New Milltek Hi Flow received...any install hints or tips?
I realize it is pretty straightforward, but any help appreciated. It is going on my 2002 180hp TTQ.
I have never seen the anti-leak paste that was included. How much should I use? Thin coat, thick coat, just in the cutouts/slots in the joints or around the entire circumfrence of each joint?
I realize that heat will cause the system to lengthen, but will it cause the tips to also "rise" in relation to the cutouts, in other words, should I set it a little low or just try to get it centered in the cutouts?
Also, what DV valve would you suggest to go with this exhaust, or should I wait until I chip it (next mod)?
Thanks in advance for any help.
Michael
Michael
they'll lengthen but not 'rise' so try to center them...
to get mine centered I had to rotate the pipe that runs to the cat.
I'd recomend having the exhaust tack welded once you get it where you want it..
DV
wait until your stock one tears up. they are quicker reacting than piston type valves. and it seems like many of the aftermarket diaphram valves tear up anyway. my stock valve been ok on my chipped car for about 9 months or longer. i'm in the minority here though. (and it will probably tear today with my luck)
Re: where did you buy it? im looking for one for the 180Q as well...
Got it from Stratmoshere. The only dealer that I know of. The system is the same for the 225 or the 180Q.
http://stratmosphere.com/milltek_tt_exhaust1.htm
Got it installed last night. Pain in the %$#. Not because of the system, but I had to do it on a gravel driveway at about a 20 degree slope, in the rain, with just enough room to wriggle my fat butt under the car. The system went together very well. I have a little misalignment in the tips but I just need to fine tune the adjustments. The newer system actually has adjustable hanger brackets on the "Can".
The sound is nice and mellow, just a little bit louder that stock, and I can only notice it when I get above 3500 rpm. I drove it in to work today and it seemed to smooth out some acceleration problems I was having (I have read this same comment on another Milltek review). I really havent put my foot into it yet, but I did notice that my MPG went up on several stretches that I had been keeping track of over the last few weeks so I could compare the before and after effects.
So far I am a happy camper. It was not cheap and I cant say it is better or worse than other systems, but I am pleased with my first mod.
Michael
Michael
AuditudeRS4
RS4 (B7 Platform) Discussion
01-15-2008 01:17 PM
magic37220
07-23-2006 08:42 AM
99MTeknic
13
05-11-2001 05:41 PM
