help please, lights flashing ABS light on, door locks cycling
2001 Audi TT 225 coupe. Just tonight, the ABSand ESP lights went on, hazards quickly flash for a period of 3 seconds then stop, and door locks cycle as lights flash.
Vag Com says:
no engine fault codes.
ABS module: 00285 right front wheel speed sensor (G45)
Instrument cluster: 01316 ABS Control Module please check fault codes.
no other fault codes. Knowing the common issues with both the cluster and the ABS module I am leaning towards the ABS module as being down for the count. I do not want to waste $1000 replacing the cluster if I don't have to. unless otherwise directed, I guess a call to module masters is due. The only thing weird is the door locks cycling as the hazards flash.
Vag Com says:
start here >>
<img src="http://images12.fotki.com/v215/photos/4/435091/2588192/32Wheelspeedsensor-vi.jpg">
photo courtesy of MCPaudiTT
clean off the flat surface of the abs sensor (where the screwdriver is pointing to) -- it will be covered in magnetized bits of metal that you can brush off and wipe. clear your abs code (in the abs module in vag-com). see if this resolves some of your problems. as far as the door locks cycling, hazards flashing.... no idea. maybe someone else can help there.
fyi: you don't need to pull the brake rotor to get at the sensor -- just the wheel.
a couple things i might check>>>>
the battery fuse box which is the component right on top of the battery....check all the connections to insure they are not rusty or corroded. With our New England weather, a bad connection could be part of the problem...
The flashing lights....how old is the battery?
When was the last time you did a green temp sensor?
I vote the easy stuff first.....
Kirk
Performance and Tuning
12
11-29-2015 12:57 PM
S4MarkS4
12-05-2005 10:48 PM
