PDA
View Full Version : Audi A5 / S5 / RS5 Coupe & Cabrio (B8)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60
  1. Alcon rear brake calipers
  2. MMI Upgrade
  3. UK: Audi A5 Cabrio 2015 Radio Sound on & off
  4. Best Place to List Car
  5. Intercooler differences
  6. 2014 A5 2.0 Integrated Engineering Stage 1 & 2 questions
  7. B8.5 2.0t engine rattle on cold start - lasts 5-7 min
  8. 2010 S5 Need MMI help
  9. A5 convertible: Rear seat covers?
  10. What to replace while engine and trans are out 115k miles
  11. Question on oily/wet trans bell housing
  12. Sport differential system fault!
  13. IE: 2012 A5 S Line, Black Edition & SONY XAV-1000 - possible?
  14. RS5 b8.5 drc
  15. On center steering feel
  16. Central speaker + sub retrofit
  17. 2013 S5 3.0T - timing service
  18. Audi A5 Rear diffuser
  19. 2016 S5 with A5 Seats
  20. Audi A5 Transmission Malfunction
  21. Audi A5 Transmission Malfunction
  22. AU: Audi A5 transmission malfunction
  23. Front speakers not working
  24. Issue
  25. FORGEDLITE Wheels - 1pc Monoblock & 2pc Modular Forged Wheels - WHEEL DESIGNERS
  26. DSG gearbox revision question about sensor selector
  27. Armrest leather Shrink
  28. 2009 A5 Quattro HEATER CORE anyone??
  29. 2011 Cabrio won’t shut
  30. All New Klassen ID F07R Form+ Light Weight Design Wheels - Tailored for Each Vehicle
  31. 2011 Audi S5 Sunroof Delete?
  32. Audi s5 b8.5 supercharger pulley upgrade
  33. Mmi 3g amplifier alternative
  34. Rattling noise from engine (Video attached)
  35. A/C not turning on, G395 error
  36. Rohana RFX Series Cross Forged Wheels - Special Member Pricing!
  37. Buying used B9 S5 privately - what should I check for?
  38. A5 hood on an S5?
  39. Noisy while driving
  40. S5 spark plug service interval
  41. 2008 Audi S5 - 4.2L V8 - Resonator Delete
  42. The 034Motorsport SummerFest Dynamic+ Sale Is Here at PartsByTopher!
  43. Hard Start When Hot
  44. Gear shift lever broken
  45. UK: A5 Convertible Boot Question
  46. 2013 S5 Manual Transmission Fluid Type?
  47. Xenon's dim
  48. New Owner - A/C - Compressor Not Turning ON
  49. No fuel rail pressure
  50. UK: Failed DRL strip for facelift b8 A5
  51. Bluetooth
  52. Transmission trouble
  53. AU: 2010 Audi A5 TDI, Help!
  54. 2013 A5 2.0T Automatic Shift Question
  55. Graphics, vinyl, logo suggestions and pics?
  56. Low coolant level / Expansion tank and sensor replaced, still causing alert
  57. Am I nuts? Pre-purchase question.
  58. Please Help! Need exact size for 2016 Audi S5 Black grille rings
  59. Mystery Part!
  60. Reverse light bulbs socket
  61. Oil level sensor?
  62. Need OBDEleven Scanner
  63. Audi A5 Quattro B8.5 Upgrade Recommendations
  64. UK: A5 radio cuts out
  65. Retrofitting CarPlay in 2014 S5
  66. Audi S5 2009 4.2 FSI - Serious coolant water loss but no leak
  67. Add Apple Car Play or Android Auto
  68. Question S-tronic Audi A5
  69. 2011 A5 Convertible Issue
  70. It Might be Time but What's Its worth?
  71. MMI moof- engine off, open door, stereo stays on
  72. seats compatibility
  73. 2013 RS 5 P0599 thermostat code and adaptive headlight error
  74. Audi S5 B8.5 Diffuser
  75. Speaker upgrade for B8.5 RS5 Cabriolet
  76. Inventory Sale - Stance SF01 20x10.5 Gloss Black Tinted Face
  77. 2015 Audi S5 premium plus automatic transmission?
  78. A5 convertible folding door mirrors
  79. CarPlay Issue?
  80. Voltage terminal 30
  81. Older A5 Sportback models (pre 2011)
  82. A5 convertible head scratchers
  83. 09 S5 4.2V8 6spd common issues?
  84. Jumpy tachometer? Audi A5 1.8 TFSI (manual)
  85. Battery voltage
  86. Is my 2008 Audi A5 B7 or B8?
  87. Rear brake light seal damage
  88. About to Purchase used 2013 A5 2.0L, any advice?
  89. 2010 A5 - won't sleep, gauges keep ticking, battery drain
  90. Sport Differential Failure Msg, no code
  91. DE: Big Problem S-tronic
  92. 2010 Audi B8 S5 4.2 V8 Knocking on Cold Start
  93. Rs5 (2011 B8) vs 2012 (B8.5)
  94. Rohana RFX Series Cross Forged Wheels - Special Member Pricing
  95. B8 RS5 Coil Connector replacement DIY?
  96. How to update MMI in a B8 (2012) A5/S5?
  97. Audi A5 Maxton Designs Carbon Boot Spoiler
  98. Cabrio tensioner cable help needed
  99. RS: 2.0 tdi fuel consumption?
  100. Stance SF01 SF03 SF07 SF10 SF11 Rotary Forged Wheels - WHEEL DESIGNERS
  101. B9 steering wheel paddle shifters not working in B8
  102. Dipstick
  103. Time display
  104. Avant Garde M580R Light Weight Design 19" 20" 21" - WHEEL DESIGNERS
  105. 2018 S5 Cabriolet peeling clearcoat
  106. Vossen HF1 HF2 HF3 HF4T HF5 HF7 - WHEEL DESIGNERS
  107. 2011 Audi A5 2.0 do I need engine or not?
  108. keyless entry is hit or miss
  109. LH Main Headlight issue
  110. Do not purchase from Strafe Design
  111. Audi A5 8T Side Skirt Removal/Installation
  112. HELP: 2010 audi a5 2.0t
  113. 2022 S5 Seat Choice
  114. Racechip choice for A5?
  115. 2019 S5 Sportback questions
  116. Audi S5 trouble code P310B
  117. 2022 RS5?
  118. Unexpected "delivery"
  119. Mysterious Unresolved Rough Idle
  120. Unknown
  121. Audi A5 Cabriolet roof operation not smooth
  122. DME tune for 2013 rs5
  123. 2016 A5
  124. KW HEIGHT ADJUSTABLE SPRINGS
  125. First Audi Advice
  126. Check coolant level warning
  127. AUX AUDIO INPUT
  128. AU: Is the 2012 B8.5 MY13 A5 2.0 TFSI petrol as reliable as the rest of B8.5?
  129. P2187 keep coming back
  130. 2012 S5 Cabriolet
  131. ECM or fuel issue???
  132. Thinking of 2011-2014 S5 manual
  133. 2010 S5 DSG DUAL MASS FLYWHEEL TORQUE SPECS?
  134. 2010 S5 Won’t start please help
  135. Start only when wants?
  136. 2013 Audi A5 convertable
  137. MMI 3G WMA and DVDs through SD cards
  138. Ac / Heat Doesn’t work HELP
  139. CA: TPMS ISSUE 2016 B8.5?
  140. Window is being dumb
  141. Changing KPH to MPH while in classic view?
  142. Houston Independent Shop Recommendation
  143. Audi Christmas Surprise!
  144. MK: Heating problem, cold on driver's side and worms on passengers
  145. Engine Mounts and Control Arms
  146. Another picture thread
  147. Replacing MMI with some android display or whatever
  148. S5 V8 Oil Leak - Towards rear of car
  149. '16 S5 - Steering column replacement
  150. S5 V8 B8 Leaking Fuel Injectors
  151. 2014 S5 Convertible White Body Black Top Red/Black Leather Interior WRAP ideas
  152. getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
  153. 2014 audi s5 62k miles with new transmission ???
  154. 14MPG. Why is my gas mileage so bad? 2013 Audi S5
  155. Missing wind deflector tips
  156. HPFP leaking - o-ring or entire replacement?
  157. AU: MY10 V8 S5 Cooling fans staying on
  158. Seeking advice on 2016 S5 Cab purchase...
  159. S5 Manual 4.2 Bad Engine
  160. Transmission failure: advice?
  161. A5 B8 Sportback exhaust tips diameter
  162. Quick Maps update Question
  163. A beautiful RS5!
  164. is this the end? switch off engine and check oil level
  165. A5 Sportback S-Tronic questions.
  166. getAudiparts.com | Genuine Audi Floor Mats Sets!
  167. UK: 1.8 TFSI 2011 oil consumption
  168. Where did these ball bearings come from?
  169. AC Compressor Pulley
  170. A5 EPC and Emission Control System light on
  171. Audi A5 loose key in ignition and faulty lock system
  172. Trunk replacement
  173. Rear wheel bearing bolt torque
  174. 2018 A5 - AC NOT blowing cold
  175. Weird stalling/stuttering at low speeds
  176. Radio fuse keeps blowing, MMI not happy
  177. “Please connect your Wi-Fi device to the Audi MMI”
  178. 2010 S5 Tiptronic reverse issues please helpe?!
  179. Looking for 2014 RS 5 OEM Exhaust
  180. Lowering Springs
  181. FI: Audi A5 2.0 diesel 130kW?
  182. UK: Component Protection Removal?
  183. Traditional Bra?
  184. Mystery coolant leak
  185. Weird misfire
  186. Need a rear bumper, but with a dual valence??
  187. Rear Anti-Roll Bar/Sway Bar Bushing
  188. FNG
  189. 2.0T TFSI Cold Start Idle Sound (Bell Sound)
  190. after market bumpers and front fenders???
  191. Audi Tech Packages. Hmmm...which one?
  192. Lower grille (fog light grille) damage -- worth a $2,000 deductible?
  193. How to update TCM software?
  194. A5 (B7F) Suspension Colour codes
  195. Flooded A5 convertible
  196. Yellow warning & red "brake" lights on after pad change
  197. Help needed with N205 issue
  198. Latest Vid, Airbag cover removal and installation
  199. Installing Navi. database Version:
  200. rebuild price check/reasonability inquiry. Also, Tech upgrades?
  201. Possibly the 2nd biggest financial mistake of my life.
  202. Trunk opening button on trunk lid removal
  203. Window does not work
  204. Engine whine from 1800rpm on 2011 S5
  205. Rear Headlight levelling sensor snapped
  206. 2011 s5 owners manual
  207. Mmi problem
  208. 7 misfire codes, 2011 S5 with 200k miles
  209. 2012 S5 air filter hsg connector/sensor
  210. HELP car not starting
  211. B8 S5 MT Help stuck
  212. S5 2011 Hell Needed!
  213. My 2014 S5 Needs Struts. Replacement suggestions?
  214. New to audi; considering a 2011 s5; would like some thoughts and opinions
  215. Audi s5 4.2L Port injection?
  216. Limited extended warranty coverage for electromechanical steering unit
  217. Route cable camara in Sportback B8
  218. Armaspeed Intake 2015 RS5
  219. UK: Oil pressure specs on 2009 Audi A5 2.0tfsi?
  220. Windscreen
  221. No boost until 2500rpm
  222. Interchangable parts?
  223. FI: 2013 Audi rs5 shaking while at idle
  224. Treating top with Porsche Cabriolet Top Protectant and Waterproofer
  225. 2014 S5 DRL has a short
  226. 2010 A5 cab soft top and trunk release problems
  227. Help, Please!!! 2013 salvage
  228. S5 4.2 Oil pressure sensor/switch location?
  229. B8 s5 MMI and buttons suddenly dead
  230. Android Auto stopped working
  231. Audi S5 4.2 FSI (B8) with Sport Features
  232. 2016 A5 2.0 Unitronic Tune..
  233. HNav usa map updates
  234. 3.2 FSI known oil pump or rod bearing issues?
  235. 2011 A5 MMI 3G HIGH FIRMWARE UPDATE PROBLEM..
  236. 2010 B8 S5 driveline fluid change help
  237. HELP! S5 oil pressure switch replaced/warning still comes on
  238. Found A Great Chaennel
  239. Replacing and securing front tow hook cap
  240. ESC and Dynamic steering fault
  241. UK: Gearbox ECU location? Audi A5 diesel 3.0 2014
  242. Rain, humidity, light sensor in windshield
  243. Road noise after 55k service
  244. A5 S Line Cab - Roof Fault
  245. RS5 build
  246. UK: Please please help me
  247. MMI 2G stuck in bootloader (Search CD players)
  248. Virtual Cockpit question Google Earth
  249. Need advice on potential purchase: 2011 S5 Cab (19k miles)
  250. Where to buy the A5 Black Edition Plus spoiler? Want one for my S5 Coupe
