FIX [Treo650 resetting when linking to '06 Audi Bluetooth]
Recently my Treo650 starting constantly resetting when it would try and link up with my S4 via Bluetooth. Tried a bunch of stuff since I was recently testing some software, deleted stuff, soft and hard reset, nothing worked. Finally stumbled across what turned out to be the fix (found in palm forums).
If you have phone numbers listed in your favorites, and you have "extra digits" listed using the ",,,123" format, this will cause the conflict. Turns out I had been testing this as well but did not remove it when I was done. I deleted the extra digits and phone now connects properly again.
Not sure if this happens with other phones but figured I would spread the word, even if it is old news.
Eric.
Eric.
Re: FIX [Treo650 resetting when linking to '06 Audi Bluetooth]
What's the ,,,,123 format ?
My Treo650 resets whenever I call my wife, take a leak, worry about the RedSox, read a book, search for something that scrolls by more than 3 screens.......
It is the....
Method the Treo phone app uses to dial extra digits after connecting the call. A "," is a pause so the example would be call connect, pause-pause-pause-pause then dial 123.
Sounds like you may have one of the bad Treos. I have maybe had 4 resets in the last 6 months.
Eric.
Eric.
Vijay
RS4 (B7 Platform) Discussion
9
01-24-2007 08:32 AM
Eric - The Red S4
11-29-2005 05:07 PM
AUDI-TOR
11
01-07-2005 10:23 AM
