Hi everyone help needed
hi i have a a6 3.2 fsi with a stalling issue , it only does this when at normal running temp. it stalls in park or when driving . ive scanned for codes none found. its like it runs out of fuel. ive replaced fuel pump in the tank , and on the engine. ive replaced the throttle positioning butterfly, ive replaced fuel pump relay and fuel pump controll unit . when its plugged in and running u can see the fuel pressure just fall , and the engine stalls, ive also replace the valve on the bottom of the mechanical pump and ive checked resistance of wires to ecu .. can u shed any more light on this please
Hi sorry i dont have access now to scans ,,,,, The only fault tha came up was intermittent fuel pump issue ,, both have been changed and faults cleared. , after car stalled scanned again. no fault codes found , that was in feb. still have no codes found
Without VCDS scans i can only suggest to try replacing this. Try replacing the high pressure fuel rail sensor underneath the manifold on the drivers side fuel rail with a oem unit. As well as the low pressure fuel sensor next to the fuel feed line. And last, the brass check valve/ bleed/ return valve located on the passenger side fuel rail closer to the front.
Like to hear back
-Cheers
Like to hear back
-Cheers
After all the issues it turned out to be the High-pressure fuel valve on the inlet pipe to the high-pressure pump ... it can be seen on the left-hand side of the car where the rubber fuel line meets a stainless steel bar, the sensor is just there .. it was disconnected and tested and didn't stall. I have replaced this,,, and believe this is also the same as the one u mention on the fuel pump
Thanks for all of your help and input
Good to hear back and issue fixed That brass sensor mentioned is low side pressure sensor for the system, also a common fail point.
-Cheers
