Clutch change now car wont start
Old 10-20-2014, 03:59 AM
Colton92's Avatar
Default Clutch change now car wont start
I think I know what the issue is I just wanted to get your guys advice/opinions.
While I was trying to line the dowels and the input shaft in, the transmission slipped from the the jack a little bit and came down on a sensor that seems to measure the teeth on the flywheel what is this sensor called? And will it cause the engine to crank endlessly and not start?
1996 Audi B5 A4 5 speed fwd.
Location of sensor is driver side about half way to 3/4 of the way to the top of the transmission.
Old 10-20-2014, 06:15 AM
David.Norton's Avatar
Sounds like the crankshaft position sensor, and yes if it is damaged the engine will not start. You might want to read the codes and verify, if I remember correctly you will need to clear the code before the engine will run once you replace it.
Old 10-21-2014, 02:14 PM
Colton92's Avatar
It is not a crank sensor it is a crank pulse sensor I have never even heard of such a thing what is its purpose?
Old 10-21-2014, 02:23 PM
Colton92's Avatar
or a crank angle sensor.
CWTech
18
11-20-2020 07:07 PM
gregorydouglas89
A4 (B7 Platform) Discussion
20
11-04-2018 08:21 PM
G_claudz
09-15-2015 10:47 AM
jared8783
09-09-2015 08:18 AM
ign 5
08-29-2015 02:45 PM
Quick Reply: Clutch change now car wont start
