I just about want to throw up every time I...
Old 02-25-2009, 02:46 PM
wisconsin_quat's Avatar
Default I just about want to throw up every time I...
try to remove rear calipers from the B6 A4... I mean really.. how obnoxiously did they design the rear caliper bolts and shock location?? Every upper rear caliper bracket bolt i've touched is stripped.
I'm starting to replace the hex head 8mm allen with a 8.8 grade 17mm 6 point bolt... should be much easier for the next change.
Old 02-25-2009, 05:05 PM
x1rider's Avatar
Default I use a shortened 8mm socketed bit with a breaker bar for clearance...
<center><img src="http://i132.photobucket.com/albums/q33/x1rider/short8mmbit.jpg"></center><p>
Old 02-25-2009, 05:59 PM
do you live outside of the salt belt?
Old 02-26-2009, 02:58 AM
x1rider's Avatar
I'm from northern Ontario
Old 02-26-2009, 05:56 AM
nanotech's Avatar
Default Next time, I'm just drilling mine out from the get-go
Last time, I spent
-1/2 hour fighting with allen key to unsuccessfully break upper bolts loose
-1/2 hour dremeling 8mm allen socket to fit with breaker bar
-1 hour fighting with breaker bar, allen key, jigaloo, heat, mallets, etc to break bolts loose
-1/2 hour cursing at stripped soft ****ty bolts with no leverage
-10 minutes envisioning how to get stripped bolt remover socket into tiny space before giving up
-30 minutes pointlessly dremeling slot into bolt head
-1 hour drinking and cursing
-10 minutes drilling out bolts
Next time, will only be 10 minutes instead of 4 hours. I was uncomfortable with the idea of drilling the bolt out originally, but the bolt is so soft and the caliper and carrier are so hard, it's hard to damage the threads if you're careful.
Old 02-26-2009, 10:24 AM
shwndh's Avatar
That's strange. I don't remember ever having a problem removing them.
Old 02-26-2009, 12:21 PM
Default LMAO!!!
haha.. just a tip for all you out there... the best solution i have found is while the bolt is on the caliper tight/ stripped, just go ahead and grind off about 1/3 of the contacting shoulder with a cut off wheel, then spin the bolt off with a pair of vise grips. should take you 5 minutes so now you're 50% more efficient!
eggsngrits
12-08-2021 06:58 PM
ZPA117
A4 (B8 Platform) Discussion
09-08-2015 11:55 AM
kclee1st
09-05-2015 09:35 PM
wjhpilot
S4 (B8 Platform) Discussion
09-04-2015 01:43 PM
zjw8407
09-02-2015 05:20 PM
Quick Reply: I just about want to throw up every time I...
