Telematics Discussion
Sponsored by:
Sponsored by:
Motorola BT -> Symphony II integration
Old 02-11-2007, 06:12 PM
T0M3K's Avatar
Default Motorola BT -> Symphony II integration
After my semi-successful PDA integration (GROMAUDIO + Palm TX), it's time for phone integration. My goal is to make it as OEM looking as possible. So I have quick questions.
Symphony II has "phone" mode, but what does it mean?
Do I need to install new microphone, or maybe 02 Audi A4 already has it somewhere?
And last but not least what kit you recommend?
Old 02-20-2007, 07:55 AM
AudiWorld Expert
Boston Driver's Avatar
Default OEM bluetooth or aftermarket...
...netiher one is much harder than the other, but the OEM costs a bit more $$ for the parts.
Advantage of OEM bluetooth, full intergration including steering wheel controls to answer/dial calls. For full features, nice intergration along with RNS-E navigation unit. Components are invisible.
Advantage of aftermarket kits (like Motorola or Parrott) cost. Disadvantage is that you are left with an extra button/control switch on your dash somewhere.
Both OEM and aftermarket setups will allow for sound to pass through your exisiting speakers, and will automatically mute when calls are placed/received.
Both choices are fine, depends on what you want, and how much you are willing to spend.
Old 02-20-2007, 09:03 AM
T0M3K's Avatar
Default Power
I don't have navigation or fancy steering wheel.
The only thing that really bothered me is how to power Bluetooth components, I heard stereo doesn't offer enough juice.
Old 02-20-2007, 11:20 AM
AudiWorld Expert
Default you hook right up to the power leads under the dash...
most BT kits will come with a power wire that includes an in-line fuse. Just connect the other end to the power leads. There will probably be a wire for constant power, switched power, and ground.<ul><li><a href="https://forums.audiworld.com/telematics/msgs/1153.phtml">aftermarket BT installation</a></li></ul>
Old 02-24-2007, 05:46 PM
TeddyBGame's Avatar
Default wow....sounds like you are starting to make positive posts towards the OEM BT option....
...that's a new development. I remember you saying that the OEM BT option was not worth the $$....have you changed your tune yet?
Let me know if you need a harness, mic etc...I've got lots of them in stock.
Good luck!!!
-Ted
richoustonA4
A4 (B7 Platform) Discussion
02-06-2013 09:47 AM
allroadCole
07-01-2007 08:23 AM
weaselchew
11-21-2005 09:25 PM
RKJ
10-28-2005 01:47 PM
cbrown9064
07-27-2005 06:48 PM
Quick Reply: Motorola BT -> Symphony II integration
