PDA
View Full Version : Q7 MK 1 Discussion
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65
  1. Should I buy 2015 Q7?
  2. 2018 Audi Q7 check engine light Engine start System Malfunction
  3. CEL-Fault 4871-Exhaust Gas Recirculation Cooling Valve Control
  4. 2012 Q7 3.0L Cylinder Compression Lost and Engine Rebuild Prognosis
  5. 2013 q7 key fob not working
  6. Just sharing
  7. Towing?
  8. UK: Battery issue? Deeper issue? Jump start evver
  9. Wipers out of place after wiper motor replacement
  10. G2 caliper paint kit
  11. Side mirror struck, body shop says need to replace door
  12. map lights
  13. Aileo LED headlamps vs. Sylvania Xenarc cool blue xenon HID
  14. EPC code P2138
  15. Auto HVAC dtc?
  16. Audi Q7 3.0 TDI, NO CRANK and FAN turns on
  17. Wheel bearing kit question
  18. Crank but no start.
  19. Need advice on a 2010 Q7 TDI 3.0 w/ 126K miles
  20. AU: Glow Plug Diagnosis
  21. 3.0L TDI extended emissions warranty
  22. 2012 q7 prestige not starting
  23. Who is the OEM Ignition coil manufacturer?
  24. Trunk weatherstripping replacement - use sealant?
  25. 2013 Audi Q7 3.0T (Gas) vibrates badly when in reverse
  26. 2013 Q7 ignition or acc wire in trunk
  27. Coolant leak front of motor
  28. Stalling and no start
  29. UK: That damn limp mode esp adaptive lights suspension oil gearbox diesel problem
  30. Trouble Code P040B - Ex. Gas Temp Implausible signal
  31. "Typical" engine oil consumption as the engine gets older? (3.0T gas)
  32. Removing Rear bumper on 2013 Q7?
  33. SE: Air suspension Audi q7 4l
  34. 2011 Q7 TDI Electrical Issue - Battery?
  35. Lower left light in rear bumper cover
  36. P0016 P0018 Error. OBD Timing value read out
  37. AUXILIARY water pump (supercharger cooling)
  38. 2013 Q7 Timing chain/Camshaft Angle
  39. 2022 Q7 Woodpecker type noise from fuel tank
  40. O-Ring for EGR, item #10 in diagram, what is part #?
  41. JHM vs APR vs Malone/Tunezilla for ECU and/or TCU tune
  42. rear side window , seal / kit replacement
  43. Good things come from Lithuania
  44. Ready to reassemble - gaskets & seals, when it it clean enough?
  45. 3.0 TFSI Belts
  46. TDI Coolant Leak from Oil Cooler / EGR - Owner Repair Stories
  47. 3.0 TDI Intake Removal - all bolts out - not budging?
  48. How to unclip this electrical connector?
  49. Carbon Canister / Vapor Purge Valve
  50. Unplugged Mystery Cable
  51. Possible condensation coming from tailgate window seal?
  52. 2016 Q7 Wheels on 2013 Q7?
  53. 2017 Audi Q7
  54. Cheap plate holder option?
  55. Q7 TPMS sensor location with air suspension?
  56. Oil on front of motor
  57. Timing chain
  58. Coolant Leak front of Engine w/Pics
  59. 2014 Q7 shutting down after ignition
  60. Aftermarket front camera
  61. Steering wheel heat problem
  62. 2014 Q7 windshield fluid reservoir sensor
  63. 2014 Q7 tire wear
  64. Need help with MMI3g update
  65. Intermittent misfire when it rains?
  66. Aircon 02874
  67. Battery Regulator Malfunction?
  68. 2007 Q7 MMI speaker pops, now no volume, cd on pause, radio on mute?
  69. Just adding my saga story - Engine Replacement
  70. Alternate TDI engine oil?
  71. Mmi not Turning on
  72. TDI Tune & Delete - How To / Steps to Complete?
  73. 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
  74. 2013 3 litre TDI injector issues
  75. Add fog lights v12 bumper
  76. MMI screen
  77. Noisy fan in disc player 2015 Q7 TDI Premium
  78. Longevity question
  79. satellite radio question
  80. Let’s talk Headlights!!
  81. How to Disconnect Center Vent Connector?
  82. Upgrading Q7 TDi springs with Cayenne
  83. Q7 CEL error
  84. Adblue Problems
  85. ESC & TPMS error. Car will not go into gear?
  86. Leaking sunroof
  87. Swap of black gloss front grill pate holder with filler (4L0807287T94)
  88. Q7 Wrong rear lid current position after replacing J605 motor
  89. Anyone from the tri-state area (Ohio, Kentucky, Indiana) Shop Recommendations
  90. Rough shifting on 2018 Q7
  91. Navigation Feature Shuts Down
  92. Cool wiper feature
  93. AdBlue leak at wheel well
  94. 2018 Audi Q7 Rear exhaust leak.muffler shop not able to weld
  95. Fan timer switch install
  96. Recall on Recall? Q7 4L Fuel flange / Filter leak - Butyl Goo gone wild - 20W9 / 20BJ
  97. 2013 Q7 3L TDI Removal Procedure?
  98. Merry Christmas and a Happy New Year!
  99. 2013 TDI Cold issues
  100. has anyone reduced oil consumption with an engine flush?
  101. It's d@mn cold, and snowing here, time to test Quattro 🙃
  102. Can anyone help identify this engine leak? 3.0 TFSI
  103. Very rough running, no engine codes
  104. 2013 Q7 TDI - NOx Bank 1 Sensor 2 issue
  105. Does anyone know how to fix it?
  106. Adaptive Lighting - How can I tell if I have it?
  107. Battery recommended for diesel?
  108. 2013 power lift gate not opening fully
  109. diagram for brake booster lines
  110. Holiday lights at the race track freaked my car completely out!
  111. Headlight bulb replacement
  112. Audi Q7 Heating issue
  113. Q7 2014 sline plus Standard speaker upgrade.
  114. 2015 Q7 Steering intermittent failure!!
  115. CN: How to change the SMALL screen language?
  116. AU: oil leak 3.0 tdi 2011
  117. 4L MMI 3G+ (HN+) Nav maps update?
  118. Funny thing happened today at work.
  119. 2014 Q7 3.0 TDI no start
  120. New to me 13 Q7 S-Line Prestige - I gots questions
  121. 2014 Front Seat Harness.... Are your plugs female?
  122. Rear bumper lower tail light screw?
  123. 07 Q7 3.6 long crank only when sitting
  124. How to Remove 2007 Q7 Rear Trunk License Plate Light Lamp Pull Handle?
  125. DEF delete in GA
  126. Audi side assist: Sytem Fault Help Needed
  127. Check engine light on 07 Q7: Misfire all 6 cylinders? Need Help
  128. Mmi not working properly 2006 q7
  129. 2013 Q7 Exhaust Tip Rotated
  130. RAWTEK DPF/AdBlu/SCR DELETE INSTALL
  131. High pressure fuel pump
  132. Coolant temperature sensor
  133. 2010 Audi Q7 MMI not working
  134. Ad Blue warning - 1k miles left - what's my play?
  135. Malone Tune and gas mileage data
  136. After market subwoofer
  137. hvac left side vent motor positioner
  138. TDI Dieselgate Warranty: Audi Towing Reinstated for 3yrs
  139. 2012 3.0TSFI oil leak from head gasket
  140. Hatch not opening from interior
  141. Q7 misfire
  142. Weird driving….in my head?
  143. Curious what others with the 3.0t (gas) in cold climates are using for engine heaters
  144. TDI Alternator
  145. Parking view camera / front and back sensors
  146. Low Oil Alert 2021 Q7
  147. What is length of propshaft(7L8521102H)?
  148. Low Temperature Gauge & Engine light
  149. 2007 Audi Q7 3.6 prem broken headlight connector
  150. Great deal on H&R lowering springs
  151. 13 Q7 diesel - 507.00 Oil?
  152. 2015 Audi Q7 - P2006
  153. Audi Q7 front license plate bracket removal
  154. TDI and Cold Weather help
  155. Audi side assist system fault 07' Q7
  156. VCDS hangs up
  157. Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
  158. Audi Q7 voltage vault
  159. AIR SUSPENSION: The Reality and Do's & Do Nots...A Learning Curve
  160. Weathertech Side Window Deflectors
  161. 2018 Q7 remote starter
  162. 2015 S-Line Q-7 Oil Separator
  163. 2014 q7 TDI P246F
  164. New to the euro world
  165. FYI TDI Guys: Malone TCU Tune Now Out
  166. Audi Q7 dashboard
  167. Map/Navigation updates 2015 Q7 TDI
  168. Convenience Lights Stay On
  169. Where is adblue cap
  170. Urgent Question: Overheating. 2015 TFSI.
  171. UK: 2007 Q7 Radio issue
  172. Will 2019 Q5 wheels fit 2022 Q7?
  173. My first Oil change on the 2013 Q7 TDI
  174. Q7 TDI fuel economy issues - VCDS root cause analysis...
  175. Q7 3.0 TFSI (Petrol) B8/8.5 2009~2011 Repair Manual
  176. 07 Q7 Start Issues
  177. 2011 TDI oil change interval
  178. Help with a part number
  179. 2022 Q7 Premium Plus interior lighting
  180. Audi Q7 2012 4L Air Suspension Pump Advice
  181. AU: HPFP CP4 leaking
  182. Default '15 Q7 Sline 3.0 Gas- hard start and transmission issue
  183. 2014 q7 anderson plug
  184. NO: Audi Q7 2010 3.0 TDI 70k.75mph/hills temp gauge shoots up limp mode stop and ok
  185. Audi Stop-start system - incline start
  186. 2009 Q7
  187. Optimal RPM for 3.0TDI?
  188. Weird noise when reversing??
  189. Q7 S-Line - Replaced a 2014 engine with 2013.
  190. a/c discharge hose
  191. Tailgate only opens 12"
  192. 2010 Q7 3.0 TDI problem starting
  193. 07 4.2 Q7 won't start on the first attempt
  194. 2012 Q7 TDI Adblue codes - Failure
  195. 2015 Audi Q7 Windshield Wiper Assembly
  196. 2017 Audi Q7
  197. A/c fan dying, where to get a good replacement?
  198. 2012 Q7 TDI: Fuel economy before/after delete and towing
  199. Engine Mounts Replacement
  200. New here :) IS OIL CHANGE MANDATORY ONLY WITH AUDI DEALERSHIP?
  201. Cost of diesel fuel - it's not "supply & demand"....
  202. Downsizing from 21" Peelers - Looking for pics and possible trades
  203. Passenger Wiper Base Cap/Air Deflector
  204. 2010 q7 Tdi code p0016
  205. ZA: Run flat tyres on non-runflat wheels
  206. UK: Audi q7 front wipers?
  207. 2011 TDI oil drain washer?
  208. 2018 Q7 full spec for $47,500 - good deal?
  209. AU: Fuel Injectors readings
  210. 2010 Audi Q7 Tdi loses prime at fuel filter
  211. Q7 TDI 2015 170k miles, dead?
  212. Low Fuel Rail Pressure 102K mi
  213. 4.2 FSI cat/downpipe removal?!
  214. AU: Possibly High pressure fuel pump
  215. 2017 Q7 cruise control traffic jam assist not working
  216. Burning oil like crazy
  217. Front / Rear camera install question
  218. Serpentine belt jumped off the tensioner!
  219. 2012 Q7 TDI - DEF/SCR Control Module Location?
  220. Remote Start on a TDI
  221. 2015 Q7 150,000 Mile Report
  222. License plate lights not working
  223. Wheel comparison, anyone have photoshop?
  224. 2015 Q7 TDI heater core replacement or?
  225. ADVICE BEFORE FITTING NEW 3.0TDI TO Q7
  226. Left headlight "dipped"?
  227. Transmission problem
  228. Anyone here with the 3.0T running JHM downpipes / HFC?
  229. Blower fan intermittent issue fixed
  230. Rear Brake Rumble 2021 Q7
  231. Question for those who have changed their transmission oil
  232. MX: Door locks going crazy
  233. Parking Brake Release Cable Failure
  234. Brake fluid brand recommendations
  235. WTB. Rear hitch cover 2014 S Line
  236. Dead battery - won't charge
  237. Cracking sound from under the car during hard turning
  238. UK: Suspension issue
  239. Audi Q7 Trip computer issue
  240. 2007 "sound system"
  241. 2015 3.0T oil leak - valve cover gasket at 95K miles?
  242. MY07 Q7 4.2 FSI Tension Roller Failure
  243. AU: Q7 diesel just stopped
  244. Infamous water around console
  245. Repair advice for grille and bumper
  246. Burning oil smell
  247. 2014 Q7 TDI - rear noise
  248. Q7 brake issue in wet slushy cold conditions
  249. 4L Q7 RS Style Grille Install w/ Adaptive Cruise and Front Camera
  250. Q7 2016. Gear not shifting to Parking. Need urgent help
