- 2013 Audi S5 Cabrio - new purchase
- RS5 Fan run even when cold (30 degrees)
- Subwoofer Install HELP
- getAudiparts.com | Black Friday - Cyber Monday: Lower Pricing + FREE Shipping!!!
- Europrice.us Black Friday Deals are almost here...
- Carbon Cleaning Adapter 2.0T, 3.0T, 3.2L, 4.0T, 4.2L, 5.2L, etc
- Some direction please, Drive Select....
- Audi A5 sportback
- Anyone know what this plastic thing is?
- Rim & Tire Swapping...looking for help...
- Dealership wants $1100 to replace front brakes...
- New (Used) 4.2L S5 ..Exhaust comments
- 2014 Audi RS-5 (Need some Turbo Advice) B8
- Upper control arm bushings covered under warranty?
- Engine noise setting and fuel economy ??
- New Audi A5 Quattro Owner
- S5 - 4.2L or 3.0L?
- 2012 A5 Premium Check engine light
- Audi A5 2017 gearbox
- AUDI A5 S LINE 2.0l STARTS THEN STOPS SOON AFTER ?
- S5 V8 suspension & differential questions
- Electrical symbol Help
- Horn not working help
- Grinding noise from front end
- Wheel spacers and paint damage
- Squeeling noise and leaking fluid?
- 2013 S5 Parking Brake Fault Code
- Audi A5 belt
- Audi A5 belt
- steering wheel upgrade.
- 2010 S5 CABRIO REAR SIDE INTERIOR PANELS
- Seeking better underbelly pan
- oil sensor
- Different offset wheels
- Rear lip spoiler, Cabriolet
- Buy or Not to Buy
- I'm Thinking This Tire Is Not Salvageable
- Update NAV on 2015 A5
- Upgrade NAV Disc for 2011 S5
- Carmax Warranty for 2014 A5 Convertible
- Steering issue on A5
- New brake rotors for 2013 A5 Cabrio with 34K miles??...
- 09 A5 3.2 just hit 130K
- Seat controller trouble
- Best Aftermarket suspension for Audi s5 (coilovers)
- Screws for plate
- Engine oil
- Audi A5 Key Fob problems
- Question about my A5... 100% Noobalicious. Coilovers & Rims
- hard start and white smoke after a head gasket replacement
- For Sale in Huntsville, AL
- 2012 S5 Recommended Service Schedule
- Advice!: Used 2015 RS5
- Moved to LA (Hancock Park Area) - Best Audi Shop
- Exhaust Valves Open at all times!
- Does RS5 have turbo lag like S5????
- Has anyone updated to MMI K0942_6
- backup camera
- Recall electric aftervrun coolant pump
- getAudiparts.com | Genuine Audi Collection Key Rings!
- 2016 S5 Air Box Modifications
- A5 Odometer Stopped counting . Shows 'Error'
- Buying a used 2010 Audi A5
- After market exhoust.
- Hidden Menu (BAP or CDEF)
- Clock Issues - Can't Set
- Fault Codes P2006, P2007. Help
- Power steering leak
- Rs5 style grill with silver honeycomb ?
- Where to buy painted trunk lip spoiler
- Clutch issue. PLEASE HELP!!!
- Instrument Cluster Replacement
- S5 vs 435xi 😫
- Vag-Com Issue on 2015 S5 Rear Brakes
- UK: 2010 Audi A5 (Diesel) - Wont start after Fuel Pump Pressure Regulator replacement
- Stock Wheels
- 2014 Audi A5 DTM/S Line
- Ignition Lock Defective
- Undo Lowering Springs?
- 2018 S5 sportback
- Sequential Tailights
- All season tires for 19” wheels S5SB
- SOS! Help needed!
- On the fence about buying an s5
- JHM Stage 1 tune for the B8.5 RS5
- Problem with windshield wipers and flushing
- Audi A5 cab clutch question
- 2013 S5 average mileage to replace clutch?
- Fault P0492 only
- Transmission Mount Insert Question
- Installing S5 Badge on RS style Grille
- SOS. Need a couple easy pointers!
- 1995 Audi Cabriolet- an OBD connector?
- S Line Sportback 2014 rear bumper fit
- Wheel Offsets
- Mechanic is telling me 2010 S5 needs two vacuum solenoid valves? (Part# 037906283C)
- 20" Trapazoid Wheels - Spacers?
- A5 2012 driver door not locking with key fob.
- 2013 S5 - Memory Seat Settings Not Functioning
- New member and had questions about 2013 RS5
- ATF Transmission Drain Fill Plug Locations on 2013 A5 B8
- Vibration when Steering while Stationary?
- Replacing a Battery on a S5
- How to clean intake manifold with Seafoam? P2006 & P2007
- folding side mirrors manually
- 2014 A5 M6 Clutch question
- Knowing when a car has a Torque Vectoring Differential?
- LED Fog Lights
- Blowout Sales Pricing - STaSIS A5 2.0t Exhausts...
- Dip Stick for 2018 S5 and/or SQ5
- RS5 Style Grill
- rotors
- Oil level low add max 1L ok to continue to drive to workshop
- Audi a5 2.0 tfsi quattro - Performance & Tune
- About to pull the trigger on a 2013-2014 Audi S5. Need help.
- RS5 Brakes on a S5?
- Adding Auto Start/Stop button (and function) to a B8 A5/S5/RS5
- Audi speaker upgrade help
- RS5 Dynamic setting looses sport exhaust sound on restart?
- Upgrading Drive Select switch on 2015 RS5
- Mileage drops drastically
- Audi S5 2015 - Chain or belt?
- Can our factory headlight housings be taken apart?
- EPS
- Fuel Gauge
- Stalling on stop when cold
- Audi 2014 Q5 2.0 Diesel
- Out of balance tire worse when braking?
- new seats
- Used 2010 2.0t
- Considering a '09 A5 3.2 6M. Good choice?
- Console/Dash rattle, vibration noise
- Engine Oil Reading from broken Hood Latch Sensor
- 2015 v 2016 S5
- Is premium gas really necessary?
- Red Engineering hidden menu
- Fan Relay location?
- Tesla Powered S5
- Oil level not displayed after hood open, not hood latch(?)
- S5 grill paint, wrap or plasti dip?
- Clutch problems
- Hello, My name is ...
- A5 SB 2.0tfsi - Instrument cluster brightness
- New Product Launch Blue, red or clean bright white FOOTWELL LEDs for all AUDI Models!
- Putting A5 back together after wreck - airbags/seatbelts
- MMI Display not turning on
- Front defrost blowing cold air
- FOR SALE: HRE S101 21X10.5
- Fog light bumper cover fell off
- Audi S5 Coupe several problems,very thankful for help!
- Production numbers
- Watch out for oil change idiots
- Looking for thoughts / reviews on a Mototec Sport Exhaust for my B8.5 A5
- Ad Blue & Reductant Pressure Too Low
- S5 LED Foglights
- Tires
- Rubber blade on undercarriage right behind front grill keeps coming off.
- RS5 20" Rotor Wheels on Stock Audi S5 (pre-facelift)
- NEW 3.0T APR Open Carbon Fiber Intake System!
- Coolant Reservoir problems HELP ASAP
- XM RDIO PROBLEMS
- Audi S5 Wheel lug nuts / bolts
- A5 Cabrio extended warranty
- Carbon cleaning cost?
- OK, let's talk performance brake pads
- 2012 A5 2.0 ENGINE MANUAL
- Sparks & Coils
- Whining/rubbing noise 2009 A5 3.2 S-Line
- S5 4.2 V8 common problems
- A5 transmission service
- Rs5 Year difference and option clarification plz
- No bluetooth audio
- 2012 A5 2.0 P0299 Code
- Rear window
- Completely locked out of my s5, HELP!
- Power Fold Mirror Retro Fit
- Fog light trim mod for CAI
- 4.2 stroker kit or better internals
- Estimated repair costs?
- 2010 Audi A5 3.2 Quattro (Seafoam)
- 09 Audi S5 Flashing Check Engine Light
- A5 intermittent vibration and shaking
- Coding help
- Weird - my car wouldn't start this morning
- Milltek Exhaust SALE! 10% off!
- Audi S5 - Car Will Not Even Attempt to Start - Is is Totaled?
- NEED HELP!!!
- Noise clunk
- Screen resolution...
- What colors r there?
- set of free 255/35 R19 96R tires in NYC
- RS5 4.2 vs S5 4.2
- 2005 A4 Cabrio. Comfort control module issues!
- Driver Seat NOT Working- B8 S-line A5 2008
- Yikes! Time for new shoes!
- BAD PISTON TEST???
- Need help ASAP on if these wheels will fit my 2013 A5 Premium Quattro
- 2009 s5 high pressure fuel pumps for 4.2 v8
- voice command
- FLASH SALE! UP to 15% off ECS Exhaust Upgrades | Tips, Cutouts, X-Pipes, and more!
- P0299 Fuel Consuption
- Vin decoder ?
- Is this factory in the front end of these s5's??
- bluetooth for Media
- Best place for RS Grille? + Your thoughts on combo..
- 4.2 motor swap between years
- Considering an A5 - Which year?
- 2014 A5 (Coupe) Rear Parking Aid Buzzer location and its relocation
- Black pearl ?? Difference
- How do I remove this clip holding a plastic piece on the rear of the front fender...
- Need help removig a piece and fixing a rust issue...
- Newbie needs help
- Parts interchangeability between years
- Just broke something.
- ProdigyWerks Rear BBK
- Audi RS5 Front Emblem on Grill
- Audi S5 2011 face lifting front end conversion
- 2012 a5 misfire after stage 1 tune
- Crazy Sirius Issue
- Questions around putting the stock 2014 RS5 springs on my 2013 A5
- Audi S5 coupe 2011 radiator help!!!
- Heavy steering
- Subwoofer Help
- A5/S5 Stealth Hitch Customer Reviews!
- Sweden: 2010 A5 2.0 tfsi HP after new pistons
- Audi A5 (2011) Burning a lot of oil
- 2015 Audi S5 Cabrio Brake Probelm
- APR3
- '13 A5 starting problems.. Need help
- Ambient temperature sensor issues (P0070)
- h&r spring
- Weird noise coming from engine bay on cold start
- Installing Coilovers - $$$
- B8 2008 Audi A5 Strut Question(s)?
- oil
- ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
- Retrofit MMI (the Control part only) down in the gear surround
- brushed aluminum inlays - S5
- Help - Is an additional 2k worth CPO 2015 S5 Convertible ?
- 2011 S5 Cabriolet--top replacement/sun shield Q's
- FLASH SALE -- Lightweight Flywheel + Performance Clutch
- Replacing Mid Resonator with X-Pipe?
- does anyone know what fault code P17D400 is related too?
- Selling S5
- Steering Wheel Upgraded
- Audi A5 high oil usage
- Audi 2011 S5 DSG Gearbox malfunction mechatronic transmission issues advice requested
- 2010 S5
- Misfiring and smoking
