Audi A1 Discussion forum for the Audi A1
visual parking
Old 01-12-2016, 02:42 PM
vw754's Avatar
Default visual parking
Hi i tried to activate the function on my sisters A1 1.4 tsi....think thats it........its got factory sat nav,have vcds but couldnt get it to work any ideas? its a 2011 car with rear parking sensors...only bleeps at the moment
i tried this but still a no go
n the parking aid control unit gives you the option of the Audi A1 8X to activate the visual display of the parking aid via the MMI, even if only the 'small' is installed for rear parking aid.
[Activation of Audi Parking System]
Select STG 10 (parking aid)
STG access authorization - Select function 16
Access Code 71679
STG coding -> Seçim function 07
Byte 0
Bit 2-3 (08 visual display active (BAP NEW) selection)
STG adjustment -> function 10
Select "Visual display for park assist"
New Value: OPS Display
The following code is to be applied:
Enter access code 71679
STG coding -> Select function 07
Select Byte 0
Bit 3 Enable
(08 visual representation active (BAP NEW) Select)
MMI reset
(press and hold down the Return key -1- (Back), the confirmation button -2-, -3- and the scroll key at the same time. The MMI then goes down and restarts. Takes about 60 seconds)
Alternatively, should active Bit 3 not function display
Select Byte 0
Bit 2 enable
(04 visual representation active (BAP ALT) Select)
Disable Bit 3
raj99
Q5/SQ5 MKI (8R) Discussion
35
02-24-2018 01:35 PM
hellonwheels33
10
06-15-2016 09:49 PM
slowguy
10-25-2012 06:41 PM
RenatoS4
03-05-2008 10:29 AM
DirkM
VAG-COM Discussion
05-31-2006 07:07 AM
Quick Reply: visual parking
