Flashing yellow oil sensor light?
Old 12-02-2010, 12:52 PM
  #11
headshok2002's Avatar
Also having this stupid light come on. Scanned the car:
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 H
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 03300
Shop #: WSC 93023
WAULC68E92A310715 AUZ6Z0B0079601
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
Actually due for an oil change in the next day or so as I approach 115 000 kms, so I will check out the wiring that's visible and go from there.
Old 06-21-2016, 03:21 PM
  #12
Hard Driver's Avatar
Originally Posted by infamous107
So after a month of troubleshooting this Yellow "oil can" sensor indicator. i change the sensor (150 bucks), wiring (10 bucks), coolant temp sensor (25 bucks), a couple vacuum lines (3 bucks),.... knowing that after all that troubleshooting it was a burnt 10amp fuse in the fuse box that i found myself thinking that a dealership would know better... priceless.
And take note that its been to two Audi dealerships…
Lesson learned, always check the small things before you start getting your hands dirty. Props to this site!!!
Thank You!! Fuse 5 on a 2008 A4. And the Oil Sensor warning light went out.
Old 01-08-2019, 03:30 PM
  #13
Thomas Mcgarr's Avatar
So this has been the biggest pain in my rear for about a month. I found broken wires at the base of the sensor and thought "ok easy fix". Fixed the wiring and still the indicator on the dash shows. so then i went with replacing the sensor and still bad indicator shows. plenty of oil in the car and i have no where else to go... can anyone help on this topic PLEASE!!?!?!??!!?
I have the same problem i replaced the sensor and wired new plug and still yellow oil sensor light on is there a reset or something?
Old 05-15-2019, 05:15 PM
  #14
Seanjames's Avatar
Default My a4 has the same problem, what fuse went?
What fuse did you replace?
Old 05-20-2019, 03:43 AM
  #15
infamous107's Avatar
Sean,
i dont have this car anymore more so I can’t get specific on the exact fuse, but it’s the fuse in the fuse box to the left of the steering column. But in all honesty, I had some rodents chew threw the wiring which popped the fuse to the sensor (it’s like a 10a I believe), then went and changed the oil sensor, then after further troubleshooting, the fuse was popped again due to another short in the wiring run. So long story short, check to see if the wiring is clipped, then the fuse in the fuse box, then the oil level sensor located at the base of the oil pan. This SHOULD do the trick. The oil level sensor usually never goes bad, but I changed it anyway.
jschick
07-28-2011 09:50 AM
jumpnofear
11-03-2009 04:16 AM
JVance
05-02-2009 02:40 AM
Knightstick
07-19-2008 10:52 PM
Quick Reply: Flashing yellow oil sensor light?
