2004 A4 Quattro USP .. Jerking Problem.
I have recently gotten my car back from my buddies shop.. he replaced the transmission I purchased the used transmission from a company using ebay they had very good reviews!. The transmission came out of a "insurance" car, the front end of the original car was damaged not severely but bad enough to consider it totaled.. lol. Anyways after the transmission is installed.. everything seems to be good other then that only when i go into drive it Jerks, I have not lost any tq or hp, no other gears slip or are shifting rough.. It only jerks when i go into drive...
Trans code: GBF
Here are the VAG Codes i am getting...
ENGINE:
Saturday, 04 January 2014, 00:31:41.
VCDS-Lite Version: Release 1.2
Control Module Part Number: 8E0 909 518 AK
Component and/or Version: 1.8L R4/5VT G 0004
Software Coding: 0016751
Work Shop Code: WSC 63351
VCID: 79856EE770C1
2 Faults Found:
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 001 - Upper Limit Exceeded
16524 - Shareware Version. To Decode all DTCs
P0140 - 004 - Please Register/Activate
AUTO-TRANS:
Saturday, 04 January 2014, 00:32:28.
Control Module Part Number: 8E0 927 156 S
Component and/or Version: AG5 01V 1.8l5VT USA 1212
Software Coding: 0001002
VCID: 3E0FBDFB296F
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 003 - Mechanical Failure
Edit/Delete Message
ABS BRAKES:
Saturday, 04 January 2014, 00:32:57.
Control Module Part Number: 8E0 614 517 A
Component and/or Version: ABS/ESP allrad 3429
Software Coding: 04277
Work Shop Code: WSC 06435
VCID: 263F759BD1FF
4 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
18265 - Shareware Version. To Decode all DTCs
P1857 - 35-00 - Please Register/Activate
00526 - Shareware Version. To Decode all DTCs
36-10 - Please Register/Activate - Intermittent
01119 - Gear Recognition Signal
Trans code: GBF
ENGINE:
VCID: 79856EE770C1
2 Faults Found:
AUTO-TRANS:
VCID: 3E0FBDFB296F
1 Fault Found:
Edit/Delete Message
ABS BRAKES:
VCID: 263F759BD1FF
4 Faults Found:
2004A8L
18
01-10-2022 03:04 PM
eTh!nk
Wheels & Tires Discussion
04-10-2007 04:11 PM
