how hard is it to remove/install interior trim pieces
Pics are welcome. I did a search and nothing came up (sea of red x's for install pics). Also, because i may be swapping my aluminum trim for wood, how hows the wood trim look on platinum interior?
very very easy (m)
with the doors, start out at the door handle. Right above the door handle lift up on the trim. Then work your way from the door hinge towards the other end. When you get the last clip out pull the trim piece towards the front of the car and it will slide out. The dash is a little more complicated but still easy. You need to pull the trim piece out that is above the radio. That is also just clipped. Remove the headlight switch, and remove the fuse panel covers on each end of the dashbord, and finally, remove the cover under the steering wheel. Thus revealing all the screw to take the dash trim off. Hope this helps. Sorry, no pics :-)
ECS Tuning-Audi
Q5/SQ5 MKI (8R) Discussion
11
02-24-2023 12:58 AM
Audi Other FS: 2007 Audi RS4 black/black CCW
ilikeit
01-09-2016 09:24 AM
ECS Tuning-Audi
09-10-2015 12:39 PM
kjmiles
09-04-2015 04:01 AM
