no heat driver or passenger side vents.......
Alright guys, heres my problem.. i got no heat threw my passenger or driver side vents. and its luke warm through my center vents, window vents and cooler air down to the floors. i have done-
-Flushed Heater Core 2 Times
-Flushed coolant system
-Checked for leaks
-Checked heater core hoses
-Pulled Blower motor and felt heater core its hot
Temp here is about 10 degrees. its sucks.. i am at witts end trying to figure it out. anyone know how to get to the air mix door? i have hvac codes as well ill post them soon if needed
-Checked for leaks
There is a blend door that may be causing your problems. Sorry I can't be more specific, but I can only tell you that it exists and you might be able to use VAG-Com to tell if it is moving properly. I have not had any trouble with my Audi heater, but on other vehicles the blend door routes the air either acrross the AC evap or heater core.
Dave
Dave
-Checked for leaks
-Checked for leaks
This may not be your issue, but read this thread.
https://www.audiworld.com/forums/a4-...2860332/page2/
It is the cause for many with no/low heat in cabin.
Cmmartin23
26
08-23-2016 04:44 PM
bilbo6209
09-09-2015 01:28 PM
raiderrider
12
09-08-2015 05:46 AM
stormchaser1967
09-02-2015 09:02 AM
