View Full Version : Q7 MK 1 Discussion
- HVAC issue on 2015 Q7
- 2008 Q7 P0322 Engine Speed Sensor Replaced but Won't Start
- Sudden P203B00 code and DEF tank still full after replacing cap
- Rack replacement
- Change oil change interval to 5,000 miles?
- Replaced steering rack now have 00778 code
- Reducing Agent System - delete
- Please help Door handle removal
- brakes issue
- 3.0 TDI - timing chain condition
- Harmonic balancer/crank pulley replacement.
- Front end swap 2008
- 2012 3.0 TDI 4L Cooling issues
- Rear Camera Module
- Has my brand new starter motor kicked the bucket?
- Trailer battery charging
- 2014 TDI - Glowplug light - Engine Light
- AC issue
- A/C issue
- Aftermarket AFS Headlight Modules from China
- JB?
- fis-contol adapter for MMI
- Camshaft positioning sensor relearn.
- Rear tail light wiring?
- AUDI Q7 2007 3.0 TDI , no connection to ECU or OBD, slow crank.
- Convenience close? The roof?
- Anyone Needing New Struts / Shocks?
- 2007 Q7 3.6 FSI V6 EVAP code P0441
- Can I have the trunk / cargo dimensions for the 4L
- Right Rear Door Control Module
- PLEASE HELP - Air Bag Light
- Rebuild Door handles
- regen
- How's Your DEF Tank Hanging?
- 2023 Q7 w/v6 gas mileage drop
- AUDI PARTS?
- Car covers
- Help pls -- Adaptive Light Failure
- Q7 randomly makes an air release or popping noises when parked
- Smelly tdi
- Audi Q7 Trunk and Gas Lid
- NOx Sensor 1 Bank 1 Electrical Malfunction
- Engine harness connector identification
- Catastrophic driveshaft failure. What related parts need to be replaced?
- Is this piece correct? Please help
- MMI not working
- brake issue
- 2019 Q7 Steering Malfunction
- High-mileage thorough service
- 2014 Q7 3.0 tensioner pulley broke
- Control Arms Clearance for early Q7s @ FCP Euro
- 2015 Q7 TDI feedback
- How Old Are Your Belt Idlers & Tensioner? Belt(s)?
- 2015 Q7 3.0 175,000 miles oil loss
- Transmission failure and replacement (photos) ✨
- no pressure in cooling tank
- TDI puffing white smoke in engine compartment
- Headlights
- 2014 TDI - Coolant in the Valley
- Key issue
- audi q7 2010 after engine change the car will not drive even after shifting into gear
- Locked out
- Trailer hitch pre-wiring?
- Coolant Leak
- Rear hatch open warning light
- A/C won’t turn on
- No heat but AC works
- Q7 Rattling back sunroof
- Advice on wing mirror disassembly (Spring loaded retaining clip)
- Replacing Brake Master Cylinder on 2010 Audi Q7 3.0 TDI RHD
- Parting a 2013 Q7. What's important and what not?
- Sunroof/Moonroof? Latch
- FR: Annoying sounds in habitacle
- Powertrain Warranty ends next month -- what to check?
- Got a starting, charging or electrical issue? Basic checks.
- Cycle TDI fuel pump without VCDS?
- NO: Battery for Audi Q7. HELP!
- Oops! Dropped copper injector seal ring into valve compartment
- Please help?
- Struggle to start
- ESC and TPMS Lights - Clear on Restart
- Supplemental heater fan won’t shut off
- mmi black screen
- Auto tailgate slams closed
- Question about bi-xenon headlight upgrade
- Differential Oil
- 2009 q7 injectors n seals keep blowing
- Got Timing Chain Stretch --- VCDS Can Provide Related Measurements!
- For Audi MMI 2G A4 A5 A6 A7 A8 Q5 Q7 2005-2010
- Bit off more than I can chew with intake
- 2018 Q7 Child lock malfunction
- 01217 - Side Airbag Igniter; Driver Side (N199) 001
- After ABS module replacement no crank anymore
- 2012 Audi Q7 hvac
- Audi Q7 3.0 TDI 2013 engine knocking sound
- small shake when heavy braking
- FCP Euro Replacement Headlights?
- 2012 Q7 headlights LED conversion
- Crank/No Start After Fuel Pump Replacement
- Honeycomb Fogs and Under Turn Signal Grilles
- Source for Wiring Diagrams?
- MMI Module malfunction
- 2014 TDI brake fluid change procedure
- High pitched squeal after changing HPFP
- "Theoretical" question about tire sizing...
- Where do you buy gas daily?
- High mileage — how can I keep it running?
- Replace/fill in front US license plate bracket
- Air-conditioning system not releasing cold air
- Accidentally pulled out axle from front differential.
- Baffled with Particulate matter sensor location
- Adaptive air suspension retrofit?
- Need help please -- 2013 TDI battery
- Water ingress from unknown source?
- Rebuilt VR6 issues
- Porsche macan wheels on my 2009 q7
- Audi Q7 running boards
- 08 Q7 Won’t start
- Cleaning sensors, replace DEF Pressure Sensor help
- Recs for miscellaneous upgrades— 3.0tfsi
- Q7 Faults in VCDS
- Main Speaker replacement instructions?
- Glow plugs and Nox sensors, related codes?
- Bluetooth
- Headlights cut-out when not in auto-mode
- Green Air Light and Front Wheel is Lower Than Normal
- 2011 Q7 not turning over
- Options?? Mmi/apple play
- Subwoofer adjustment
- Battery Diagnostics
- Bluetooth initializing setup screen
- Lift or lower? That is the question...
- VCDS advice
- Audi Electronic Fuel Latch and Electronic Trunk Issue
- Headlight Replacement
- Short to positive after sensor replacement
- Bumper light out
- 2014 Audi Q7 No crank No start transmission stuck in park
- 17277 - SCR NOx Catalyst Bank 1 - Back to the dealer
- Anyone tried the eBay or Alibaba parking cameras?
- Codes after performing oil cooler/egr work
- Looking for a motor
- How's your A/C Cooling?
- new gear shift cover
- 2018 Audi Q7 Prestige Excessive Oil Consumption
- Changing starter 2007 Audi q7 please help
- Quart of cranberry juice in my 2014 Audi Q7 Supercharger antifreeze tank.
- Bluetooth issue 🤯🤯
- Help with Battery Adapatation
- Change driveshaft, neutral or parking mode?
- 2010 Q7 3.0L TDI/CATA replacement wiring harness routing
- Replace Right Side Mirror Motor Refurbished
- Transmission wiring issues
- GEN1 Oil Cooler FIX
- 3.0 tfsi muffler/exhaust options
- Injector washer failing multiple times
- Need help identifying cracked hose (part number and replacement)
- Suspension issue
- Another Q7 Battery Drain Question
- Can't seem to find standard amplifier
- 2013 Audi Q7 seat swap 2nd row
- H9 Everstart Platinum BEM code
- SQ5 Coolant Leak - so how does this connecter separate?
- Sensor issues
- MMI DAB retrofit?
- Part number for MMI screen
- Android Touch Screen For Audi Q7 200-2015 | Apple Carplay & Android Auto
- Adding a Push to start on a 2011 Q7
- Bodykit Dilema
- Coding the mmi unit
- '14 Headlight Adjustment
- Spark plug and ignition coil replacement isuses in the 3.0T
- Does this engine sound healthy?
- 2007 Audi Q7 trouble code: transmision friction element
- Dumb question? Headliner mounting holes...
- '14 Q7 3.0T Acceleration Issue
- Found my coolant leak
- ‘12 Q7 TDI rear cv shaft removal
- Which Q7 would you buy?
- Tuning Options For Gas & Diesel Engines
- 2015 tdi q7 on BaT
- Battery Is draining
- Both, NO Hight Beam Bi-xeno. PLEASE
- Wheels for my 2015?
- open gas flap when engine running : Have I lost my mind?
- Deleting EGR and DPF
- Humidity Sensor-G355
- Audi q7 problem with start engine
- Using 3.0t for Towing and Recovery?
- Hard steering
- Q7 TDi Engine Replacement - Harness
- Drive shaft removal
- Upgraded transmission 8HP70
- Hard start parasite continues......
- Zero Compression #5 only
- transmission jerking
- How to move seat with dead battery?
- Audi traffic recorder
- Interesting News Article; 3.0T Engine Failures in the 4M Q7 (and other models)
- B&O Woofer Refoaming Help?
- Audi Q7 3.0 TDI error code 05663
- Power seat adjustment fuse location
- 2013 OEM Tow Package DIY Q7
- MMI screen stopped working
- Injector Cleaners That Work
- Power seat adjustment dead
- Q7 transmission adaptation
- Adblue problems
- Gas 2015, low oil pressure light
- ZA: VCDS, Where to buy?
- Speed limit sign recognition
- CAN, MMI, Sun Roof, Headlights, all OFFLINE. Best experienced men are welcome.
- Does an ‘07 Q7 steering rack fit on a 2011 Q7?
- High Pressure Fuel Pump Failure (HPFP)
- Emissions System Failures Post-TDI Modification – VW Audi Porsche
- Reset tpms with min not functioning?
- Scoring in cylinders. How did that happen?
- Cracked front interior door cards on 2015 Prem+
- 2015 q7 TDI battery and sound problems
- MMI lights blink on hard rev
- Rocker Moldings
- battery coding issues
- Restricted performance when revving past 2500rpm
- Audi enthusiest/tech in NC
- Chasing hard thump in rear
- Massive leak + prevent maintenance?
- Central Locking Query
- Interior trim rear molding question
- 2014 Q7 TDI Heater Core Flush
- First time in 12+ years. There’s no Q7 in the garage.
- Q7 rear boot actuator
- Fumoto Oil Drain valve for Q7 3.0 TDI?
- TDI Back in for a leaking timing cover / upper oil pan gasket
- ZA: Central Locking issue? 2009 q7
- Amp Failure?
- Better wheel/tire setup for more off-road capability
- Posable turbocharger problems
- EGR valve stuck open
- 2009 Audi Q7 3.6L - Not cranking
- 2014 Q7 TDI DEF Leaking
- Q7 MMI (3G High) HDD died
- FIX or DITCH my Q7 diesel? Need Advice
- wiper fluid frozen
- Replacing PCV - what else to replace CTWA 3.0T
- Not obvious (to me) buttons for play/pause and phone
- APR Stage 1 ECU tune for 3.0T gas (2015)
- LK: Audi starting once in a while
- Weird Alarm Going Off
- Vcds "Interface not found"
