Tranni problem
Tranni problem
so i i think i blew my tranni but not sure what it could be. so what happened was is i was a t light in neutral and then pushed the clutch in i moved the shifter to 1st gear then let it out and i let the clutch out like normal which would be slow enough to not burn the clutch up but yet slow enough for it to properly grab. then i hear a couple of bangs and then its now stuck in first and i can freely move the shifter to any gear slot including reverse. when the car moves it makes a grinding noise.
1st question is what could have happened?
2nd question is it possible to look inside the tranni without removing it from the car?
awdinut
32
09-03-2016 04:38 PM
