Please help with ABS wiring.
Hello all,
I was wondering if someone would be able to help me.
I am trying to extinguish my ABS light. When I got the car it had damage to the front right fender. I replaced the ABS sensor and fixed a damaged ABS line (car harness side). The repair is good, however I still get the light. The car's code says that there is still a fault in this same right front.
I think that I may still have damage/open circuit to the ABS line in that side. The damage to the right front fender was high up, with a small dent to the hood at that side, so I would like to check that part of the harness that runs along the right front upper frame. I think (if mem serves) that part of the harness has F/R ABS, F/R brake pad, washer bottle pumps, and F/R lights.
Is there a plug in the ABS circuit up-line from this point (pass fender wire harness) that I can check the circuit integrity? I just need to see a good circuit from the ABS sensor plug to somewhere past the right fender.
Maybe some one with a Bently could have a look at the elec schematic?
Many thanks in advance,
Mike
Mike
RussB
10
02-15-2007 01:07 PM
