Telephone/Telematic Control Module -J526- Pin Assignments
The telephone/telematic control module is located under the driver's carpet.....it's J526. Number 8 in this picture:
<img src="http://www.audipages.com/images/d3telephone1.gif">
The connector on it looks like this:
<img src="http://www.audipages.com/images/d3telephone3.gif">
1 - Antenna connection
2 - 42-pin connector (see terminal assignments below)
3 - Antenna connection
Note:
Terminals which are not listed are vacant/unassigned.
Here is the pin out for the 42 pin connector:
<img src="http://www.audipages.com/images/d3telephone2.gif">
42-pin connector
3 - Cellular telephone connection - Audio in
4 - Cellular telephone connection - Battery Feedback
5 - Cellular telephone connection - Ground (GND)
6 - Cellular telephone connection - RS 232
7 - Cellular telephone connection - control-Line 1
8 - Cellular telephone connection - shielding Ground (GND)
9 - CAN-Bus High (Display)
10 - Line(+) Output to radio
11 - Auxiliary speaker (+)
12 - Telephone microphone (+)
13 - K-wire, Data Link Connector (DLC)
14 - Terminal 75x
15 - LED "red" (in Telematic Control Head)
16 - LED "green" (in Telematic Control Head)
18 - Ground (GND) (Terminal 31)
19 - Ground (GND) (Terminal 31)
24 - Cellular telephone connection - Audio out
25 - Cellular telephone connection - Audio Ground (GND)
26 - Cellular telephone connection - power supply
27 - Cellular telephone connection - RXD
30 - CAN-Bus Low (Display)
31 - Line(-) Output to radio
32 - Auxiliary speaker (-)
33 - Telephone microphone (-)
34 - Mute
35 - Output - to Telematic Control Head
36 - Input - from Telematic Control Head
38 - Crash-Signal from airbag control module
39 - Terminal 30 (B+)
I'm going to do an install on a guy who lives in Chicagoland (Ulf) on his D3 using a Bluetooth system. It's not going to charge the phone or have an external antenna, but I was planning on tapping into the mute for the radio and using the B pillar speaker.
Can make a simple schematic for anybody who wants to put in an aftermarket hands free system using the factory wiring.
I will have the D3 ross-tech cable next week!
Paul
Note:
42-pin connector
14 - Terminal 75x
34 - Mute
Paul
Re: Telephone/Telematic Control Module -J526- Pin Assignments
I have the blue tooth kit in my D3. I have it working independently of the car. It uses its own speaker and does not mute the radio. If you figure it out I would love to talk to you as I live in Chicago.
I'm using bluetooth as well with the headset. How clear is the speakerphone and is it loud enough?
I like the headset and was thinking about getting the speakerphone, but if there is a way to get bluetooth to work through the existing Audi speakers I would be ecstatic.
-P
-P
I fully expect the internal speaker to work with the kit.
...of course, you still need the kit. Getting the microphone to work could be an impedance issue, acc'd to PaulW. After speaking with SE tech-support, it's that and more -- Audi apparently uses a condenser-type mic, while SE uses an electrec mic with pre-amp. No biggie, I can deal with an extra microphone.
Now, I note (didn't I mentioned this before somewhere?) that the notorious J526 has an RS232 connection. My HCB-30 also has an RS232 connection, and after plugging it into a computer, I actually get a few prompts at 115.2kbps. Seems like it's a bit of a console port, haven't figured out how to "break in" yet. I was half expecting, half hoping that this would be a GSM-type modem-presence, which allows sharing of contact info and such... which could have been compatible with the V60 cradle. At this time, it doesn't seem to be.
iestatic
S4 (B8 Platform) Discussion
20
07-15-2022 09:43 PM
Aman Singh Parhar
11-29-2016 05:03 AM
vtraudt
09-17-2015 09:51 AM
mdkv5
A6 (C7 Platform) Discussion
09-16-2015 01:09 AM
2005, a8, assignments, audi, auxiliary, control, information, j526, module, modules, picture, speakers, telematic, telematics, telephone
