Can't get my front struts to air up!!!!!!
#11
There are small valves mounted on struts. They hold a minimum pressure preventing bag to be damaged if created vacuum inside. They can be blocked for some reason. I would check them. Just don't move struts when there is no pressure in there.
#12
Banned
I was afraid of that...I have no idea how to get that valve off or check it etc. It's the gold fitting mounted to the outside of the strut yes?
#13
Valve is that small part pointing down. I think it is just screwed in that angular part connected to the strut. Recently somebody here had one broken, so be careful. I would first try by applying a higher pressure. May be a few drops of WD-40 before pumping.
#14
Banned
SOOOO, My question is: Does the leveling module prevent a good strut from rising if the one across from it holds no pressure?????
Also. I'm sure this is a horrible idea, but I'm takeing the leaking one apart. I'm pretty sure I can find that leak and replace the o-ring or bag that is the problem. Even if I can't as long as I don't destroy anything I'll still have core value.
#15
Why "horrible idea"? That's actually the right one. If it is any of O-rings it should be easy to find it. They must be standard. Not so sure about bag. I believe Continental makes them, but how to get one? If you find the way it would be a great brake trough.
I don't know if computer prevents pumping of only one side. It wouldn't be unreasonable. Otherwise one can drive it on three wheels, or close.
#16
Banned
#17
I wouldn't be so much concerned about that strap. Whatever it is it can be custom made, including tool, or something else can be used. Can you make a few pictures and post them here?
P.S. If it is just a plain ring I can see on drawings than it won't be any problem to make one and crimp it on in place.
#18
Banned
#19
Excellent! I can help. CNC is my middle name. PM is my address.
P.S. Before you cut mentioned ring measure its outside diameter.
#20
Banned
fricken sweet. I'll get the OD and ID and width. I wonder what material it is. I'm sure it has to be maluable enough to crimp but rigid enough to hold over time. I'm gonna take some pics in the morning but what are you thinking in regards to a crimping tool that will fit around the barrel of this strut? I also have to come up with some info on how to get the upper barrel top cap off. I was thinking of calling Jeffery from rebuild masters found on ebay. Another member has mentioned him as being very helpful. I was thinking maybe he would tell me what his process was for dis-assembly. I would love to see any info you have on good part diagrams or graphics. I've seen the strut home work study thing and it's very informative on description and operation details but obviously they don't cover any tear down. There's plenty of people that will try to kill this thing before it starts but I know there is someone out there that has a lead on how this process is done and I just need to find that person. Hope we can figure something out that will make it worth a DIY strut rebuild.
