A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Camshaft Sensor/solenoid
Old 07-10-2016, 05:03 PM
Jmartin827's Avatar
Default Camshaft Sensor/solenoid
I recently purchased my first Audi, 2005 A6 3.2. It is running rough and I'm getting the following readouts. p0341 )camshaft position sensor "A" Circuit Range/performance. P0304, p0305, p0306 Misfire cylinder 4,5,6.
After reading some threads on this site I thought I would try swapping the solenoids from the passanger side on the driver side. When pulling one of the solenoids out, it split apart. Attached photo.
Is this solenoid finished and needs to be replaced?
What is the best way to get the remainder of it out of the head?
I still want to test if it is the solenoids that are the problem but am scared of creating more problems, is there a trick to pulling these out?
Old 07-10-2016, 05:14 PM
Jmartin827's Avatar
Attachment loaded
Attached Thumbnails Camshaft Sensor/solenoid-audi.jpg
Old 07-16-2016, 02:12 PM
Jmartin827's Avatar
wow, nobody has seen this before?
Old 04-14-2020, 04:48 AM
Sommerfeldt's Avatar
Four years too late, but just had this happen right before Easter. Was changing o-rings on these, and one came out in two pieces like this.
I made a small, flat "hook" from some hard steel, and pulled the remains out by the "lip" on the part stuck in the engine. Took some wiggling, since these are tight fitting, but it came out. Won't lie - was panicking a bit.
Since no one answered OP's question the first time around - these are shot if the break apart like that. Didn't look shot, so I tried putting it back together, but the car was NOT happy. Needs replacement if this happens.
- S
Old 04-16-2020, 12:33 AM
AudiNike12's Avatar
Happened to me also a couple of weeks ago. Had to make a small hook thingy that would grab on to the inside of the remaining part and pull it out. I was panicking a bit too
The following 2 users liked this post by AudiNike12:
mmthorn (01-16-2021), Sommerfeldt (04-16-2020)
Will Merritt
Q5/SQ5 MKI (8R) Discussion
09-13-2022 04:08 PM
dzywicki
10-18-2019 08:10 PM
msd29
10-15-2010 04:39 PM
b4 audi
05-14-2008 10:54 AM
Matt1colorado
2.7T V6 Discussion
01-27-2007 09:38 PM
Quick Reply: Camshaft Sensor/solenoid
