Audi A8 air suspension problem
#51
As long as you don't mind reducing the resale value of the car, go for a standard suspension. Personally I wouldn't buy an A8 that had been modified in that way. Having the ability to change the suspension to the task at hand is worth the extra money. I have driven both types. The comfort of the air suspension is far superior to coil springs. Coil springs are a compromise. With air suspension, there is no compromise.
Try doing the following with coils springs.
Put another way, there are several reasons why Audi abandoned coil springs.
Having said all that, it is your car. I don't care what you do to it. It is your right to do whatever you want to your own property.
Deep snow? No problem.
Road trip? No problem either.
#52
Air suspension is a compromise too, it does not handle the same as coil springs.
Audi still uses coil springs to this day, not on all models but they do.
#53
Thanks for the feedback gents. Just looking at options is all. Coil overs you can set the car like you want it and be done with it. Never having to worry about an air leak again. Yes probably a firmer ride and maybe a little better handling. I can buy one air shock now to fix the problem and wait for the others to go out eventually.
#54
#55
Banned
+1 100%
Plus why destroy the beautiful ride of the A8.......
Most of struts newer go out, so by replacing one you are most probably done for as long as you have your A8. That is much cheaper and much less work than switching to conventional suspension. As far as ride quality air suspension is better in every aspect and it is adjustable by the press of the button. As the last drop, if you switch to coilovers you will not be able to get rid of the warning on your dash.
#56
I can appreciate converting to coils for a Lincoln Town Car, but on a German Überautomobil, I can't see it. Unless you hide the fact(don't), you will reduce the cost of resale significantly, and the car will be worse in every dynamic measure the suspension affects.
#57
Air suspension does many things including virtually eliminating body roll, and with the newer cars, dynamically adjusts height and stiffness based on conditions.
For more details, see http://forum.a8parts.co.uk/attachmen...6&d=1420368237
also see
also see
#58
#59
Hey guys, I read through a couple pages but couldn't find anything about my issue. My front drivers side compressor seems to keep running even when the car is off. There are no lights on the car but when I start the car there's some weird clunky noise from front drivers side.
