A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Bentley manual assistance please...
Old 10-24-2014, 10:17 AM
fe342185's Avatar
Default Bentley manual assistance please...
Looks like my front right door latch assembly needs to be replaced. I know how to take the door panel off but need help in removing the latch assembly. Please help if you have it available.
Fyi- stealer wants $350 for labor plus the part at $372. Door panels comes off in 3 minutes now that I know how to remove it.
Online dealers sells for $270ish.
Part number in case anyone needs for front right door: 4F1837016A
Thank you.
Old 10-24-2014, 11:02 AM
put3namo's Avatar
Default Typical on the other side?
Removing and installing power latching system
Old 10-24-2014, 11:17 AM
fe342185's Avatar
Hi put3namo,
Thank you but i believe what you posted is the power latch that pulls the door in when its patially closed. I believe this option was only available on the A8 in the US. The part that I need to replace is the door latch itself. The part that hooks the door onto the B pillar.
Thank you very much for assiting and quick response.
Old 10-24-2014, 11:33 AM
stroker351w's Avatar
Is there a full PDF version of the Bentley Manual for an S6?
Old 10-24-2014, 12:18 PM
put3namo's Avatar
Default Maybe this will help ?
Old 10-24-2014, 12:20 PM
put3namo's Avatar
Not that I know of, Sorry ... I use Elsawin DVD
Old 10-24-2014, 01:33 PM
fe342185's Avatar
Thank you put3namo. The guide say to remove the window regulator assembly. I hate to be a pain but do you happen to have the instructions for the window regulator?
Thank you so much.
Old 10-25-2014, 02:44 AM
put3namo's Avatar
Default Removing and installing window frame and window regulator
Note
Disconnect battery before removing window frame or door.
Old 10-25-2014, 03:31 AM
put3namo's Avatar
Default you may not need to remove the door handle
but may need to dis-engage the operating rod -3- from door lock -hope it helps >>> enjoy the weekend!!!
Mesa512
S4 (B8 Platform) Discussion
20
07-07-2018 11:23 AM
vansoffyomama
09-28-2015 04:38 PM
jonedwd
Audi A3 / S3 / RS 3 MKII
09-26-2015 10:49 PM
Audigirl121
Want To Buy - Archive (NO NEW POSTS HERE)
09-26-2015 12:51 PM
beep-beep
Audi A3 / S3 / RS 3
09-24-2015 02:25 PM
Quick Reply: Bentley manual assistance please...
