HELP Immobilizer bad actuator bad r-tronic pump
Hello everyone,
Long story short, the car will not start or turn over but I have full lights and radio and etc... I replaced the battery.
There is a gear light and malfunction on the actuator and possibly the r-tronic pump. I do not hear is priming anymore when i open the door.
Why can't I start the car and why do I have an immobilizer code?
SEE BELOW:
Address 02: Auto Trans Labels: 420-910-156-V2.clb
Part No SW: 420 910 156 H HW: 420 927 156
Component: SL600 5.2L FSI HDZ 0020
Revision: SBH02001 Serial number: 7MHN1523J
Coding: 0000001
Shop #: WSC 06759 128 40452
VCID: 14644498378075EF25-8040
Subsystem 1 - Part No: 420 713 041 C
Component: A11 C02 11.11.08 0A11
2 Faults Found:
005934 - Shifting Actuator
P172E - 000 - Mechanical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 110043 km
Time Indication: 0
Date: 2019.05.23
Time: 20:27:23
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
Torque: 0.0 Nm
Temperature: 21.0∞C
0.00 %
006079 - Hydraulic Pump
P17BF - 000 - Play Protection - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Mileage: 110043 km
Time Indication: 0
Date: 2019.05.23
Time: 20:28:23
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
Torque: 0.0 Nm
Temperature: 21.0∞C
0.00 %
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No SW: 420 920 980 J HW: 420 920 980 J
Component: KOMBIINSTR. VDO H02 0360
Revision: D0H02001 Serial number: AUX7Z0I2FNO0DX
Shop #: WSC 00000 000 00000
VCID: 1C742CB8DF503DAF6D-8048
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
SEE BELOW:
Coding: 0000001
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 110043 km
Time Indication: 0
Date: 2019.05.23
Time: 20:27:23
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
Torque: 0.0 Nm
Temperature: 21.0∞C
0.00 %
Freeze Frame:
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Mileage: 110043 km
Time Indication: 0
Date: 2019.05.23
Time: 20:28:23
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
Torque: 0.0 Nm
Temperature: 21.0∞C
0.00 %
1 Fault Found:
014 - Defective
This seems to be beyond me but seems like you have two separate issues. With the immo being defective you may be out of luck. But it wouldn't hurt to key on and run the shifter from park to drive/sport and back a few times to make the actuator do its thing. Then disconnect the battery and hold the terminals together for one minute to completely drain the capacitors and clear stored memory. Then reconnect them, maybe this will for a lack of better words "spike" the module into restarting, ive scene this work on some abs modules.
audiringpwr
03-09-2005 02:39 PM
audiringpwr
03-09-2005 01:50 PM
