Electrical problem
Anyway, the point is that it sounds like random microcontroller weirdness. If you have vag com you can make individual controllers reset themselves, but if not you might have to do something like disconnect the battery, let the car sit for several minutes, then reconnect it. Of course this will make everything reset and some stuff may happen (like you might have to enter the lock code on the radio, or the ECU might spend 10+ minutes fiddling with the engine performing diagnostics, etc etc) So before unhooking the battery I'd check to see what needs to be done after you reconnect it on your particular car.
