TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
left door latch replacemet
Old 08-31-2015, 07:21 AM
peter.loux@gmail.com's Avatar
Default left door latch replacemet
I have a 2009 TT with need for a left door latch replacement advice on replacement techniques and time estimates.
Old 08-31-2015, 12:43 PM
Audiworld Basic Sponsor
ECS Tuning-Audi's Avatar
Interior or exterior?
Jason
Old 08-31-2015, 03:09 PM
Jason
The door latch mechanism is inside the body of the door frame, and somehow requires the interior panel to be removed, and then to take out the door latch electronic mechanism that is part of the door locking activation by the key fob.
Peter
Old 09-01-2015, 05:59 AM
Peter
Below is link to I believe the part you would need.
Click HERE to order or for more information
You definitely will have to remove the door card. You may need to remove the door channel too.
Jason
Old 10-31-2018, 02:25 PM
veloman08's Avatar
Default Unsure of replacement technique for door lock
I have bought a replacement door latch mechanism for my 08 TT convert. I'm not sure of the installation technique to install the new latch connected with the cable to the mounting bracket. Should I bolt the latch to the door before I attempt to install the mounting bracket to the door? It's rather a cumbersome handful with the springy cable attached. Any advise will be welcomed. I have a manual but the re-installation advice is sketchy to say the least.
Old 11-09-2018, 02:09 PM
veloman08's Avatar
The door latch with all its cables installed and mounting bracket can be installed together at one time. My son assisted me and I helped him align the bracket with the holes in the door, Once we had it aligned and the screw at the front installed he slipped the latch into place and we hand started the mounting screws. I would say you need someone to help get things aligned. Once the pieces are installed it's a matter of hooking up the electrics and the inner door pieces. It's a fiddley job but doable.
blink
07-14-2016 11:43 AM
RoyalA8
09-17-2015 08:11 AM
ajg617
09-06-2015 07:23 AM
kjmiles
09-04-2015 04:01 AM
OSUNick
NorCal Discussion
09-02-2015 08:35 PM
Quick Reply: left door latch replacemet
