver issue
  244. How do I convince my wife I need a SQ7?
  245. 2014 Q7 Navigation
  246. Car won’t start
  247. Having this rattle noise on gas pedal release, any ideas?
  248. 2013 q7 tdi glow plug issue
  249. 2009 Wipers turns on when switch is off and no winter park below 0 Celsius
  250. Audi Self Study Program. TDI. Oil extraction not permitted?
