PDA
View Full Version : Audi A5 / S5 / RS5 Coupe & Cabrio (B8)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. B8.5 audi s5 misfire
  2. RO:New (to me) car, new problems
  3. A% Transmission Service
  4. Multifunction steering wheel buttons, illumination colour change
  5. AU: Audi a5 b8.5 mystery button?
  6. Audi S5 B8.5 ROW CREC engine rebuild
  7. 2.0 T 2011 A5 coupé Performance Upgrades
  8. 3.0 tdi no power
  9. Loud Whine Not SC
  10. Valve cover
  11. S5 Cab - rear heated seats?
  12. S5 K sport front calipers banjo bolt size
  13. Advice on purchasing a used B8 3.0L S5 cabrio
  14. Running Rich Bank 2
  15. What the heck is a MHEV
  16. Help! Lost radio signal ( impedance converter)
  17. UK: 2014 Audi B8.5 replace OEM reverse camera?
  18. HPFP Fuel leak ??
  19. UK: Audi dead? 3.0 diesel A5 quattro 2008 coupe
  20. Touch Screen For AUDI A5 S5 RS5 2008-2016 | Apple Carplay & Android Auto
  21. Inner tail light bulb(s) dead -do I have to buy entire assembly??
  22. Rs grill parking sensor problem
  23. LT: Engine splash guard part numbers?
  24. IT: Coding generic ambient lights
  25. Front Tires Strange Wear and Failure
  26. 3.2 v6 intake manifold question.
  27. Do Audi A5 B8.5 front and rear doors fit pre-fl (B8) ?
  28. Rear view mirror fell off (?) now phone calls muddy,
  29. Rattle noise at around 3000rpm b8.5 S5
  30. Rear camera bugged after staying in cold
  31. Headlight / Foglight Died at Same Time (Solved)
  32. For Audi A4 A5 2013-2015 Linux Car Radio Multimedia Touch Screen
  33. Centre Brake Light on A5 S-Line causing headache
  34. Intermittent Long crank time 2.0T FSI hard start
  35. No Crank or Start After Battery Change
  36. Passenger Cylinder Head Oil Leak
  37. Clutch and dmf problems
  38. Backup Camera activating in 3rd gear after Short Shift Install
  39. Audi jacking points?
  40. QA: White smoke from exhaust and droplets.
  41. S5 headlight range warning light
  42. pad longevity after notification?
  43. Sport Differential Failure
  44. Starter immobilization?
  45. Does anyone know this code pls: U13A900
  46. Obdeleven and vcds Backup options
  47. Car not cranking
  48. New Red Top coils, plugs, S shifting observation
  49. 2011 S5 cabriolet. Locating items.
  50. Help with Audi Adaptive Light: Defective Warning
  51. EPC light, stop start fault
  52. Supercharger kit for 4.2L fsi
  53. 2015 Audi A5 Cabriolet No air from any Vents
  54. Problem with A5 3.0.quattel
  55. Do OEM part kits come with instructions?
  56. Fitment question
  57. Cockpit view
  58. My s5 is having a starting issue I need help
  59. Needed wire harness info
  60. Auto headlights set "late" but still turns on early.
  61. Creaking rear suspension nearside
  62. Would you "un-bone stock" a '13 S5?
  63. "Lifetime" transmission oil
  64. Help! Leaking Intercooler Core
  65. 180 miles on a full tank in my s5
  66. UK: tuned and buggered
  67. "The Supercharged Audi 3.0T's Fatal Flaw" title says it all. You have issues and don'
  68. Garmin dashcam woes
  69. S5 apr stage 3+ 4.2L
  70. Audi S5 - Tickling noise while accelerating
  71. 3.0 tdi CAPA to CCWB problem
  72. Identify this part
  73. OEM Software version for Audi A5 2011 Cabriolet
  74. 2014 RS5 scanner advice
  75. 2010 A5 B8 Multiple Sensor Issues (Related?)
  76. Audi A5 2.7 tdi , 4332 - Check Coding of ECUs on Powertrain Data Bus P1647
  77. Automatic Radio?
  78. MMI Multimedia turns on and plays but no controls
  79. UK: Replacing cats?
  80. Memory seat + convenience buttons not working
  81. Trunk Subs
  82. Is bang and olufsen speaker plug and play ?
  83. 2009 A5 power steering loss
  84. B8.5 Coupe rear side speakers
  85. Air Tank Leak Fix Attempt – Stuck Fitting Removal Advice Needed
  86. Fob frequency change necessary
  87. Weird Knocking from the front left part of the engine bay
  88. B8.5 S5 Cabrio. Trunk lid mounted LED tail light no longer functions. Wiring issue
  89. intermittent no start. Cranks and eventually starts
  90. AU: Rs5 2013 engine dramas
  91. MMI head unit how to calibrate?
  92. B8.5 3.0t brake bleeder size ??
  93. 2024 S5 Cabrio remote top control stopped working
  94. 2010 3.0 tdi A5 brake goes to the floor only in some cases
  95. MMI Not working.
  96. A5 Cabrio - Looking DESPERATE for part number
  97. 2013 S5: HELPPP.... I'm Bricked
  98. Passenger (right) side door electrical issues
  99. Takes 6 or 7 Cranks more than normal to start.
  100. A5 needs new wheel brng. Brand and self help video suggestions appreciated.
  101. Whats wrong with my clutch?
  102. Question about Audi WiFi
  103. 2011 Audi S5 - No crank after minor accident
  104. Coolant change and purge with fill schwaben tool?
  105. 2009 S5 V8 Oil leak fro block casing hole
  106. 2013 Audi S5 3.0T Crank pulley wobble?
  107. 2011 S-tronic 0B5 Transmission Woes
  108. A5 B8 sportback and coupe rear bumper diffuser
  109. A5 B8 Cold Air Intake
  110. Trunk water leak
  111. Audi A5 B8 Front Bumper & Headlights
  112. Audi S5 b8.5
  113. Head Gasket issue? Audi S5 2012 3.0 TFSI
  114. UK A5 2.0 TDI 2018 B9 DETA with SVG stronic noob need advice
  115. Sat Nav Latest Update
  116. Seatbelt presenter fuse
  117. The A5 Cab is dead after 2024
  118. 2009 Audi a5 p0305 code
  119. UK: Audi A5 2.0 TFSI Quattro Cab, TCM failure. HELP!
  120. Looking for B8 Red Seats!
  121. 2018 Audi S5 Engine Revving Issues
  122. A5 manual transmission torque rating?
  123. Unknown DCT's causing trouble
  124. MMI update and bluetooth issues
  125. UK: A5 soft top help
  126. Really need some help, throttle body and tuning issues!
  127. Looking to make my car sound good.
  128. Limp Mode after new 034 Motorsports tune..
  129. 2010 Audi A5 2.0 TDI - IE intercooler installation with dynamic steering?
  130. RS Power Seat: all functions stopped except lumbar support with direct 12V DC
  131. 2.7 tdi multitronic humming noise in cabin
  132. UK: Audi b8.5 nocking with po600
  133. ECP Light - 08852 and 00135 Codes
  134. Major elctrical issues after retrofitting Drive select
  135. PL: P0087, low fuel pressure 2.0 TFSI CPMA
  136. 2011 Audi S5 Cabriolet engine
  137. 2009 Audi A5 Quattro needs help!
  138. Question about new B8.5 S5!
  139. 2013 Audi S5 sway bar links
  140. PL: AC randomly working, N280 problem
  141. Front right light issues
  142. Misfire after clutch replacement P0016 & P0018 & P1571
  143. Android head unit For Audi A5 2009-2016
  144. Help with vibration while idle 2.0tfsi 2014
  145. Help! Oil leak from turbo return?!?
  146. HELP - fault code p040300 exhaust gas recirculation circuit
  147. Sudden non-Start with pushkey
  148. AU: Audi a5 2012 cabrio rear bumper fitment?
  149. Interchangeable parts between 2,7tdi & 3.0tdi
  150. 2012 S5 New Purchase - Bluetooth Audio not connecting
  151. O2 Sensor Codes After Replaced Turbo
  152. Led tail lights repairable?
  153. UK: Which part Nos for 2011 A5 coupe with MMI 3G High?
  154. Can you fit a S-line diffuser on a non S-line rear bumper ?
  155. PL: Relay for Coolant Pump and Auxiliary Air Heater, AC problem
  156. No crank on start after dead battery
  157. Injector flow
  158. Mis-fire: Slowly giving up!
  159. IT: Cooling problem
  160. DL501 transmission mystery failure
  161. Oil Leak 2.0 TFSI
  162. A5 No ignition
  163. Pricing an S5
  164. Audi A5 B8 3.0 TDI Cabriolet Stronic S Tronic-Stage 1 remap; no difference in power
  165. 190hp CNHA long crank first start
  166. Audi A5 G-tron
  167. BLUETOOTH, AUX AND CD REFRESHES EVERY 30 SECONDS ON MMI
  168. Road noise after driving over curb
  169. Replacement Radiator Grille
  170. 2008 Audi S5 Misfire Help
  171. UK: Vibration and Noise at Motorway speeds, HELP
  172. One Year of Minimal Use Leads to No Start Condition?
  173. Electrical problems!! Help please
  174. NO: DESPERATELY NEED HELP WITH TIMING CHAIN JOB!
  175. Right rear loose metal rattle sound
  176. Replaced Steering Control Module now New code 5258756 - Steering
  177. 2010 S5 4.2 "Steering System Fault", "Gearbox Malfunction" and "Sport Diff Fault"l
  178. 2010 B8 audi s5 mechatronic unit
  179. Audi A5 / S5 / RS5 Android head unit
  180. Throttlebody screw isn't tightening, help pls
  181. Gear with exclamation point
  182. UK: Done a "cracking" job today.
  183. Is this a sign of a bad Shift Interlock Solenoid?
  184. 2013 AUDI S5 UPPER CONTROL ARM BUSHINGS
  185. Sourcing parts that are no longer available.
  186. PL: No Communications with Steering Angle Sender (G85)
  187. Pin Out for 2014 A5 Quattro Convertible
  188. Pin-out for A% Cabrio Roof up/down switch
  189. 2014 Audi A5 Underboost comes and goes + dealerships
  190. AU: Wiring diagrams for a 2012 A5
  191. Wiring diagrams for a 2012 A5
  192. 2010 S5 fans run forever
  193. 2016 A5 Convertible top issue - top won't close due to drooping headliner
  194. Carbon clean causing injector failure
  195. P2015 and p2006 b9 Audi a5 2.0t 2018
  196. stage 2 IE tune cel?
  197. Misfire diagnosing 4.2 S5
  198. UK: 2.0 TFSI (E888) - When should I change the timing chain?
  199. Musty air coming from vents
  200. broke the supercharger bleeding screw head. Best way to take it off?
  201. Misfire Diagnosing on my S5
  202. 2008 S5 (B8) - MMI 2G High (2GH) - Radio freezes for a couple seconds when the temper
  203. Enabling Red Engineering Menu
  204. 2010 Audi S5 Cabrio Exhaust Vibration
  205. Replaced injectors, now has a very rough idle (help)
  206. EPC & ESP light on, Parking Brake Malfunction, Loss of Power (Limp Mode)
  207. Audi Connect on a 2013 S5
  208. Headlight range control defective issue
  209. Need help weird clicking sound when brake in N/P
  210. 2013 S5 OEM Replacement Battery?
  211. 2014 Audi A5 Quattro P0299 when in sports mode
  212. 2019 A5 rain sensor
  213. A5 3.0 TDI cardan shaft numbers
  214. Anyone Ever Get Code P2075 IMT Valve Position Sensor
  215. Rough Idle / Mis-fire at morning startup
  216. Mirror Replacement A5 Cabrio 2011
  217. audi a5 b8.5 A/C leak help
  218. How to remove kick panel below steering wheel?
  219. Spiral Audio Install Kit
  220. rough or loose SOUND
  221. Steering wheel control issues
  222. Should I use a gasket maker sealant on the PCV gasket?
  223. Do B9 alloy wheels with same ET / bore fit B8s?
  224. PLEASE HELP!! Fuel Filler- Water Leaking into trunk boot
  225. VCDS - Battery "Not OK"
  226. Fuel injectors question
  227. 2015 S5 Mostly Driven in NY - Too Much Undercarriage Rust?
  228. Need help with wire color identification
  229. UK: Audi A5 2.0 Multitronic CVT, high miles
  230. Strange buttons
  231. Misfire question B8 S5
  232. Wiring Harness Connector and Headlight
  233. 2007 3.0 TDI A5 Quattro Thermostat
  234. 2009 S5 4.2 starts but shuts off immediately.
  235. High pressure coolant flying all over the engine and rattling noise. Help me diagnose
  236. BA: Increase Audi A5 3.0 diesel quattro to 380 hp?
  237. Automatic rain sensor malfunction error
  238. 2014 RS5 Cabriolet Ctl Arm/Bushing Replacements
  239. PL: Audi A5 2013 2.0 TFSI, no crank, terminal 15 problem
  240. Start-Stop & Auto Hold (Vcds Code)?
  241. 2012 S5 Cabrio front grill replacement
  242. 2014 A5 sportback - parking sensonrs stopped working
  243. Wiring Harness damaged by ECM?
  244. Help me figure out what I have.............
  245. UK: New drilled & grooved discs/pads judder
  246. Is my B8 S5 Totaled?
  247. Soft top whole roof replacement
  248. AU: Is my A5 a B8 or a B9?
  249. 2008 S5 won't start
  250. Question of parts compatibility for A5
