New mod installed yesterday
Packed up and headed for my friendly independent shop: fresh batch of Mobil 1 and bbk install w/ Motul 5.1 along w/ Hawk pads for each corner
<img src="http://i9.photobucket.com/albums/a63/rasta4/bbk1.jpg">
Stoptech installation is pretty straight forward and well documented, so I won't bother w/ installation details.
<img src="http://i9.photobucket.com/albums/a63/rasta4/bbk2.jpg">
"OOOooo Look! BBK! And I don't even track the car, but I must have! - Yield///Spread* Lol. So true.
My 17x8 et35 BBS RCs just barely cleared the stoptech calipers (1-2mm clearance at best)
<img src="http://i9.photobucket.com/albums/a63/rasta4/bbk4.jpg">
<img src="http://i9.photobucket.com/albums/a63/rasta4/bbk5.jpg">
A little too close for comfort. I bought 3mm spacers just to be on the safe side, but couldn't use them up front because of the need for longer lug bolts due to the added thickness of the rotor hat. With this kit, an et35mm wheel offset ends up being about et30mm. I had plenty of clearance around the barrel of the wheel though (wheel weights weren't an issue at all)
<img src="http://i9.photobucket.com/albums/a63/rasta4/3mmspacer1.jpg">
<img src="http://i9.photobucket.com/albums/a63/rasta4/bbk9.jpg">
I threw on my 18x8 et35 BBS REs and had plenty of clearance as expected.
<img src="http://i9.photobucket.com/albums/a63/rasta4/bbk6.jpg">
I ended up installing 3mm spacers in the rear to help even up the "new offset".
<img src="http://i9.photobucket.com/albums/a63/rasta4/3mmspacer2.jpg">
Here's a couple of quick shots of the new stance.
<img src="http://i9.photobucket.com/albums/a63/rasta4/bbk8.jpg">
<img src="http://i9.photobucket.com/albums/a63/rasta4/bbk7.jpg">
Hopefully the weather will clear up so that I can do a proper "bed-in" procedure today.
stormchaser1967
09-02-2015 08:48 AM
