- UK: Slow dropping revs?
- New 2012 A5 owner questions
- B8 Manual Shift Knob- BFI GS2H
- Is doing mechanic on an S8 harder than on a A4?
- A5 3.2 120k Coolant flange leak?
- My 2014 S5/updates/upgrades
- used A5
- BEARING REPLACEMENT FROM HELL 🤬
- 2011 A5 Front fascia repair
- 2011 Audi S5 Front Suspension Bushings
- Audi A5 Sportback hood latch?
- MMI software update - 2011 S5 Cab
- Audi S5 not starting/turning over
- 2014 Audi RS5 multiple system faults
- Dipsticks says full, MMI says low.
- Is it possible to put a B8.5 S5 frront end on a B8 S5?
- Audi s5 strange rattle noise when at 2000-2800 rpm
- Audi s5 air pushing out antifreeze out coolant tank
- Audi A5 2009 - Exterior Handle Not Working
- Need to update radio and Nav. Any suggestions for updates and how-to's are welcome
- 2013 S5 manual transmission fluid? How many diffs does this thing have??
- 4.2L V8 firewall/hood seal part question
- 2014 s5 STAGE 2 APR or not?
- Rear Sport Differential DIY
- Rear brake upgrade DIY video
- Are black Audis worth it?
- Potential B8.5 Cab S5 buyer
- Problem using Waze through mmi
- My First Audi S5
- A5 Door Lock Actuator Replacement (PARTS?)
- Time for service, or not?
- The light bulb indicator lamp
- Cargo Mat for Cabriolet?
- Leather Seats
- Worried about 4.2 V8. Any experience with extended warranties?
- Location of temperature sensor
- My Keyfob doesn't work! I need help and advice!
- 4.2 Engine Review
- Potential buyer again, feedback?
- UK: A5 diesel, Need Help finding something...
- Well, I went to the Dark Side
- Different heads from 2009 S5 then a 2010 S5?
- 2015 S5 timing is off- 43k miles and tensioners fail??
- Change atf for miles only?
- 4.2l v8 Spark plug tube seal short term solution
- New RS5 owner looking for indy garage
- RS5 Cabriolet Wind Deflector
- getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
- Audi S5 spark plug & solenoid gasket
- 2010 Audi A5 2.0 Quattro Coupe EPC light keeps coming on rough idle
- Audi S5 stalling with oil cap off
- 2010 Audi S5 4.2EFI manual | P2293 code
- Bye Bye Google Maps
- Can’t figure it out!
- B9 wheels on a B8?
- UK: PLEASE HELP - 2012 AUDI A5 - WARNING LIGHT (GEARBOX MALFUNCTION) AND DIAGNOSTIC
- 2021 Audi A5 sportback Sline questions?
- Seat knob part number? I can't quite find it
- deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
- AWE Black Friday 2020
- traffic signs mmi
- Audi A5 Installed BBK big brake kit 6piston for front
- Black Friday Deals Are Already Here and More to Come...
- Installed Apple CarPlay/Android Auto on A5 B8 for $207
- Cold misfire? Transmission shifting a little weird? Check your spark plugs!
- 2019 S5 with 19,500 mi, Stealer or Private shop?
- Battery Display Doesn't Show Up On My 2014 A5 Cabriolet
- Central lock not opening driver's door.
- Enable A5 B8 Key Fob Windows Up/Down Function
- plug locations of front differential and center differential/transfer case?
- 2014 A5 Cabriolet Memory Seat Problem Fix
- Replacement fog lights bulbs 2014 S5?
- LI NY: oil in coolant - 2011 S5
- 3.2 replacement needed
- AU: Backlash on Torque Reversal - B8 S5/ZF 6HP28AF
- Battery life on a 2014 S5?
- Thoughts on 2013 Rs5
- CEL - Evap Control? Multiple codes! Solution?
- Driverside window not working
- New to this forum LOL
- New buyer advice on 2014 RS5
- Fasteners in the engine bay
- 2009 Sirius radio delete?
- Audi a5 2011 advanced key features
- A5 2011 sunroof stuck
- Suspension Question
- 2021 A5 Sportbak
- RS5 (B8) US Production numbers
- Headlight out message
- Advice for potential first time owner?
- Upgrade ideas?
- CarPlay Symfony
- What are common oil leak cuases on 2015 S5?
- S5 US Sales Numbers
- 2015 Audi S5 Technik Back up Camera not working
- Reverse sensor
- 2010 S5 CABRIO DSG Recoding
- 2014 S5 Possible Tranny Not Funcitioning
- Introducing OEM Folding Mirror Packages...
- 2020 RS5 B9 vs B8.5 2013 RS5
- Audi B8/8.5 3.0t Engine Diagnostic & Maintenance Guide
- rs5sb driving impressions
- Audi A5 2014 Bonnet
- Help please - part number hose coolant
- Looking for a paint code for spare wheel well?
- 2009 S5 power steering pump
- 2017 S5 Modification Help (new owner)
- Need advice on this S5 - 1 owner, full dealer history BUT high mileage
- 14' S5 stage 2+ coolant leak?
- Engine Noise @ 1900rpm
- 2013 RS5 questions
- DRL on the Tail light
- 2009 Audi A5 Thermostat replacement?
- Cargo net for B8.5 cabrio
- HELP!!!! 2008 Audi A5 3.2
- 2014 - to update mmi and maps or not?
- AU: A5, Can anyone help?
- Wheel color of 19in S5 wheel
- Car On - Door Chime Switch - Who Knew...
- The Audi A5 car stops by itself when i open the door
- 2018 A5 vs 2014 S5
- VIM MMI 2G I can't find my serial number.
- 2016 A5 Review, Common Issues, Buying Guide
- AUDI S5 8T 4.2FSI
- subframe realignment
- B8 RS5 - Sport Diff Broke
- 2010 S5 DSG P081E ERROR
- 3.0 tdi noise
- A5 cabrio - wind deflector part number?
- Any help with these sudden 32 faults due to some electrical issue i guess
- A5 2.0T B8 stage 3 apr - faults after oil change
- Another annoyance
- A5 Coupe Lowered on 18s
- Radio Comes on at Start up
- pride month
- Lug Wrench scratching the wheels
- 2010 S5 CABRIO B/O AMP REPLACEMENT
- 2010 A5 3.2 Prestige Facelift Project
- A5 2008 3.0 TDI CAPA quattro, manual, 4367 - Powertrain Databus
- Draw test? Has anyone had a sudden battery problem with the S5 ?
- Roof bars?
- A/C too cold!
- S Tronic transmission sounding like it may stall
- whine/howl/whirring -- changing out rear differential
- MMI S5 2009
- M6
- Audi engineers are having too much fun?
- 2015 RS5 launch control
- Pull the trigger on this 2017?
- Timing Belt?
- key blank
- oil dipstick
- trunk bracket
- program new key FOB
- 2012 Audi S5
- Local A5 possible buy but leery
- HPFP fittings
- 2010 S5: P179c00
- CV axle/transmission
- S5 Cabrio B8 Rear Diffuser
- UK: Advice for used A5
- Need replacement key fob
- S5 won’t crank after accident
- Tire Recommendatio?
- help needed
- Resetting historical mileage/mpg data?
- Mi 2015 RS5 select drive
- TCU tune for ZF 8HP automatic gearbox
- S5 b8.5 forgestar super deep concave f14's
- Rear suspension -- one side is higher than the other
- PCV Oil Leak?
- RATE-A-KIT: NEWING Alpil Body Kit for Audi A5 Sportback 2013-2017
- Bad Shocks?
- Audi A5 S-Tronic, gear stick problem
- Emission Light
- 2011 Audi A5 Headlights
- How to accelerate fast with RS5 (2017)?
- Battery replaced under warranty
- Weird sound from the A5 S-Tronic gearbox
- Thought it was a dead battery 2011 V8 S5
- OBD11`Gateway~Battery Adaptation~Replacement
- Help!! Water tank boiling up
- How easy is it to remove the supercharger?
- Audi B8.5 S5 vs R8 Ground clearance?
- A5 2017 SLine coupe
- 2011 A5 Vibrating After New Spark Plugs
- Donate to Discount so you can Quarantine in Your Garage...
- Overnight Battery Drain
- Need help with radio and navigation
- Clicking noise @ 15 kmph.
- Strange Gearbox Behavior?
- A5 build Thread
- Exhaust valve question
- Shopping for a B8.5, have a few questions
- RS5 - newbie question
- 3.0 bitdi swap
- Wanted: awe touring exhaust for s5 b8.5 coupe
- Rear Bearing Axle Bolt Size
- MMI firmware and map version 2019
- B8 S5 4.2L - Battery Drainng due to module in trunk relay area
- DE: Auspuff Anlage A5 3.0 tfsi
- Audi A5 2012 1.8T No heat from cabin heater.
- SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
- Installing a B8/B8.5 pre-fan HVAC filter
- MMI number of keys data?
- Cold Air Intake?
- Reattach power seat button 2014 A5
- whose car is also on vessel GLOVIS COURAGE which arrive at Benicia port on Apr. 27th?
- MMI sound issue after replace XM module
- B8 S5 4.2 Multiple cylinders miss fire
- Advice needed!
- Over heated and It wont start
- S5 transmission KMV to LPC
- Please help. Weird humming/buzzing noise from my RS5
- Crankshaft speed sensor location -
- S5 Hesitation
- Selling my Stg2 6MT SportDiff B8.5 S5 on BringATrailer ends Thurs 4pm ET
- Identifying failing wheel bearing
- 2011 A5 Coupe- Plastic fascia underneath front?
- Headlight issues
- 2013 Audi RS5 Transmission Overheating
- HELP! BUYING AN A5!
- Ouch - RS Q3 review
- AUDI RS5 SOFT CLOSE CAR DOORS
- Introducing OEM A5, S5, RS5 Post-Facelift LED Taillight Packages...
- Wheel bearings went out, Audi claims they don’t fail
- Anyone have experience with this carplay module?
- We Build Faster. Shorter Lead Times on AWE Exhausts.
- MMI Screen Scratch Removal?
- How to clean behind instrument cluster glass?
- Audi A5/S5/RS5 Soft Close Door Update
- Tire Commentary
- 2015 S5 manual long term update
- A5 Convertible - Opening Roof Manually
- B8.5 2.0T Trans & Diff Service Intervals?
- Dash Speaker and Map Pocket Rattles
- Noise when from the first two shifts
- B8.5 S5 AWE Touring going back to factory
- Too lean off idle and cylinder 7 misfire..
- Audi a5 2009 coupe b8 rear speakers changing
- GB: TV tuner? Anyone have one?
- Audi S5 2011 3.0T Cabriolet - Leaking oil
- Wind/road noise from B pillar area
- Chipwerke???
- Audi A5 2011 disappearing oil
- 2010 Audi A5 leaking excessive oil & running on limp mode
- A CD loaded into the car
- Searching for a B8 or 8.5 - Pricing differences?
