Sweet Coolant Smell
Old 06-14-2014, 12:09 PM
  #31
SloopJohnB@mac.com's Avatar
Originally Posted by thall6594
Sensor was changed this morning, haven't had the chance to see if it was still leaking yet. The shop told me there was a slight leak into cylinder 2, and I once got a cylinder 2 misfire code and smelt coolant. (cleared the code and it has yet to come back)
The car blew a water pump and overheated nearly 38k ago, has been fine until about 1k ago though so I don't think that really had anything to do with it?
Depends on how bad it was overheated. 38K ago probably wasn't the cause.
If you're going to trade the car go ahead and put the bars leak in it…it's designed especially for head gaskets so what have you got to lose? If it works, good. If it doesn't, you're no worse off.
Old 06-14-2014, 12:17 PM
  #32
~$32 Amazon Prime:
Head gasket leak detector...
Amazon.com: Lisle 75500 Combustion Leak Detector: Automotive Amazon.com: Lisle 75500 Combustion Leak Detector: Automotive
Old 06-14-2014, 01:58 PM
  #33
Well I have no oil/coolant mix, so it isn't that bad, yet.
I was thinking about just throwing this in.
http://barsproducts.com/catalog/view...asket-fix-1111
It is suppose to seal the gasket. If it works until I find a new car that's all I need. This car is quickly becoming ****ing junk.
The other issue is exhaust gases in the coolant. They will very quickly exhaust any anti corrosive additives in the coolant and damage the engine thereafter.
Old 06-14-2014, 10:45 PM
  #34
thall6594's Avatar
Originally Posted by SloopJohnB@mac.com
~$32 Amazon Prime:
Would that work on the overflow tank?
Old 06-15-2014, 08:09 AM
  #35
That's exactly where you use it. You put some test fluid in the tester and suck up a given amount of coolant from the coolant tank. If the fluid turns yellow you have HC (combustion gases) leaking into the coolant, ergo a head gasket leak.
eldoj
07-09-2012 04:46 AM
ucf_motorcycle
9
04-14-2010 10:41 AM
yvk_99
Audi 100 / A6 (C4 Platform)
05-31-2006 11:34 AM
Kirath ¾-B0§t0n
10-30-2002 12:06 PM
Quick Reply: Sweet Coolant Smell
