Help with seat fault codes
I have the following fault codes showing up, but both seats function normal and I cannot clear the codes. ***I did have to replace one of the seat control modules once and prior to getting a new one, I had to move the working one to move the seat with the broken module. I just plugged them in, do they have to be coded or something? If so, can someone assist me in doing this so I can clear the codes? Thanks.
Address 36: Seat Mem. Drvr Labels: None
Control Module Part Number: 4E0 910 760 D HW: 4E0 959 760 B
Component and/or Version: Sitzmemory FS H03 00100
Software Coding: 4063330
Work Shop Code: WSC 00000 000 00000
VCID: 2443E8A39E4B
5 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 10:15:19
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 09:15:52
01448 - Sensor for Driver Seat; Tilt Adjust (G232)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 10:15:19
01974 - Backrest/Head Adjustment Sensor (G376)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 10:15:19
02084 - Component Protection
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 10:15:19
Address 06: Seat Mem. Pass Labels: None
Control Module Part Number: 4E0 910 760 C HW: 4E0 959 760
Component and/or Version: Sitzmemory BFS H08 0060
Software Coding: 3940576
Work Shop Code: WSC 02313 785 00200
VCID: 2341EBBF9B45
3 Faults Found:
01723 - Sensor for Head-Rest Adjustment; Pass. Seat (G282)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 102010 km
Time Indication: 0
Date: 2004.04.14
Time: 11:15:47
01721 - Sensor for Seat Rear Height Adj. Pass. Seat (G280)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 114592 km
Time Indication: 0
Date: 2010.12.09
Time: 11:01:20
01719 - Sensor for Seat Position; Pass. Seat (G278)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 114592 km
Time Indication: 0
Date: 2010.12.09
Time: 11:01:20
VCID: 2443E8A39E4B
5 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 10:15:19
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 09:15:52
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 10:15:19
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 10:15:19
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 10:15:19
VCID: 2341EBBF9B45
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 102010 km
Time Indication: 0
Date: 2004.04.14
Time: 11:15:47
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 114592 km
Time Indication: 0
Date: 2010.12.09
Time: 11:01:20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 114592 km
Time Indication: 0
Date: 2010.12.09
Time: 11:01:20
VCID: 2443E8A39E4B
5 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 10:15:19
VCID: 2443E8A39E4B
5 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 168
Mileage: 115004 km
Time Indication: 0
Date: 2010.12.30
Time: 10:15:19
Seats are not same and they are differently coded. Recoding is a bit longish and not all strait forward. Easiest would be to copy it. I can read codes later and post here. Hopefully same features on two 2005's.
Another thing that helps is moving all commands from one end position to another. It calibrates module.
Thanks, I will try the moving method and I'll save my $110 plus tax...Seats work fine anyways.
Aman Singh Parhar
11-29-2016 05:03 AM
